Winglet sliced off?
Old October 11th 06, 05:43 PM posted to rec.aviation.piloting
Default Winglet sliced off?
I was recently on a SWA flight aboard a 737-800, and looking at the
large winglet that the 737-800 sports (for lift enhancement, drag
reduction), it occured to me that perhaps the recent 737-800 that went
down in Brazil after colliding with an Embraer jet may have had one of
its winglets sliced off. The reports that I have read state that the
737-800 spiraled out of control after the collision, which I could
envision happening if the lift/drag of the main wings had a large
amount of asymmetry due to the loss of a winglet. The Embraer lost a
portion of its wing, so if the two planes clipped wings, odds are the
Embraer hit the 10 feet tall winglet rather than the wing itself since
they are both in level flight.
This is pure speculation, but it will be interesting to see if the
final report from Brazil indicates that this is what occured.
Dean
Old October 11th 06, 06:20 PM posted to rec.aviation.piloting
Robert M. Gary wrote:
Do you think a winglet lose would create so much asymetric life that it
would lose control? It seems hard to believe. And why would it be more
likely to have been a winglet than a wing?
-Robert
Yes, I do. The winglet is about 10 feet tall, which makes it a pretty
big target to get hit by a wing of another plane.
Imagine that the winglet gets mangled but does not come off completely,
imagine how much drag that would put on that side of the plane way out
at the tip of the wing.
Alternately, imagine that the winglet is gone completely. Imagine that
the plane happens to yaw to the left. The intact winglet on the left
side now experiences a side load and high drag. The absent right side
winglet isn't there to produce an equal and opposite drag force. The
left winglet then pulls the plane into a left handed spiral. If the
rudder and ailerons can't match the force from the winglet, you are
stuck in that spiral.
Can this really happen? I'm not certain, but it seems posible.
Dean
Old October 11th 06, 07:04 PM posted to rec.aviation.piloting
pgbnh[_1_]
Ten feet? Maybe more like three or four??
ps.com...
-Robert
Dean
Old October 11th 06, 07:12 PM posted to rec.aviation.piloting
At least 8 feet. Its taller than I am, and I am over 6 feet tall.
View this profile view he
http://www.airliners.net/info/stats.main?id=96
The winglet is close to 1/4 of the total height of the plane which is
41 feet.
Dean
Old October 11th 06, 07:18 PM posted to rec.aviation.piloting
ps.com...
Oh, and if you still think its only 3 or 4 feet tall, look at photo 12e
in this PDF on the Boeing website. Look how much taller the winglet is
than the mechanic installing it!
http://www.boeing.com/commercial/aer...7/winglets.pdf
Old October 11th 06, 07:49 PM posted to rec.aviation.piloting
news.charter.net
ps.com...
-Robert
Dean
Rutan's Voyager lost a winglet and didn't die. It is possible to fly without
one, as did the Embrauer(sp?).
Al G
Old October 11th 06, 09:32 PM posted to rec.aviation.piloting
Jim Macklin
Remember the Voyager had wingtip damage at take-off. They
did some maneuvers to break their winglets off.
A few years ago a 707 had an engine fire and melted about
half a wing off the airplane.
http://aviation-safety.net/database/...0628-0&lang=en
A vertical winglet would be easily compensated with rudder
looking at the
enhancement, drag
737-800 that went
have had one of
state that the
I could
a large
Embraer lost a
odds are the
itself since
see if the
occured.
| Dean
Old October 11th 06, 09:53 PM posted to rec.aviation.piloting
The winglets on the Voyager were much smaller in size both compared to
the wingspan and absolute size. The 737-800 winglets are very tall (8
to 10 feet) and fairly large in comparison to the rudder size and
wingspan.
You may be right that the rudder could compensate, but I could also be
convinced that the rudder wouldn't be enough to do it.
Dean
Discus Winglets Peter F Soaring 8 December 12th 05 05:29 AM
Masak winglet info John Ferguson Soaring 0 December 6th 05 11:49 PM
Winglet Alternative? mike fadden Soaring 1 October 22nd 03 09:46 PM
