Poll: electrical connector crimpers/dies
Old October 11th 06, 06:28 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Default electrical connector crimpers/dies
"Dan" wrote
And that's trained personnel, some of the work I have seen on home builts
makes me cringe.
Do you know of a text, or other reading, that one could study to learn out about
how to do wiring up to your specifications?
Jim in NC
Old October 11th 06, 07:21 PM posted to rec.aviation.homebuilt
Dan[_2_]
Morgans wrote:
builts makes me cringe.
out about how to do wiring up to your specifications?
I used USAF T.O. 1-1A-14. The FAA A.C. (43 series ?)(for the life of
me I can't recall which one) is similar. None of this is a good
substitute for training and practice. I had some bad habits to unlearn
when I started tech school.
There are a lot of little things shown which aren't obvious on first
glance. An example: when soldering a wire into a pin on a connector the
length of exposed wire outside the pin must be less than the diameter of
the conductor. The reason is so a loose (for whatever reason) wire can't
make contact with the conductor. OK, so I am not good at explaining
things, but the basic assumption is that which can go wrong eventually will.
Dan, U.S. Air Force, retired
Exposed Electrical Wires in Boeing 737 Fuel Tanks! Larry Dighera Piloting 0 July 17th 06 06:13 PM
2005 SSA Contest Rules Poll and Election [email protected] Soaring 0 September 27th 05 01:47 PM
Electrical system for Champ 7DC? Jimmy Cash Restoration 3 October 25th 03 08:28 PM
