#11
oups.com... This a change that I can live with. This just moved the end of the "canyon" to the SW end of Roosevelt Island. This means that you can still fly up the East river to almost Central Park. No, you misread the TFR and my summary. The restriction extends to the southwest tip of Governor's Island, not just Roosevelt Island. I think the northeast tip of Governor's Island would make more sense. --Gary Gary Drescher wrote: This restriction strikes me as semi-reasonable, since many or most pilots (including me) already considered the East River U-turn (surrounded by dense traffic) to be too risky to fly there. Now, ATC can ensure that you don't fly up the river unless they're going to clear you to continue all the way. (Helicopters and seaplanes are properly excluded from the restriction.) The main problem I see is that the new restriction starts at the southwest tip of Governor's Island instead of the northeast tip. That seems like an unnecessary complication to navigation there, especially since it forces pilots flying past to descend to 1100' instead of remaining just below 1500'. Perhaps that part of the rule can be changed. (skyvector.com) --Gary !FDC 6/3495 ZNY EFFECTIVE IMMEDIATELY UNTIL FURTHER NOTICE, VFR FLIGHT OPERATIONS INVOLVING FIXED WING AIRCRAFT (EXCLUDING AMPHIBIOUS FIXED WING AIRCRAFT LANDING OR DEPARTING NEW YORK SKYPORTS INC SEAPLANE BASE) IN THE EAST RIVER CLASS B EXCLUSION AREA EXTENDING FROM THE SOUTHWESTERN TIP OF GOVERNORS ISLAND TO THE NORTH TIP OF ROOSEVELT ISLAND, ARE PROHIBITED UNLESS AUTHORIZED AND BEING CONTROLLED BY ATC. TO OBTAIN AUTHORIZATION CONTACT LGA ATCT SOUTH OF GOVERNORS ISLAND ON 126.05. Also NYT: http://www.nytimes.com/aponline/nyre...rtner=homepage |
Bob Noel wrote:
In article , "me" wrote: With respect.. The reason this will help is that when flying up that part of the river while talking to atc they will be able to clear you into the class b and LGA's airspace with out getting stuck in the canyon and not being in a position to make the narrow turn to try and stay out of the class b. If that's the reason, then they should make a class b clearance a requirement for fixed-wing aircraft operating in that corridor. You can't get a class B clearance outside the class B. Changing the class B limits actually has a bit more of a sham procedure the FAA must go through. Issuing random TFR restictions like this can be done on a mere whim. |
In article k.net,
"Steven P. McNicoll" wrote: If that's the reason, then they should make a class b clearance a requirement for fixed-wing aircraft operating in that corridor. Then what would be the purpose of the corridor? bingo. -- Bob Noel Looking for a sig the lawyers will hate |
On Sat, 14 Oct 2006 11:58:18 -0400, Ron Natalie wrote:
You can't get a class B clearance outside the class B. Changing the class B limits actually has a bit more of a sham procedure the FAA must go through. Issuing random TFR restictions like this can be done on a mere whim. The TFR also permits the rotary exception. Discrimination against the fixer-wingers, if you ask me. All because we can't hover w/o a helping headwind. - Andrew |
East River turning radius | Gary Drescher | Piloting | 106 | November 9th 06 05:17 PM |
Second Helicopter Crash into the East River | Bob Chilcoat | Piloting | 2 | June 21st 05 08:50 AM |
No US soldier should have 2 die for Israel 4 oil | Ewe n0 who | Military Aviation | 1 | April 9th 04 11:25 PM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
