I know the FCC says you're not supposed to use cell phones on an
aircraft (even though recent studies show that such use does not overload multiple base stations, as the FCC originally feared). However, has anyone tried it on small aircraft? There is some concern about cell phones interfering with avionics on commercial airliners (the jury is still out for most scenarios), but I don't know if the phones make any difference on a small plane. I suppose it depends on how much of a glass cockpit you have. Will anyone admit to using phones on a GA aircraft? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
I know the FCC says you're not supposed to use cell phones on an aircraft Actually, the FCC only says that for certain wireless phone services. Not all of them have that prohibition written in the regs. (even though recent studies show that such use does not overload multiple base stations, as the FCC originally feared). It's less of a problem now that we've moved away from the original AMPS (analog) cellular phone. However, the study you are probably thinking about doesn't say what you are proposing. It is talking about the Aircell guys identifying that THEIR airborne use (which is not standard cellular) doesn't cause any untoward interference to the ground based systems on the same frequency. However, has anyone tried it on small aircraft? The problem is that it doesn't work. Once we went to much fancier digital systems and antenna systems designed to really pack in the density, trying to hit them from over 1000 feet just doesn't work. Handheld cell phones have never put out more than 850mw when operating at high power (and they would use much less in a plane) and the modern digital ones put out even a fraction of that. It's unlikely that avionics would suffer much. |
Modern GSM phones don't seem to get any coverage at altitude. When I
had my CDMA phone I could send emails when I flow over populated areas. Now, nothing. -Robert Mxsmanic wrote: I know the FCC says you're not supposed to use cell phones on an aircraft (even though recent studies show that such use does not overload multiple base stations, as the FCC originally feared). However, has anyone tried it on small aircraft? There is some concern about cell phones interfering with avionics on commercial airliners (the jury is still out for most scenarios), but I don't know if the phones make any difference on a small plane. I suppose it depends on how much of a glass cockpit you have. Will anyone admit to using phones on a GA aircraft? -- Transpose mxsmanic and gmail to reach me by e-mail. |
In a previous article, Mxsmanic said:
how much of a glass cockpit you have. Will anyone admit to using phones on a GA aircraft? I can't get a signal at cruise altitude in the US. I can in Canada, but I've never tried to make a call or even send an SMS. -- Paul Tomblin http://blog.xcski.com/ Make backups before you try something new or interesting or experimental or radical or if the day has a "y" in it. -- Chris Hacking |
On Sat, 14 Oct 2006 12:27:04 -0400, Ron Natalie
wrote: Mxsmanic wrote: I know the FCC says you're not supposed to use cell phones on an aircraft Actually, the FCC only says that for certain wireless phone services. Not all of them have that prohibition written in the regs. However, has anyone tried it on small aircraft? The problem is that it doesn't work. Once we went to much fancier digital systems and antenna systems designed to really pack in the density, trying to hit them from over 1000 feet just doesn't work. Handheld cell phones have never put out more than 850mw when operating at high power (and they would use much less in a plane) and the modern digital ones put out even a fraction of that. It's unlikely that avionics would suffer much. I once called my favorite CFII to make an appointment. When she answered the phone, there was a lot of background noise but we could still converse. She was talking to me on her cell phone while she was instructing. Obviously, it can work. Of course that was most likely at relatively low altitude in the practice area, near civilization. Many areas where I fly there's no cell coverage at all, on the ground or otherwise. A look at the service provider's coverage map tells the story. Much of the area is RF wilderness. RK Henry |
I'm confused -- I thought in a previous thread you said you lived in
Paris? If so, why does the FCC matter? (Or am I wrong about where you live...?) Chris --- Mxsmanic writes: I know the FCC says you're not supposed to use cell phones on an aircraft (even though recent studies show that such use does not overload multiple base stations, as the FCC originally feared). However, has anyone tried it on small aircraft? There is some concern about cell phones interfering with avionics on commercial airliners (the jury is still out for most scenarios), but I don't know if the phones make any difference on a small plane. I suppose it depends on how much of a glass cockpit you have. Will anyone admit to using phones on a GA aircraft? -- Transpose mxsmanic and gmail to reach me by e-mail. |
RK Henry wrote in
: Of course that was most likely at relatively low altitude in the practice area, near civilization. Many areas where I fly there's no cell coverage at all, on the ground or otherwise. A look at the service provider's coverage map tells the story. Much of the area is RF wilderness. Actually, I have found my cell phone to work better in God's country then over civilization. Less cell towers to hit on to confuse the phone is my guess. My experiences is that the higher you go, the less reliability you get. For me, seems that 6000 AGL is the point where the reliablity decrease substantially. Other then my own experiences, nothing to back up to the reasons why. Allen |
Christopher Brian Colohan wrote in
: I'm confused -- I thought in a previous thread you said you lived in Paris? If so, why does the FCC matter? (Or am I wrong about where you live...?) You are right Chris, but the dude lives in a simulated world *smile* Allen |
I've called people from about 6000 ft. This was back in the days of
TDMA. Now that I'm on CDMA it's harder. I did send an e-mail from about 8000 ft. the other day. --Dan RK Henry wrote: On Sat, 14 Oct 2006 12:27:04 -0400, Ron Natalie wrote: Mxsmanic wrote: I know the FCC says you're not supposed to use cell phones on an aircraft Actually, the FCC only says that for certain wireless phone services. Not all of them have that prohibition written in the regs. However, has anyone tried it on small aircraft? The problem is that it doesn't work. Once we went to much fancier digital systems and antenna systems designed to really pack in the density, trying to hit them from over 1000 feet just doesn't work. Handheld cell phones have never put out more than 850mw when operating at high power (and they would use much less in a plane) and the modern digital ones put out even a fraction of that. It's unlikely that avionics would suffer much. I once called my favorite CFII to make an appointment. When she answered the phone, there was a lot of background noise but we could still converse. She was talking to me on her cell phone while she was instructing. Obviously, it can work. Of course that was most likely at relatively low altitude in the practice area, near civilization. Many areas where I fly there's no cell coverage at all, on the ground or otherwise. A look at the service provider's coverage map tells the story. Much of the area is RF wilderness. RK Henry |
"Robert M. Gary" wrote in
oups.com: Modern GSM phones don't seem to get any coverage at altitude. When I had my CDMA phone I could send emails when I flow over populated areas. Now, nothing. -Robert You don't have to go very high to be "at altitude" to not receive a cell phone signal. Two years ago on July 4 at the top of the Stratosphere tower in Las Vegas, I overheard several people remarkng how their cell phones had roamed to analog to connect. My phone is CDMA and was not able to pick up a digital signal, either on network or digital roaming while analog roaming gave a solid signal. Excellent digital signal at ground level. -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
| Thread Tools | |
| Display Modes | |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 04:55 AM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 04:04 PM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
