I notice that my (simulated) Baron has negative pitch adjustment
available, below the feather position. Does this mean reverse thrust, or what? I tried setting it to -25 on the ramp with the engines running, and each time I tried it, the engine stalled a few seconds later. Am I supposed to be able to go backwards in a Baron? Is this setting for reverse thrust on landing, or what? Or does it even mean reverse thrust? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote: I notice that my (simulated) Baron has negative pitch adjustment available, below the feather position. Does this mean reverse thrust, or what? I tried setting it to -25 on the ramp with the engines running, and each time I tried it, the engine stalled a few seconds later. Am I supposed to be able to go backwards in a Baron? Is this setting for reverse thrust on landing, or what? Or does it even mean reverse thrust? -- Transpose mxsmanic and gmail to reach me by e-mail. If you shift it into "R" it will back up! |
"Emily" wrote in message
. .. wrote: Mxsmanic wrote: I notice that my (simulated) Baron has negative pitch adjustment available, below the feather position. Does this mean reverse thrust, or what? I tried setting it to -25 on the ramp with the engines running, and each time I tried it, the engine stalled a few seconds later. Am I supposed to be able to go backwards in a Baron? Is this setting for reverse thrust on landing, or what? Or does it even mean reverse thrust? -- Transpose mxsmanic and gmail to reach me by e-mail. If you shift it into "R" it will back up! Yep! You can even do that in the air! Which is dangerous without a rear view miror and rear window. :-( |
"Peter Dohm" wrote in message
. .. "Emily" wrote in message . .. wrote: Mxsmanic wrote: I notice that my (simulated) Baron has negative pitch adjustment available, below the feather position. Does this mean reverse thrust, or what? I tried setting it to -25 on the ramp with the engines running, and each time I tried it, the engine stalled a few seconds later. Am I supposed to be able to go backwards in a Baron? Is this setting for reverse thrust on landing, or what? Or does it even mean reverse thrust? -- Transpose mxsmanic and gmail to reach me by e-mail. If you shift it into "R" it will back up! Yep! You can even do that in the air! Which is dangerous without a rear view miror and rear window. :-( I thought you just told the sim to increase winds on the nose to 200 kts. Then press "." as necessary to work the brakes. That's how we back up in real life, right? ugh |
Yes, you can back up a Baron (like the one I own and fly) by shifting into
reverse. It is the R on the switches. Rearward visibility is limited, however, and I usually roll the windows down to look out. It is a lot easier getting the plane into the hangar than using a power tug, like a lot of single engine pilots. On the other hand, taxiing out is simply a matter of raising the hangar door and starting both engines, and then using the hangar door remote control to close the door after leaving. It saves a lot of time. |
Hmmm, I see a little bit of a Troll getting slammed.
How funny is this. All of a sudden MXSmanic, you come into a group being new here and telling people what they need to do. Now all of a sudden you have a question? A pretty basic question at that, isnt it???? And you actually expected a straight answer for all the nonsense that you spit out!!! I Dont Think So................ What goes around, comes around!!!!!!! Not4wood PS You will get your answer, but you will have to earn it from the group as a whole first. Duhhhhhhhhhhhhhhhh "Steven Barnes" wrote in message t... "Peter Dohm" wrote in message . .. "Emily" wrote in message . .. wrote: Mxsmanic wrote: I notice that my (simulated) Baron has negative pitch adjustment available, below the feather position. Does this mean reverse thrust, or what? I tried setting it to -25 on the ramp with the engines running, and each time I tried it, the engine stalled a few seconds later. Am I supposed to be able to go backwards in a Baron? Is this setting for reverse thrust on landing, or what? Or does it even mean reverse thrust? -- Transpose mxsmanic and gmail to reach me by e-mail. If you shift it into "R" it will back up! Yep! You can even do that in the air! Which is dangerous without a rear view miror and rear window. :-( I thought you just told the sim to increase winds on the nose to 200 kts. Then press "." as necessary to work the brakes. That's how we back up in real life, right? ugh |
Actually,
THere IS an STC for reversing props on a Baron...............the only one on a light twin that I'm aware of. Karl "Viperdoc" wrote in message ... Yes, you can back up a Baron (like the one I own and fly) by shifting into reverse. It is the R on the switches. Rearward visibility is limited, however, and I usually roll the windows down to look out. It is a lot easier getting the plane into the hangar than using a power tug, like a lot of single engine pilots. On the other hand, taxiing out is simply a matter of raising the hangar door and starting both engines, and then using the hangar door remote control to close the door after leaving. It saves a lot of time. |
Flight Safety's Lear simulator, when they first installed it
back in the late 70-early 80s would stop in flight if the gear was down and the pilot applied the wheel brakes. You even got the chirp of the tires. "Emily" wrote in message . .. | wrote: | Mxsmanic wrote: | I notice that my (simulated) Baron has negative pitch adjustment | available, below the feather position. Does this mean reverse thrust, | or what? I tried setting it to -25 on the ramp with the engines | running, and each time I tried it, the engine stalled a few seconds | later. Am I supposed to be able to go backwards in a Baron? Is this | setting for reverse thrust on landing, or what? Or does it even mean | reverse thrust? | | -- | Transpose mxsmanic and gmail to reach me by e-mail. | | If you shift it into "R" it will back up! | | Yep! You can even do that in the air! |
I think there have been several reversing prop STC, usually
on seaplanes, such as the BE 18 and even the Aztec. "karl gruber" wrote in message ... | Actually, | | THere IS an STC for reversing props on a Baron...............the only one on | a light twin that I'm aware of. | | Karl | | | | "Viperdoc" wrote in message | ... | Yes, you can back up a Baron (like the one I own and fly) by shifting into | reverse. It is the R on the switches. Rearward visibility is limited, | however, and I usually roll the windows down to look out. | | It is a lot easier getting the plane into the hangar than using a power | tug, like a lot of single engine pilots. On the other hand, taxiing out is | simply a matter of raising the hangar door and starting both engines, and | then using the hangar door remote control to close the door after leaving. | It saves a lot of time. | | | | | | |
| Thread Tools | |
| Display Modes | |
| Update on new paint job and leather seats - Trip back home | Longworth | Piloting | 6 | November 21st 05 07:52 PM |
| A chance to give something back | Jack Allison | Piloting | 14 | October 24th 05 12:41 AM |
| KVUO to KAST & Back IFR 1.8 Act. 2.7 Total "First In Act. IFR X-C" | NW_PILOT | Piloting | 20 | June 29th 05 05:27 AM |
| Interesting. Life history of John Lear (Bill's son) | Big John | Piloting | 7 | September 20th 04 06:24 PM |
| Student Pilot Stories Wanted | Greg Burkhart | Piloting | 6 | September 18th 03 09:57 PM |
