RV-8 What happened?
Old October 14th 06, 04:42 PM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
Default RV-8 What happened?
"Lady Pilot" wrote in message
news:vdYXg.6100$fl.417@dukeread08...
"Capt. Geoffrey Thorpe" wrote:
"Lady Pilot" wrote:
Inhofe's Plane Experiences Problems After Landing
POSTED: 12:12 am CDT October 6, 2006
UPDATED: 12:31 pm CDT October 6, 2006
TULSA, Okla. -- A single-engine plane piloted by Sen. Jim Inhofe spun
around
after landing at a Tulsa airport, authorities said Thursday.
Ground loops happen.
Of course...I've owned 3 Beech 18 tail draggers...
Cool. I've always wanted to fly one of those.
Learned to fly in a C-120, but I'm so rusty nowadays that my brother doesn't
let me handle his T-18 or his "Pitts" on the ground.
A taildragger is dynamically unstable because the center of mass is
behind the main gear -
Are you an aerodynamics engineer? ;-) Many pilots around the world are
"effiencient" in training by a professional.
B.S. Mechanical Engineering, M.S. Electronics and Computer Controlled
Systems.
My brother is the one with degrees in Aero engineering.
get it a little sideways and it wants to continue around all the way.
Perhaps it was the end of a long day and the pilot got a little behind
the aircraft, or..., or... or...
Or....where are you? heheeheeeee
Yea.
Geoff
Old October 16th 06, 07:01 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On Sat, 7 Oct 2006 09:24:16 -0400, "Peter Dohm"
On Fri, 6 Oct 2006 22:17:54 -0500, "Lady Pilot"
"Roland Herwig, a spokesman for the Federal Aviation Administration in
Oklahoma City, said a preliminary inquiry found that the plane spun
around
briefly upon landing.
"Finnerty said Inhofe thinks there may have been a problem with the
plane's
rudder.
"The plane is old-fashioned, with two wheels in the front and one in the
back, Finnerty said."
Any clues?
Could be human error, could be mechanical error. The Senator wouldn't be
first pilot to lose control while landing a taildragger.
As for potential mechanical causes, could be a jammed brake, could be a
problem
with the tailwheel itself. We had a Maule at a local airport lose one of
links that connected the tailwheel to the rudder, a month or two back.
Depending on how the tailwheel control is set up, this could cause the
tailwheel
to turn sharply.
The same has happened down my way.
Tension springs can simply defy inspection--especially on a pre-flight.
We had one throw a spring here at 3BS on take off last summer or the
summer before. It shook but he already had rudder control. Other
than the pilot being a bit apprehensive on landing (he wasn't sure
what had happened but had a good idea). The landing was uneventful.
When he came to a stop they found the one spring hanging loose. I
don't think they found a reason for it coming off as it had plenty of
tension.
Peter
www.rogerhalstead.com
Has anything happened to Stemme? Martin Gregorie Soaring 4 October 31st 05 11:57 AM
What happened at PAE this Saturday M General Aviation 1 February 1st 05 08:02 AM
What happened at PAE this Saturday M Owning 1 February 1st 05 08:02 AM
Whatever happened to ? Anne Military Aviation 48 May 26th 04 06:47 PM
What really happened to Chuck Noland's plane Mxsmanic Piloting 29 November 7th 03 10:15 AM
