anyone interested in high-res performance charts?
Old October 18th 06, 07:06 PM posted to rec.aviation.piloting
buttman
Default anyone interested in high-res performance charts?
I'm in the process of vectorizing all the charts in the PA-28-161
Warrior III POH. I am mostly doing it to make it easier on me and my
students when reading them. The takeoff roll charts you almost need a
microscope to get an accurate reading, the lines are so close together.
I plan on doing all the ones in my Warrior III POH, then I'll plan on
doing the PA-34-200T manual I have, then hopefully if I can get my
hands on one, I'll do a Baron 55.
Anyways, is anyone else interested in these charts? Is there any other
service out there that does the same thing I'm doing? Here are a couple
examples of what I have so far:
http://isodrosotherm.info/5-19.pdf
http://isodrosotherm.info/6-13.pdf
If anyone has a POH with hard to read charts, and they'd like me to
vectorize them, fell free to contact me with some scans.
Old October 18th 06, 08:26 PM posted to rec.aviation.piloting
Stubby
The charts look very nice. Do you reenter them? They are too good to
have been scanned in. I'm always interested in the Warrior II and
C-172. W&B charts are most important. Thanks.
Old October 18th 06, 08:35 PM posted to rec.aviation.piloting
Peter Duniho
"Stubby" wrote in message
have been scanned in. I'm always interested in the Warrior II and C-172.
"Vectorizing" means that he is taking the original charts and essentially
redrawing them, using a vector-based description (that is, rather than
drawing the charts in a manner similar to painting or printing, the charts
are described as lines from one point to another).
Google "raster versus vector" for more info. The bottom line is that the
resolution of the displayed chart is matched to whatever medium they are
being displayed on. Only the endpoints of each line used to describe the
chart are stored (ie vector data), and during display the actual raster data
required to show the charts on the chosen medium (computer screen, printed
page, etc) is derived from that vector data to match the resolution of the
raster device being used.
So, yes...they are necessarily "reentered" and not scanned (that is, they
may have been scanned as part of the vectorization process, but the end
result you're seeing is not the scan itself).
Pete
Old October 18th 06, 09:21 PM posted to rec.aviation.piloting
Jim Macklin
You can work from FAA data, it is public. But you can't
legally copy a manufacturers pages, that is copyrighted.
Also be sure you put make/model and serial number ranges on
the product. Remember you to can be sued if somebody uses
your product and is injured. Talk to your lawyer and
insurance man.
That said, those charts are for speed and convenience, they
are created from mathematical data points by teams of
engineers. That's why you see terms such as "straight line
variation between point" on so many charts.
Even more than that said; as the end user you can scan at
1200 dpi, the charts from you own airplane and they will
print out very big and easy to read.
Good luck, BTW, when I use a performance chart, I always
take the least favorable number if it is too close to call.
"Peter Duniho" wrote in
message ...
| "Stubby" wrote in
message
are too good to
and essentially
rather than
line is that the
medium they are
to describe the
actual raster data
screen, printed
resolution of the
(that is, they
| Pete
Old October 18th 06, 09:51 PM posted to rec.aviation.piloting
buttman
insurance man.
Oh, I'm not planning on selling these. They take maybe 1 hour each to
do. I was just planning on putting them up on my website for all to use.
Old October 18th 06, 11:07 PM posted to rec.aviation.piloting
Jim Macklin
Still you'll be advise to have a prominent disclaimer, even
if your rendition is perfect, you could be sued.
"buttman" wrote in message
on
uses
| insurance man.
they
line
at
always
call.
hour each to
for all to use.
Old October 19th 06, 12:35 AM posted to rec.aviation.piloting
john smith
What software/hardware do you use to vectorize the images?
Old October 19th 06, 02:47 AM posted to rec.aviation.piloting
buttman
First, I scan the charts with my scanner from the POH. Then I open the
charts in an image editing program (I use Adobe Photoshop), and rotate
the image so the axes are straight. Then I open the file in Adobe
Illustrator and just use the pen tool to trace over the lines. The
hardest part is making the grid, since the lines aren't perfectly
parallel with each other (I have to do each one individually). All in
all, it takes anywhere from 1 to 2 hours to make a single chart. It's
something I do while I'm at my computer listening to music.
Unfortunately, Illustrator costs like 500$, so unless you have money to
burn, or have other uses for the program, it's not cost effective.
There may be free alternatives to Illustrator, but Illustrator is the
industry standard.
Old October 19th 06, 04:04 AM posted to rec.aviation.piloting
Peter Duniho
ps.com...
industry standard.
Well, Photoshop has a line/pen tool as well, as does its little sibling
Photoshop Elements. You can get Elements for under $100 (assuming it wasn't
included in some other bundle one has already purchased...that happens a
fair amount).
Illustrator has lots of great, fancy vector-type tools, but for something
like this they probably aren't needed. Of course, if you already happen to
have Illustrator, I guess that's the way to go.
Pete
Old October 19th 06, 01:10 PM posted to rec.aviation.piloting
Ron Natalie
Selling isn't an issue. Copying is.
Revisiting lapse rates (From: How high is that cloud?) Icebound Instrument Flight Rules 5 November 26th 04 09:41 PM
Performance World Class design proposal iPilot Soaring 85 September 9th 04 09:11 PM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS MT. DIABLO HIGH SCHOOL PHOTOS Home Built 1 October 13th 03 03:35 AM
High performance homebuilt in the UK NigelPocock Home Built 0 August 18th 03 08:35 PM
