Why no plywood monocoque homebuilts?
Old October 20th 06, 11:47 PM posted to rec.aviation.homebuilt
Default Why no plywood monocoque homebuilts?
Howdy,
After reading a bit about the early Lockheed Vega, the Focker Albatross
DIII and the Dehavilland Mosquito I was a bit suprised that plywood
monocoque construction hasn't been used in any more modern airplanes.
(Or at least none that I can think of) What gives? Is it cheaper to use
glass than wood? Anyone here have any experience with this type of
construction and how it compares to truss style construction?
-Thanks!
-Matt
Old October 21st 06, 12:02 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Howdy,
It is The Falco comes to mind. It is available as a kit here, and as a
production aircraft in Italy. (or it was available in Italy)
Jim in NC
Old October 21st 06, 03:30 AM posted to rec.aviation.homebuilt
On 20 Oct 2006 15:47:10 -0700, "
Howdy,
Jim gave the Falco as an example of a monocoque wood aircraft, but keep in mind
that the three you mentioned are *molded* wood aircraft. Not really efficient,
for a homebuilt, unless you're planning on selling kits.
Old October 21st 06, 08:37 AM posted to rec.aviation.homebuilt
Howdy,
It also depends on what you consider more modern, the last of the
all-wood european sailplanes were in the 70's but the performance had
reached impressive levels. The most common would have to be the Ka6cr
but the K6e was definitely the 15metre machine to have, far superior to
most other 15m gliders of the time. Wood gliders finished for the most
part with the SHK1, the 17m follow-on to the 15m Standard Austria. It
was a plain timber monocoque, but it made good use of glass for
finishing the wings and nose.
There's still a few gliders for homebuilding made with a monocoque
construction, but I think even a simple monocoque is probably just too
much work for a one-off.
Carlo Selman
Old October 21st 06, 06:26 PM posted to rec.aviation.homebuilt
Roger (K8RI)
On Fri, 20 Oct 2006 19:02:20 -0400, "Morgans"
roups.com...
Howdy,
How about the Barracuda?
www.rogerhalstead.com
Old October 21st 06, 06:58 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Does the Barracuda get its strength from its skin, or from a wooden framework
with plywood covering it? I don't know.
Jim in NC
Old October 21st 06, 08:19 PM posted to rec.aviation.homebuilt
Ed Sullivan
As I recall the Barracuda was just a plywood covered conventional
spruce frame.
Old October 21st 06, 09:56 PM posted to rec.aviation.homebuilt
Ed Sullivan
On Sat, 21 Oct 2006 13:58:52 -0400, "Morgans"
Again as I recall the Barracuda has a
Warren Truss Fuselage, that is it has both verticle and diagonal
members. the strength is shared. On the other hand DeHavilland
aircraft frame had only verticle members therefore the skin prevented
the structure from skewing.
Old October 21st 06, 11:19 PM posted to rec.aviation.homebuilt
Roger (K8RI)
On Sat, 21 Oct 2006 20:56:12 GMT, Ed Sullivan
I'm not sure how much strength the skin addes in the Cuda so I passed
this question on the the Barracuda users group. If my memory holds out
I'll bring their answer(s) back.
Old October 23rd 06, 08:06 AM posted to rec.aviation.homebuilt
It is called "complimentary structure". Most GA aircraft have a
structure consisting of a skin (alum or plywood) that carries most of
the load. However, the stringers and longerons have an important
function, that is, they provide out of plane stiffness to the skin,
thereby preventing it from buckling under load. Each element of the
structure has an axis about which it is weak, and it needs the other
elements to provide strength in that direction. They need each other
very much.
Bud
Jim in NC
compound curves in plywood BA-100 Home Built 58 April 13th 05 05:29 AM
cvjetkovic ca-65 skyfly- plywood spar? patrick mitchel Home Built 3 October 16th 04 05:26 PM
Air Conditioning System for Homebuilts? JPAviation Home Built 18 February 6th 04 03:24 AM
Homebuilts by State Ron Wanttaja Home Built 14 October 15th 03 08:30 PM
Substitute for Mahogany plywood Kelvin & Janice Rempel Home Built 1 September 5th 03 08:02 PM
