Dual glide slope, $95...priceless!
Old October 22nd 06, 03:45 AM posted to rec.aviation.owning
Robert M. Gary
Default Dual glide slope, $95...priceless!
Jack Allison wrote:
Robert M. Gary wrote:
The older VOR heads (the ones fed by the KX-170B style, not the KX-155
style) can be relied upon to be 6 degrees off every couple of months.
The one that was off is a newer Garmin, installed along with the GNS430
by the previous owner. While I haven't checked the logs on this, I'd
bet it hasn't been tuned since then. During the first 1.5 years of
ownership, both VORs were never more than +/- one degree.
Interesting, those are normally highly accurate. I also have two
glideslopes. I always tell myself I should set both but almost always
forget. Even when I do set it, I tend to forget to look at the #2.
However, I do take careful note of the FAF altitude as a GS
verification.
-Robert
Can a failed Glide Slope also void the Localizer approach? Jim Carter Instrument Flight Rules 17 August 24th 06 09:01 PM
Glide Slope Antenna Ground Plane JKimmel Home Built 6 August 1st 06 01:28 AM
En route glide slope? Andrew Gideon Piloting 17 November 21st 04 05:49 PM
Effect of airbrake blade height on glide slope Mike Soaring 1 January 30th 04 08:24 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
