Contact approach question
Old January 22nd 05, 02:16 PM
On Sat, 22 Jan 2005 06:11:42 GMT, "Gene Whitt"
MY Bad,
Mixed up two different flights and situations. One was SVFR from
the Spreckles Sugar plant and Monterey with 400' ceiling. whet we went in
SVFR
Other was Contact where we had to change runways to maintain
cloud clearance.
Gene
SVFR with a 400' ceiling? Is that legal?
  #85
Old January 22nd 05, 02:46 PM
Steven P. McNicoll
By itself, yes. But extended flight under a solid 400' ceiling will likely
require a violation of FAR 91.119
  #86
Old January 22nd 05, 03:30 PM
Ron Garret
In article , wrote:
"Steven P. McNicoll" wrote:
Never would have thought of this, but it seems plausible enough, now
that you mention it.
Although there is a regulation that says that the pilot is required to
use a prescribed "instrument letdown" when cleared for an approach,
or something like that.
I wonder, would this be a violation of that?
No. That regulation begins with "Unless otherwise authorized by the
Administrator", and FAR Part 1 defines "Administrator" as "the Federal
Aviation Administrator or any person to whom he has delegated his authority
in the matter concerned."
Where the regulations intend to give ATC authority to provide exceptions, it
states "unless otherwise authorized by ATC."
Where it states "unless otherwise authorized by the Administrator" delegation
has to be affirmed by some policy document or other formal agreement.
In the area of instrument approach procedures the Administrator has formally
delegated the authority to pilots to deviate from the requirements of a Part
95
SIAP:
1. Contact approaches provided the policy conditions and limitations set
forth
are observed.
2. Visual approaches provided the policy conditions and limitations set forth
are observed.
3. Special instrument approach procedures, authorized for an operator by
operations specifications or a letter or agreement.
4. SAAAR Part 95 procedures, such as Category II and III, and soon-to-be
SAAAR
RNP RNAV instrument approach procedures.
Of the foregoing, ATC has the ability to initiate only the visual approach.
I know; you know all of this but others may not.
Yes, but don't forget the situation that started this thread: the tower
is fogged in and calling zero vis. They cannot issue a contact approach
even if one is requested. You cannot land VFR or SVFR. I don't have
time to look it up right now, but it seems highly dubious to me that
they could or would issue a visual approach clearance under such
circumstances.
rg
  #87
Old January 22nd 05, 06:06 PM
wrote in message ...
I'd say it should read "any short-cut without a revised clearance or a
cancellation is a legal no-no."
But, ATC is not authorized to issue an initial or revised clearance to
short-cut any required segment of an instrument approach procedure except
for
radar vectors provided in accordance with 7110.65P, 5-9-1.
If in VMC the pilot can cancel IFR and discontinue the SIAP. If conditions
permit a contact approach the pilot can request one, receive a revised
clearance, and discontinue the SIAP.
Read me previous messages: I said that contacts, visuals, and cancellations
were the only exceptions to a full approach (or 7110.65, 5-9-1 vectors to
final).
  #89
Old January 22nd 05, 06:09 PM
True, provided you cancel, or receive a clearance for a contact or visual
approach. Otherwise you must fly the IAP regardless of how good the
weather
might be (VMC, not VFR).
A visual approach is not an option when an instrument letdown is necessary.
Depends on how you define "when necessary," Steve. The FAA postion is that
"when necessary" is when the pilot is on an IFR flight plan and has not
received a clearance for a visual or contact, regardless of weather
conditions. It's in the AIM that I cited to someone else here.
  #90
Old January 22nd 05, 06:11 PM
On Sat, 22 Jan 2005 02:08:12 -0800,
Paul Tomblin wrote:
In a previous article,
said:
On Mon, 17 Jan 2005 23:45:57 -0700, Newps wrote:
Once a clearance for an approach is issued, the pilot is bound by the
appropriate segments of the approach (Part 97) and the applicable parts of
91.175. Any "short cut" with either a contact, visual, or cancellation is a
legal no-no.
Baloney. Once I'm in a position to fly visually to the airport/runway I
can do just that.
that's not what this says, I don't think:
(a) Instrument approaches to civil airports.
Unless otherwise authorized by the Administrator, when an instrument
letdown to a civil airport is necessary, each person operating an
aircraft, except a military aircraft of the United States, shall use a
standard instrument approach procedure prescribed for the airport in
part 97 of this chapter.
I don't see anything there that prohibits you from cancelling IFR when you
have sufficient visibility and cloud clearance to operate under VFR.
You can cancel when the reported ground visibility and your observed flight
visibility permit. Then, none of 91.175 has any application from that point on.
(you can't cancel in Class A airspace but that has no application to 91.175 in any
case.)
You can cancel any time you are operating in VFR conditions. Ground
visibility may or may not have something to do with that.
If it's reported and you're going to land at that airport served by the IAP, then it's
pertinent. Otherwise, it's not.
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 03:54 AM
GPS approach question Matt Whiting Instrument Flight Rules 8 November 1st 04 10:51 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 04:03 PM
Established on the approach - Checkride question endre Instrument Flight Rules 59 October 6th 03 04:36 PM
