#51
#52
Sure, they are probably built on the same assembly line (but maybe not)
and they meet the same specs (but maybe not), but (FAA bashing aside) how do you know that this particular part is (or is not) as good as an approved part? Define "good". If you mean "value for the dollar" good, well, obviously the FAA-approved GE 4509 is the biggest rip-off on the market. It costs twice as much as the equivalent tractor bulb. If you mean "long life" good, Aviation Consumer magazine just did a comparison, and the 4509 is not even close to being the longest-lasting bulb. In fact, it didn't even make it to its measly 25-hour predicted life. If you mean "brighter" good, well, the two bulbs put out the same lumens. So...how else can we compare the bulbs? What do you mean by "as good"? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#53
#54
"Jay Honeck" wrote in message
oups.com... [...] So...how else can we compare the bulbs? What do you mean by "as good"? One thing *I* would be concerned about with respect to ANY electrical part is whether it will start burning. Now, I admit that I don't know what the certification standards are for an aviation-approved light bulb, but I would hope that at some point along the way it involves various safety standards to ensure that not only will the part work as intended, conforming to the original design of the aircraft, but will also not compromise the safety of the aircraft. If I'm out plowing my field or hauling bales of hay and the lightbulb in my tractor explodes, no big deal. Hopefully it hasn't been a dry season, or I'm not near my parched wheat fields. But in any case, I have a pretty good chance of simply walking away without any trouble at all. It's a bit different when you're airborne and something like that happens. Now, it is true that in some cases an aviation-approved part is manufactured right alongside non-approved parts. But the certification process is applied differently, and you are paying for that. The cost of a part is more than the R&D that went into making it and the cost to manufacture the part, it's even more than those things and a fair retail markup. It also includes all of the FAA-mandated procedures that provide a proveably safe part (and yes, much of that is just paperwork, but that's how it goes when complying with safety regulations). Your tractor-"approved" part has none of the aircraft-related certification applied to it, and so you have no way of knowing whether it does or does not comply with the same safety standards that apply to aircraft-approved parts. I find it amusing that you preach "owners are safer", and even crow about your own dedication to safety, even as it obviously doesn't even occur to you that somewhere along the line in approving a part for aviation use, the FAA actually considers the safety of that part. If an owner has taken it upon themselves to not only have read and understood exactly the certification standards that are applied to aviation-approved parts, but has also done the necessary work to ensure that an otherwise-unapproved part meets those standards, then I would say that owner is still acting illegally if they install that part, but at least they can still lay claim to being safety-minded. However, I doubt you've done all of that, and neither would most of the rest of us. It is far more convenient to let the FAA and the parts suppliers worry about all that, and just pay the higher price for a part. And yes, I agree that the FAA standards are probably not the end-all, be-all when it comes to aircraft safety. But it does define a minimum bar that aircraft are expected to meet, and it seems foolish to me to knowingly ignore even that minimum bar. Pete |
#55
It doesn't really matter, unless you are writing the rules. In your position, you only get to follow them (or not). Let's turn it around a bit. You are thinking of buying an airplane, and you find that the owner has declined to record his maintanance as required by the FAA. This of course has no impact on safety, since it's just paperwork, and the airplane flies just as well without that dumb bureaucrap. Of course the landing light is the tractor bulb, and the stall switches (seven hundred dollars from piper) were replaced with two dollar radio shack switches when they failed. In fact, there are two in parallel, for redundancy. One of the landing gear shocks turns out to be a truck shock which the owner assures you is just as good. The engine is just out of overhaul but the mechanic is at an airport a hundred miles away. No problem - he fires up the plane and you both fly there so you can speak to the mechanic. You fly this leg yourself, as a test flight. He'll fly home (because he's paranoid about the dumb FAA rules about sharing costs, so this makes it ok). While you're at the shotp, he runs into a buddy who has a beer brewing hobby. So this pilot samples a bit of his brew. Just a sip (maybe an ounce of beer). It's not really a problem because you'll be talking to the mechanic for a while, and by the time he gets back at the controls, it will be four full hours, maybe more. The "eight hour bottle to throttle" rule is stupid since it doesn't distinguish between a sip and a couple of glasses. He's got a system where he's figured out a function of how many ounces of beer he can have how many hours before flying - two hours for a sip, four hours for half a glass - eight hours for one drink, twelve hours for two drinks. It's lots more sensible than that hard and fast FAA crap, since the FAA would let you fly eight hours after four drinks if you weren't impaired. The FAA rules are for idiots who can't figure this out. So, you talk to his mechanic and he assures you that the engine is in great shape, and shows you the oil analysis report. It =is= in great shape according to that. Five hours later he gets in the left seat, you get in the right seat, and express some concern about his alcohol thing. "No problem, you can be PIC", but I still have to fly the leg home. It's getting cloudy and the return will be IFR. He's rated. He's current and sharp. That is, he flies an hour on MSFS every day practicing approaches. He has not done the FAA six in six in a real airplane but he's sharper than most pilots who are "current". On the way home the weather turns to crap, he's on top of it despite his little sip of beer, and brings the thing down to minimums on a GPS approach. No airport. The GPS shows he's right above the runway, so he ducks down two hundred feet, finds the strip exactly where he said it would be, flies a tight pattern and greases it in. The DH is pretty high because of a large radio tower, but since he knows where it is, he's comfortable going down another 250 feet if he has to. Eagle flight needs pilots. Would you reccomend him? You want to buy an airplane. Would you buy his? Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
#56
I don't know any other way to say this: Because that FAA rule is
stupid. Anti-authority, anyone? It doesn't matter if the rule is stupid, it's not an excuse for breaking it. Not to be dramatic, but do you think having a DH on an approach is stupid? Comparing silly landing light regulations with life-and-death flight rules does little to further the discussion. But back to the topic: I see plenty of owners dinking around with their planes inside their hangars every weekend, checking this, straightening that, making sure every zip tie and hose is perfect. Quite frankly, pride in ownership is one of the three reasons that I think owning a plane is worth every penny, and I've spent many happy hours in my hangar doing nothing but polishing parts that no one else (but my mechanic and me) will ever see. During this quality time, I've occasionally found little maintenance issues that would otherwise go unnoticed. I've found exhaust pipe clamps loose, drippy hoses, and loose electrical connections while farting around inside the engine compartment, and in each case I have been able to rectify them BEFORE they became a maintenance problem. This is unlikely to happen as a renter. Unlike John Smith's happy situation (where he belongs to a club with 25 rental aircraft that are meticulously maintained) around here the rentals are all either owned by the FBOs, or they're put on "the line" as a lease-back aircraft. Not only would you have difficulty finding a renter pilot who would be willing to take the time to do this type of stuff, but the FBO rules would most likely prohibit it from happening. An example: When I was a renter, Mary and I had a favorite plane, a sweet little Cherokee 140 with a fresh engine. After six months of renting it, the thing was an absolutely cosmetic disaster, with bug guts hardened on to all the leading edges, and topsoil pounded into the carpet on the floor. Knowing what a shoe-string budget the FBO was running on (they weren't about to pay a line boy to clean it), we proposed doing a "plane-washing party", where all the renters would come out and spend an afternoon cleaning that poor old dawg. We even volunteered to provide the beer, and do a cookout (remember, this was in Wisconsin, where beer at the airport is not only okay, it's *expected*), as an incentive to get renters to participate. The idea was met with absolute incredulity from the other renters. Their attitude was, quite simply, "Why would I work to clean someone else's plane?" -- and that was that. There was no pride in the machine -- it was just a tool that they were borrowing from someone else -- period. Saying that this "not my problem" attitude isn't common among renters flies in the face of my personal experience, which isn't to say that there aren't exceptions to the rule. But, again, IMHO most rental birds are "ridden hard and put away wet" -- and there should be some way to quantify this when comparing accidents due to mechanical failure, if only the FAA would track it. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#57
It doesn't really matter, unless you are writing the rules. In your position, you only get to follow them (or not). Let's turn it around a bit. Big Snip of Fun Story I hate to waste such a great narrative, Jose, but your premise is so overblown that I can't even address it. For you to equate my attitude toward using an unapproved (but identical -- maybe even superior) landing light bulb with the attitudes of an IFR pilot drinking and doing an unapproved instrument approach is just goofy, and does nothing to further this discussion. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#58
I find it amusing that you preach "owners are safer", and even crow about your own dedication to safety, even as it obviously doesn't even occur to you that somewhere along the line in approving a part for aviation use, the FAA actually considers the safety of that part. Obviously when it comes to flight safety rules, FAA approval is paramount on a certificated plane. But I wasn't talking about engines or props here, Pete -- I was talking about a *landing light*. Which, again, is pretty far afield from the topic of this thread. IMO, rental planes are ridden hard and put away wet, compared to owner-operated planes, and you would think there would be some way to quantify this by examining accidents that were caused by mechanical problems, if only the FAA/NTSB would ask the question. Of course, in my experience the government is quite good at not asking questions that they don't want answered. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#59
On Sun, 22 Oct 2006 08:32:46 -0700, Xmnushal8y wrote:
Yeah, it's funny, but that *is* the prevailing *assumption* among renters, and the FBOs bank on it. Pilots should be more aware of the regulations than this. But, while I knew that the only difference between rental and owned was the 100 hour, and I also knew that the only difference between the 100 hour and the annual was the IA signature, I didn't - until I became involved in MX myself - know just how much was possible WRT MX that wasn't required. As I mentioned in another posting, oil analysis is a good example of a useful "inspection" tool that's not required. Not knowing about this, one wouldn't know to ask the FBO if it is being done. So I can see how one could easily fall into this mistaken belief. I did. And, for obvious reasons, I don't think we can presume that the FBOs are going to ever get better about teaching this. - Andrew |
#60
overblown that I can't even address it. For you to equate my attitude toward using an unapproved (but identical -- maybe even superior) landing light bulb with the attitudes of an IFR pilot drinking and doing an unapproved instrument approach is just goofy, and does nothing to further this discussion. You see, I disagree with that assessment. And besides, you miss the point. He only drank a little bit. He knows the FAA is too strict on this. He ducked under the minimums only when he knew he was where he was (and was familiar with the terrain and the tower). And there was the whole bit about the unapproved maintanance and the lack of silly paperwork. We all know that the only paperwork that makes an airplane fly is green and has dead presidents and such on it. Who are you to disagree with his assessment of himself, his maintanance, and his attitude? You are in the same position (objectively speaking) as I am, disagreeing with your assessment of yourself, your maintanance, and your attitude. That is, we are each "the other guy" in the scenario. Each of us knows =we're= right, and "the other guy" is messed up. Now, in the scenario I painted, where is the problem? Why is "one sip" (and I specified the amount, it wasn't a "big sip") of beer five hours before a flight not safer than two and a half drinks eight hours before? It probably is, but that's the start down a slippery slope which can easily end in an NTSB report. But so can replacing stall warning switches and landing gear struts with unapproved parts (the homebuilding market notwithstanding). If you have an "approved" airplane, it needs to stay "approved", and that means following the rules. You don't get to decide what they are, not with alcohol, not with aircraft parts, and not with recordkeeping. Cut a corner (and get away with it) anywhere, and more corners will be cut in the future. And if the NTSB report shows that the unapproved part in somebody else's airplane was installed when you were the owner, and an accident results, I may lose my chance at staying at the premier aviation-themed motel in Iowa. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Florida Rentals | Arnold Sten | Piloting | 0 | December 14th 04 02:13 AM |
Wreckage of Privately Owned MiG-17 Found in New Mexico; Pilot Dead | Rusty Barton | Military Aviation | 1 | March 28th 04 10:51 PM |
Deliberate Undercounting of "Coalition" Fatalities | Jeffrey Smidt | Military Aviation | 1 | February 10th 04 07:11 PM |
Rentals in Colorado | PhyrePhox | Piloting | 11 | December 27th 03 03:45 AM |
Rentals at BUR | Dan Katz | Piloting | 0 | July 19th 03 06:38 PM |
