Fortunately, the autogas pump at AWO is usually only about 20c/gallon higher than the price on the street. I hope that'll make the flight school price their autofuel accordingly. Grumman-581 wrote: Of course, that is going to depend upon how much the owner of the flight school is going to sell autogas for... I seem to remember reading in our city's docs for our airport that it was defined that they would sell fuel for $1 per gallon over their actual cost... |
Jay Honeck wrote: Outstanding! Our stupid airport commission and FBO would much rather complain about the stuff (although, in fairness, they're pretty muted about it) instead of jumping on board the band wagon, and installing tanks/pumps. Lord knows they wouldn't want to actually make any money selling fuel... So why don't you buy and install a tank and pump and sell the fuel yourself. Iowa still allows competition don't they? I have a friend who installed a 12,000 gallon tank at an airport near here and directly competes against the full service FBO on the field. Because your field takes FAA funds you are guaranteed to get it approved although the process can be discouraging. |
The ONLY "downside" to this... which is subjective.. is that if the wet
rate is lower because of this, also expect the "reimbursement" rate to reflect HIS cost per gallon of autofuel, and not YOUR cost per gallon of fuel bought away from the field on cross country. Its a matter of being informed ahead of time that you may spend $3-4/gal buying fuel remotely and only get $2-2.50 reimbursed based on this. Dave M wrote: The owner of a flight school at my airport (PAE) told me today that he'll soon install a 1500 gallon fuel tank for 91 octane autofuel, to supply fuel for his STC'ed cherokees and the Stingsport LSA on his flightline (he's a dealer for Stingsport LSA). What a concept! He can save a whole bunch on fuel, offering a better wet rental rate, and I'll have another on-airport autofuel supplier in this area (the other is at the self serve pump at AWO). In case people didn't notice, the price gap between avgas and autogas is no longer $1/gallon. It has grown to something more like $1.30/gallon. |
: So why don't you buy and install a tank and pump and sell the fuel
: yourself. Iowa still allows competition don't they? I have a friend : who installed a 12,000 gallon tank at an airport near here and directly : competes against the full service FBO on the field. Because your field : takes FAA funds you are guaranteed to get it approved although the : process can be discouraging. What exactly are the rules on this? The airport authority here has a rather draconian set of rules WRT "taxes" they impose on other potential FBO's who might want to sell fuel. I suspect the rules are contrary to what the feds say is allowable (but then again, so are a lot of other rules they've imposed as well). -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
"M" wrote in message
ups.com... Fortunately, the autogas pump at AWO is usually only about 20c/gallon higher than the price on the street. I hope that'll make the flight school price their autofuel accordingly. Currently, I have a 55g drum and I fill it up periodically... I *used* to be able to fill it up near the airport, but thanks to the alcohol in the fuel these days, I would have to drive around 30 miles (each way) to get it filled up with *real* gas... That's not really worth it for just 55 gallons... I'm going to pick up a couple more 55g drums so that it would be worthwhile... At around $10 per drum, they pay for themselves after the first fillup as compared to avgas... I recently found a car wash that was throwing away a 30g drum... I need to clean it up on the inside a bit with a pressure washer, but all in all, I suspect that this size might even be more convenient -- at least from a handling standpoint... You gotta be a bit careful with the 55g drums when unloading them from your truck... They weigh about 350 lbs full and you don't want to drop 'em and cause a leak... I figure that I can probably put at least 6 of them in the back of my pickup, but I'm not so sure I want that much weight back there... That's 2100 lbs and that might be a bit much for what is supposedly classified as a 1/2 ton pickup (Dodge QuadCab 1500 4x4)... Filling it with 30g drums would probably be alright from a weight standpoint though... |
Dave S wrote: The ONLY "downside" to this... which is subjective.. is that if the wet rate is lower because of this, also expect the "reimbursement" rate to reflect HIS cost per gallon of autofuel, and not YOUR cost per gallon of fuel bought away from the field on cross country. Its a matter of being informed ahead of time that you may spend $3-4/gal buying fuel remotely and only get $2-2.50 reimbursed based on this. Is that a common practice? where I fly remote fuel reimbursement is what you actually paid. You attach the fuel receipt to your statement and simply deduct it from your bottom line price. I just assumed that's how everyone does it. Of course our on-field FBO is not the cheapest by any means either, so the club usually comes out ahead on remote fueling. |
In rec.aviation.owning xyzzy wrote:
Dave S wrote: The ONLY "downside" to this... which is subjective.. is that if the wet rate is lower because of this, also expect the "reimbursement" rate to reflect HIS cost per gallon of autofuel, and not YOUR cost per gallon of fuel bought away from the field on cross country. Its a matter of being informed ahead of time that you may spend $3-4/gal buying fuel remotely and only get $2-2.50 reimbursed based on this. Is that a common practice? where I fly remote fuel reimbursement is what you actually paid. You attach the fuel receipt to your statement and simply deduct it from your bottom line price. I just assumed that's how everyone does it. Of course our on-field FBO is not the cheapest by any means either, so the club usually comes out ahead on remote fueling. The local renter reimburses actual up to a maximum which is roughly the average local price and usually around a half buck more than the field price for full serve. I once asked why and they replied they were more concerned about someone running out of gas a mile short of the runway and what that would do to the bottom line than they were about the couple of bucks now and then for a pricey fillup. -- Jim Pennino Remove .spam.sux to reply. |
what you actually paid. You attach the fuel receipt to your statement and simply deduct it from your bottom line price. It's probably common club practice (it is in our club - we get reimbursed at the rate at our home base). FBOs tend to reimburse on actual costs. I guess it's simpler accounting and a different pilot set. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
My buddy got the contract
for the college flight school on the field and as such he buys gas often and at full tanker loads so he gets the best price. They probably have $75K invested and the whole deal was paid for in about three years. They are always priced well below the FBO, about 40-50 cents a gallon. That is COOL. One of the flight schools on our field just went belly up. Not much to be made on fuel sales around here, I'm afraid... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| CRS: V-22 Osprey Tilt-Rotor Aircraft | Mike | Naval Aviation | 0 | October 14th 05 09:14 PM |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 05:24 AM |
