"Bob Gardner" wrote:
Same thing applies at many controlled fields. Ask the controller for permission to cross the airport and you will most likely be told to cross midfield at 2500 feet or so...that's the way they do it at Seattle-Tacoma, anyway. Hard to hit a jet when it has its wheels on the runway and you are way up there. Yup, that's what they do around here. Ask to transition LaGuardia, and they'll have you fly directly over the tower at 1500 feet. I've had them do similar at Newark and Kennedy. At White Plains, they'll often give spam cans closed traffic on 29 while running jets on 34; they just ask you to keep your downwind in tight, passing right over the numbers of 34. |
"Roy Smith" wrote in message =
... "Bob Gardner" wrote: Same thing applies at many controlled fields. Ask the controller for=20 permission to cross the airport and you will most likely be told to = cross=20 midfield at 2500 feet or so...that's the way they do it at = Seattle-Tacoma,=20 anyway. Hard to hit a jet when it has its wheels on the runway and = you are=20 way up there. =20 Yup, that's what they do around here. Ask to transition LaGuardia, = and=20 they'll have you fly directly over the tower at 1500 feet. I've had = them=20 do similar at Newark and Kennedy. =20 At White Plains, they'll often give spam cans closed traffic on 29 = while=20 running jets on 34; they just ask you to keep your downwind in tight,=20 passing right over the numbers of 34. Occasionally I fly IFR into Spirit of St. Louis Airport from the east, and it's rare NOT to be vectored squarely across Lambert Field, continuing outward south-westerly until getting further vectors to KSUS. Once, in VMC, I was asked to cross "the building with the big blue = roof"! |
Depends on what the weather is, and if there is VFR traffic. If it is
IFR conditions and no VFR traffic is observed, then circle anyway as you please, while looking out for traffic. If there are other VFR traffic, I don't like either of your options. Too much maneuvering for the first option, and it is best to avoid straight- ins when there is VFR traffic. I would fly slightly west to intercept the extended downwind and merge with the traffic. Alternatively, you could fly south, pass overhead and turn directly downwind. I wouldn't do the descending 225-degree right. Way too much maneuvering near the traffic pattern. You could do this if you go a few miles out, but you are wasting time and fuel on something that could be accomplished quite easily and safely. wrote in news:cfiqv0hgqs3mic8c9hr1cv87rpeiikqji2@ 4ax.com: Consider you're NE of the airfield, non towered airport, runway 18/36, standard left pattern applies, with runway 36 the active. I'm interested in hearing what your personal method of joining the pattern would be, while adhering to the FAR's and AIM. I've two thoughts: Fly south, then west, pass overhead the field, and then 2 or 3 miles later do a descending 225 degree right turn, and join on a 45 degree to downwind, or Stay east and then south of the airport, and join a straight in outside 5 sm. Opinions? Stan |
Bob,
The AC you referenced AC 90-66a says in "7. GENERAL OPERATING PROCEDURES ....E. The FAA encourages pilots to use the standard traffic pattern. However, for those pilots who choose to execute a straight-in approach , maneuvering..." I believe that this clearly indicates that the 45 entry is the standard traffic pattern and that the straight-in is an exception to the standard. Perhaps my 2005 AIM differs from your AIM. The note under 4-3-3 "Examples Key to traffic pattern operations 1. Enter pattern in level flight, abeam the midpoint of the runway, at pattern altitude..." supports the entry we both think is best. In my 2005 AIM 4-3-4 is "Visual Indicators ar Airports Without an Operating Control Tower". 4-3-3 is "Traffic Patterns". I thank you for your reference to AC 90-66a which I have read and since we both agree on the best entry don't see much value in arguing about the justification for that opinion especially since the Original Poster asked for "Opinions." I will, since I respect your opinion, let you have the last word, if you choose, and will read what you have to say and then drop the matter. Daniel What you are missing is that 4-3-2 deals with application of traffic pattern indicators, period. Look at the note near 4-3-1 to see what the writers of the AIM say about traffic pattern entries. Bob "Daniel L. Lieberman" wrote in message ... Bob, Perhaps I am misunderstanding something but Figure 4-3-2 of the 2005 AIM Shows only one entry to the pattern. That is what you suggested. The straight in (his second choice) is probably more dangerous. I would be concerned about the possibility of (if there is an Instrument Approach to 36) someone coming in behind or above me. I will look up the AC you referenced in an attempt to learn more. I know one of the local DPEs might fail the straight in since he says the PTS incorporates the AIM. Daniel "Bob Gardner" wrote in message ... I like your first solution better than the second. Having said that, neither the regs nor the AIM provide much guidance in the situation you describe. Look at Advisory Circular 90-66A for more relevant information. Bob Gardner wrote in message ... Consider you're NE of the airfield, non towered airport, runway 18/36, standard left pattern applies, with runway 36 the active. I'm interested in hearing what your personal method of joining the pattern would be, while adhering to the FAR's and AIM. I've two thoughts: Fly south, then west, pass overhead the field, and then 2 or 3 miles later do a descending 225 degree right turn, and join on a 45 degree to downwind, or Stay east and then south of the airport, and join a straight in outside 5 sm. Opinions? Stan Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
Just wondering how many pilots prefer to just make the simplest entry, minimizing time manoeuvring in the pattern, and perhaps being safer on the whole That is what my last instructor taught me, and what the local FAA Safety Counselor (who's also a CFII) recommends. Extra maneuvering near an airport increases collision risk. Flying all over the county just to achieve the sacred 45 degree downwind entry is silly and dangerous. -- Dan C172RG at BFM |
![]() "Bob Gardner" wrote: Then flying away from the pattern and descending to pattern altitude well away from the pattern is the safest solution to the problem you posed. What's the point of that? That requires more turns at low altitude near an airport, increasing collision exposure. Join the pattern as expeditiously as possible (always following right-of-way rules) and get it on the ground. Crossing midfield at pattern altitude gives a good view of the pattern and the windsock and sets you up for an simple turn to the downwind. -- Dan C172RG at BFM |
#28
![]() "Andrew Sarangan" wrote: Too much maneuvering for the first option, Yup. and it is best to avoid straight- ins when there is VFR traffic. Why? If you're approaching from a direction that is straight in to your runway, what would be safer--flying all over the area to set up for a downwind? -- Dan C172RG at BFM |
#29
... Consider you're NE of the airfield, non towered airport, runway 18/36, standard left pattern applies, with runway 36 the active. I'm interested in hearing what your personal method of joining the pattern would be, while adhering to the FAR's and AIM. I guess you could do an abbreviated version of the overhead join, whereby you descend on the dead side (on the east) and then when you get to circuit height, cross the northern end of the runway, effectively joining the circuit on the crosswind leg. Normally with an overhead join to a left-hand circuit you'd be approaching from the "live" side of the circuit at 2,000 feet or so, but as you're on the dead side already, this doesn't apply. Fly south, then west, pass overhead the field, and then 2 or 3 miles later do a descending 225 degree right turn, and join on a 45 degree to downwind, or Probably not favourable, as you're in the vicinity of traffic in the circuit but as you're in a right turn, you won't have a particularly good view in the direction you're turning (particularly if you have a high-wing aircraft). All you need is for someone to be doing what my instructor used to call "V-bomber circuits" (i.e. not keeping them tight and close in) and you're in a potentially sticky spot. With the crosswind join you're already flying in the direction of the circuit when you start, and the main lookout will be for departing traffic, which until you get to the runway will be forward of your nine o'clock. If you converge onto the downwind from 45 degrees you'll be looking over your left shoulder to try to spot people, which isn't ideal. Stay east and then south of the airport, and join a straight in outside 5 sm. That's probably the nicest way. Actually the absolute nicest way would be to join on a right-hand downwind (we often have both directions working at once at my home field), but in a non-ATC situation you would want to stick with the official way. D. |
#30
![]() "David Cartwright" wrote in message ... All you need is for someone to be doing what my instructor used to call "V-bomber circuits" (i.e. not keeping them tight and close in) and you're in a potentially sticky spot. Was he British? |
joining the traffic pattern quandary | pstanley55@hotmail.com | Instrument Flight Rules | 77 | January 17th 05 05:07 PM |
