Is an IFR flight more or less work?
Old October 29th 06, 08:01 PM posted to rec.aviation.piloting
Mxsmanic
Default Is an IFR flight more or less work?
I think someone here said that you really need a copilot when you fly
IFR. If so, what duties does the copilot have? I'd think that IFR
would be no more work than VFR, especially since ATC is helping with
directions and there is often some degree of automation (autopilot or
something). So, what's the story in real life? Is it really more
work to fly IFR, or more work to fly VFR? I'm thinking that VFR you
must spend a lot of time reading charts and looking for landmarks.
Old October 30th 06, 12:03 AM posted to rec.aviation.piloting
Tony
Many of us who are rated for instrument flight are likely to tell you
real life flying under instrument flight rules is easier than VFRr.
This is especially true in controlled airspace during the approach and
landing phases of flight in congested airspace. In my view, if the
conditions are soft IFR so that the VFR guys are on the ground, very
much easier.
I fly SEL with no co pilot in a Mooney 201 and find the workload very
manageable. It's worth mentioning when I lived in New England about a
quarter of my time was spent in IMC, and after hunderds of hours in the
clouds and on the gauges, so flying by reference to instruments feels
quite natural. Lower time pilots may feel differently.
You might try getting into a real cockpit, much of what you've read
here will become obvious then.
Old October 30th 06, 12:23 AM posted to rec.aviation.piloting
Matt Whiting
much easier.
I agree. I file IFR for virtually every flight these days. One, it is
easier in many cases than VFR. Opening and closing VFR flight plans
requires talking to someone else ... twice. I usually request flight
following when VFR, but sometimes I'm not able to get it in the
northeast. Two, filing all of the time keeps me proficient in copying
clearances and generally using the system.
Matt
Old October 30th 06, 12:58 AM posted to rec.aviation.piloting
Andrew Sarangan[_1_]
Since you are comparing IFR to VFR, I am assuming that conditions are
VMC. If weather is not part of the equation, the answer depends on the
complexity of the airspace you are flying. In complex airspaces, IFR is
simpler than VFR because you don't have to worry about staying out of
anyone's airspace. In less busy areas, VFR is simpler because you don't
have to follow ATC assigned routes, or even talk to anyone.
However, flying in IMC is more demanding than flying in VMC. When you
throw weather into the mixture (icing, imbedded thunderstorm), then
things get a lot more difficult than VMC. That's when having a co-pilot
is an asset.
Also note that VMC does not necessarily mean VFR. The vast majority of
IFR flights take place in VMC.
Old October 30th 06, 01:07 AM posted to rec.aviation.piloting
Transpose mxsmanic and gmail to reach me by e-mail.Since you are comparing IFR to VFR, I am assuming that conditions are
is an asset.
Hello,
first time poster here.
I think it is worth noting that the Mooney 201 and other newer aircraft
usually have two axis autopilots with altitude hold. When other pilots
say " a second pilot is needed", they may be referring to single pilot
IFR without an autopilot, or out there in the sticks without radar
coverage making leg calculations, mandatory reports over fixes with
estimates for the next, all on the old whiz wheel.
I fly single pilot IFR in a C310 sans autopilot, and I welcome the
company when I can get it.:-)
Old October 30th 06, 04:18 AM posted to rec.aviation.piloting
Mxsmanic
Tony writes:
I think it will become clearer with experience, be it in a real
cockpit or in a simulator.
Old October 30th 06, 04:24 AM posted to rec.aviation.piloting
Mxsmanic
Andrew Sarangan writes:
VMC.
Not necessarily, although I see your point. I was thinking mainly in
terms of the cockpit workload for IFR vs. VFR.
I actually find IFR easier than VFR in a simulator, but there are some
key differences between simulation and reality that might keep this
from being fully representative. It's hard to "turn" one's head in a
sim, since the view is mostly out the front of the aircraft, and the
landmarks on the ground below may be less (or sometimes more) clear
than in real life. Whatever the case may be, I find that looking at
instruments seems to require less work than looking out the window,
worrying about other traffic, and so on. A flight in IMC (without any
icing or really rough weather), where the only traffic is IFR, makes
me worry somewhat less about hitting someone.
Once the autopilot or FMC is set up, it seems like it would be mostly
relaxing and sightseeing out the window.
Old October 30th 06, 06:03 PM posted to rec.aviation.piloting
gatt
"Mxsmanic" wrote in message
I think someone here said that you really need a copilot when you fly IFR.
There are many things a second pilot can do to help, starting with:
1) monitoring and transcribing ATC calls and clearances
2) verifying radio frequencies
3) timing approaches as a means of secondary navigation
4) assisting with checklists; particularly in complex or performance
aircraft.
5) providing a second pair of eyes on the panel and outside the airplane.
It is; your attention is generally only focused on the lower half of your
monitor; you don't need to look over the nose, etc as long as you can keep
the needle centered and stay oriented.
-c
CFI without commercial? Jay Honeck Piloting 75 December 8th 10 04:17 PM
FLIGHT SIMULATOR X DELUXE 2006-2007 (SIMULATION) 1DVD,Microsoft Flight Simulator 2004, and Addons, FLITESTAR V8.51 - JEPPESEN, MapInfo StreetPro U.S.A. [11 CDs], Rand McNally StreetFinder & TripMaker Deluxe 2004 [3 CDs], other T.E.L. Simulators 0 October 14th 06 09:08 PM
Thunderstorm - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 11:05 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
