#21
I think if you're going to thread tight areas in an unfamiliar metro
area these days, you'd better have a GPS with airspace depiction. Sure, you may be able to do it via pilotage, but then again you could easily screw up and bust class B (or worse). Sometimes I just file IFR to avoid the hassles. --Dan Grumman-581 wrote: Judah wrote: In the real world, you start out at a known location, and monitor your progress using navigation tools such as pilotage, dead reckoning, etc. You don't simply 'pop' into a largely empty area of a chart. Ahhh, but you can in MSFS... snicker |
![]() "Mxsmanic" wrote in message How in the world are you supposed to know when you are inside or outside one of these areas, There's a dark, dashed line painted on the surface of the earth denoting these areas, making avoidance easy. These lines are not noticeable to those on the surface, but are easily visable from the air. If you'd take the bother to go on a real flight, you would notice this. :-) |
says... Dave Doe writes: You might like to note the differences between IFR charts and plates vs VFR charts (which, if you look, are really maps - topo maps). I've been able to find sectional charts and terminal charts at SkyVector, but where can I find IFR charts? You could check out some arrival and departure plates here... http://www.aip.net.nz/NavWalk.aspx?s...e=Christchurch -- Duncan |
#24
Robert M. Gary writes:
The sectional chart is used with a plotter. The plotter measures distance and can figure direction. I googled for this and found only software. I presume you mean the mechanical arm-like device that I've seen being using with flat charts on tables in movies? Certainly that might be useful, but what about during flight? Chart tables would be awkward in the cockpit (although large aircraft with navigators might have them). -- Transpose mxsmanic and gmail to reach me by e-mail. |
#25
Dave Doe writes:
You could check out some arrival and departure plates here... http://www.aip.net.nz/NavWalk.aspx?s...e=Christchurch AirNav has those. But it sounds like there are other en-route charts for IFR, which I haven't seen. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#26
A Lieberma writes:
Maybe if you took the time to RESEARCH how to read a sectional, you will find all sorts of goodies, such as power lines, lakes, rivers, cities, points of interests that actually correlate with USING YOUR EYES outside the window. I've looked very carefully at sectionals. In the vast majority of cases, there are no clear landmarks indicated that allow one to locate the exact boundary of airspaces. The best one can do is allow a margin of several miles or more, but in crowded areas that may not be sufficient. How do I know if I'm in the southwestern tip of the Turtle MOA on the chart that covers Arizona, for example? There are no landmarks given. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#27
Judah writes:
In the real world, you start out at a known location, and monitor your progress using navigation tools such as pilotage, dead reckoning, etc. You don't simply 'pop' into a largely empty area of a chart. I don't see any difference between the two. The charts have numerous landmarks - lakes, rivers, roads, power lines, cities, racetracks, aqueducts, quarries, bridges, antennas, hills, mountains. Not enough to locate the boundaries of the airspaces. All are very discernable from the air in real life. MSFS does not effectively simulate the real-world view of the ground from the cockpit of a small plane, and that is why you are having so much trouble. No, I'm having trouble because there isn't anything on the chart that allows me to locate airspace boundaries in many cases. The boundaries are not stenciled on the ground outside the window, even in real life. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#28
Dan writes:
I think if you're going to thread tight areas in an unfamiliar metro area these days, you'd better have a GPS with airspace depiction. Sure, you may be able to do it via pilotage, but then again you could easily screw up and bust class B (or worse). I think a GPS is useful in any case--but how do pilots without moving maps and GPS do it? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#29
Wolfgang Schwanke writes:
You ought to know where you are anyway, at least roughly. If you do, you also know when approaching an airspace indicated in the chart. But you don't know when you've cross the boundary in most cases. You can only guess. You can find points that are definitely outside or definitely inside, but you cannot find the boundary itself. That's what navigation is all about. If you don't know where you are at all, you're doing something wrong. It's not a question of not knowing at all, it's a question of knowing with sufficient precision to respect airspace boundaries. In "empty" areas you use a technique called dead reckoning. It's essentially extrapolating from your last known position. Of course this introduces an error, which you should take into account when deciding your safety margins from any obstacle or forbidden airspace. In other words, you still don't know. If you feel uncertain about those blank areas, you can always avoid them. Sometimes the airspaces to avoid are so close together that one cannot avoid them and still complete the flight. No, but they don't have to for that purpose. You deduce your position in the topography relative to visible landmarks without having to be exactly over them, and from there you deduce your position relative to whatever airspace depicted on the map, once again without its boundary having to be exactly on a landmark. That only works if you leave an extremely wide margin for error. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#30
Mxsmanic wrote in
: A Lieberma writes: Maybe if you took the time to RESEARCH how to read a sectional, you will find all sorts of goodies, such as power lines, lakes, rivers, cities, points of interests that actually correlate with USING YOUR EYES outside the window. I've looked very carefully at sectionals. In the vast majority of cases, there are no clear landmarks indicated that allow one to locate the exact boundary of airspaces. The best one can do is allow a margin of several miles or more, but in crowded areas that may not be sufficient. How do I know if I'm in the southwestern tip of the Turtle MOA on the chart that covers Arizona, for example? There are no landmarks given. You would observe the Pinto Mountains intersecting the Sheep Hole Mountains, and know that the edge of the MOA is about halfway between that and the Cadiz Lake... It's pretty distinct, actually, if you know how to read a sectional. |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
chart heads-up | Jose | Instrument Flight Rules | 2 | September 29th 06 07:25 PM |
Sectional Chart Question | Teranews | Piloting | 27 | June 23rd 05 12:14 AM |
WAC Chart Images on line? | Rich | Owning | 5 | March 22nd 04 11:17 PM |
