IFR in the 1930's
Old August 31st 03, 02:18 AM
Mike Beede
In article , Jan Carlsson wrote:
Good reading is the "I could never be so lucky again"
and also "The Spirit of ST Louis" (1953) The last one tells a lot about how
it was to be a mail pilot in the 20's
_The Spirit of St. Louis_ is one of those books all pilots should read
(because they'll probably like them), like _Fate is the Hunter_. If I
recall correctly, Lindberg talks about getting caught over a deck
and letting the plane find its own way down while he walks. I think
*that's* how the mail pilots handled hard IFR. (If it's really in a
different book, it still doesn't change the recommendation to read
it!).
Mike
Old August 31st 03, 03:07 AM
Bill Daniels
"Mike Beede" wrote in message
In article et, Bill
Daniels wrote:
Every figured what you would do if
the wet compass goes TA while you are in the soup and all you have is a
manually set DG? Been there.
Declare an emergency and request a no-gyro approach. If I'm out
of radar coverage, then I guess I'd just start compensating for drift
as though there were wind, even though it's really precession error.
That would get kind of difficult eventually, so I might be tempted to
reset it based on what I thought the winds really were when I appeared
to be tracking a course accurately. It probably wouldn't be any
worse afterwards....
Did you have some suggestions in mind when you asked the
question? If so, I for one would like to hear them.
Regards,
Mike
I declared an emergency and requested a no-gyro approach as you suggested -
even though I had gyros. Then, because I had quite a ways to go to the
first IFR runway, I figured out that the GPS ground track was almost as good
as a wet compass. I just set the DG to the GPS ground track and ignored
wind - which worked as long as I didn't change heading often. That got me
into approach's radar coverage and the no-gyro approach worked from there.
My CFII had told me that there was no backup for a wet compass because "they
never fail" - baloney, the glass cracked and all the fluid ran down the
instrument panel. After that, it wouldn't move. Made me think.
Bill Daniels
Old August 31st 03, 11:00 AM
Paul Mennen
I'll tell you why. The needle only shows a real turn of the nose.
The turn coordinator will bank on you if you rock the wings and the
nose stays pointed straight ahead. So, the turn coordinator gives you
fales information. If you hit a bump and your left wing lifts
momentarily, the turn coordinator will bank right on you when you
aren't turning at all. Hell, in turbulence the son of a bitch is all
over the place and is unusable. The needle works on a gyro that ONLY
makes the needle move if your nose is changing heading just like the
DG.
You can see the problem. The turn coordinator gives you too much
information but it gives the same indication if you bank or if you
stomp a peddle. That's no good. You don't know what really is
happening...it could be either.
Badwater, "you can stuff them damn turn coordinators" Bill
I think you are wrong. The turn coordinator doesn't give you bad
information, just different information.
Consider for a moment what your best response should be if during
straight and level flight you suddenly find yourself in a 30 degree
right bank because of turbulence or any other reason for that matter.
I think you would agree that you should apply left aileron (as well as
left rudder to remain as coordinated as possible) until any turning
and/or banking indications are removed and you are on your proper heading.
This is not that much different from your response if you suddenly find
yourself in a right turn.
Consider also the situation where you are flying partial panel
(i.e. your AI is not working). In response to the 30 degree bank
above, your response with a turn indicator will be nothing since
you won't even know that anything is wrong. Eventually the 30 degree
bank will cause turn and only then will you be able to correct for
it. Assuming you don't over-react to the turn coordinator's indication
you should be able to fly smoother than when using the turn needle
because you can respond sooner. In fact the turn coordinator was invented
because the engineers noticed that their autopilots (connected only to
the rate gyro) flew smoother when the gyro axis was tilted slightly
(and thus causing it to respond somewhat to roll rate in addition to yaw).
While it's true that some pilots fly better with one type of turn indicator
or the other, the difference usually depends on which instrument the
pilot started with or has become most accustomed to. And many pilots
fly just as well using either turn instrument even in turbulence. It often
helps to understand exactly what the needles indicate for the two different
instruments (although surprisingly even that is not always needed).
~Paul
Old August 31st 03, 12:46 PM
Bill Daniels
"Paul Mennen" wrote in message
m...
DG.
indicator
different
~Paul
I have always though of a turn coordinator as a magnificent solution..... to
a non-existent problem.
The purpose of a needle is not only to keep the aircraft upright, it's to
facilitate accurate timed turns to an exact heading. If turbulence bumps
the aircraft to a 30 degree bank but the aircraft does not turn, the ball
will instantly show this by moving toward the low wing. Since the ball does
not over-react, the pilot won't either.
The thing I like most about a needle is that if held exactly on the standard
rate turn "doghouse" timed turns are very accurate - the kind of accuracy
that makes partial panel approaches practical. I've never seen anybody get
that kind of accuracy out of a turn coordinator.
Bill Daniels
Old August 31st 03, 05:49 PM
Big John
Bill
You talk about the 'wet' compass. Used to be called a 'whiskey'
compass because it had whiskey as the damping fluid in it. It also
served as a nerve steadier if you crashed and 'walked away' as you
could open and get a snort while waiting for rescue G
Big John
On Sun, 31 Aug 2003 02:07:34 GMT, "Bill Daniels"
----clip----
Bill Daniels
Old August 31st 03, 07:32 PM
Paul Mennen
to
Do you call designing a smooth flying autopilot a non-existing problem?
True some later autopilots achieve smooth flying by tapping off the
attitude indicator, but I believe this is slightly more complicated.
I'll grant you that if it were not for the autopilot problem we would
all be happily flying around with turn and bank indicators.
If turbulence bumps the aircraft to a 30 degree bank but the aircraft
does not turn, the ball will instantly show this by moving toward the low
wing.
True. For that reason I shouldn't have said that you wouldn't even
know about the 30 degree bank until the turn started. I was thinking
from the autopilot's perspective. (The autopilot is not hooked to the ball.)
Since the ball does not over-react, the pilot won't either.
The turn coordinator does not over-react any more than the ball does.
It merely shows the sum of the yaw and roll rate. In any case the response
by the pilot to an unwanted bank angle whether detected from looking at
an AI, TC, or T&B is the same - enter a smooth coordinated turn in the
opposite direction (usually requiring both aileron and rudder opposite
to the unwanted bank) until the airplane is once again straight and level.
I've seen some pilots (esp. those relying mostly on a T&B) respond to
this situation simply by stomping on the rudder opposite to the direction
of the ball deflection. Perhaps the reasoning is - well since it is only
the ball that is out of whack because of the damn turbulence, I'll counter
the turbulence in the most expeditious manner by an equally jarring jab
on the opposite rudder. This works fine unless you have any passengers.
They will turn green about 3 times faster than if you fly properly.
standard
Bill, you are showing your prejudice. It is entirely practical to do
such approaches with either instrument. On my CFII checkride I did a
fine partial panel approach down to 200 feet using my turn coordinator.
I've seen other pilots do this also.
As far as timed turns, remember that once the turn has stabilized
(constant bank angle) the T&B and TC needles show the same thing.
If you roll out of the turn the same way you roll into it, your timed
turns will be accurate. (This is true using either instrument).
The TC needle will react more to turbulence, but if you react to the
indications smoothly (as I described for straight and level flight)
it will do a good job for you.
I've never seen anybody get that kind of accuracy out of a turn
coordinator.
Bill Daniels
Well I guess you just haven't looked very hard
~Paul
  #28
Old September 1st 03, 05:54 AM
Roger Halstead
On Sat, 30 Aug 2003 19:27:44 -0400, "G.R. Patterson III"
Badwater Bill wrote:
You guys must not remember the "Cat and Duck" method of flying
instruments. Hell, when I was a kid in the 1950's that's all we used.
Hell, the ASPCA won't let us use cats anymore, and good ducks are hard to find.
Been hunted too much, I suppose.
Lordy...I have a cat that loves to play catch...Yah have to remember
to be careful though as he's not been declawed. They are long and
sharp, so if he grabs yah, you know which ever way them fish hooks are
pulling is down.
My biggest problem is he's not afraid of heights and killed the last
two ducks.
Roger Halstead (K8RI EN73 & ARRL Life Member)
www.rogerhalstead.com
N833R World's oldest Debonair? (S# CD-2)
George Patterson
Brute force has an elegance all its own.
  #29
Old September 1st 03, 02:27 PM
In rec.aviation.owning Badwater Bill wrote:
: two, it would be a DG then a horizon. I also hate turn coodinators.
: Pieces of crap. The turn needle is much better.
My limited experience having flown with both (albeit moreso with
the TC than the turn needle), is that the TC is *much* more stable in
turbulence than the stick. Have I just been flying with slow TC and/or
twitchy turn needles?
From what I've seen, keeping the wings level partial panel with
the stick would be almost impossible in turbulence.
Feel free to correct:
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
  #30
Old September 2nd 03, 04:29 AM
Big John
I heard someplace through the years in some hanger flying that a
pencil was used in IFR in the very early days. Can't remember how it
was used but might be something like it was hung from a string in
cockpit???? Maybe some real old, old, old timers remember some to the
stories about the time the AAC was tasked to fly the Airmail?
There's got to be some lurkers older than BOB and me G
Big John
On Fri, 29 Aug 2003 21:15:30 GMT, "Dick" wrote:
Staring at my empty instrument panel while considering which instruments and
their placement, I got wondering how old time Mail pilots flew if caught in
IFR conditions.
On my project plane, I'm considering just a airspeed/altitude/ ball & tube
slip (no needle) indicator/compass setup in order to avoid the venturi or
vacuum pump setup. Since I consider "electric" too expensive and wondered
whether a dome style compass might be the key??
Any thoughts would be appreciated.
Thanks, Dick -Lakeland, Florida
