I am not sure if it is correct technique, but I have learned over many =
years that a slip followed by a skid seems to increase climb rate. The = idea is to alternate between the two maneuvers quickly. If done = properly and at a rapid rate, the result is amazing. GA |
Are you doing this with stick or with rudder? Sounds
like sculling to me. At 13:00 02 November 2006, Robert Gaines wrote: I am not sure if it is correct technique, but I have learned over many = years that a slip followed by a skid seems to increase climb rate. The = idea is to alternate between the two maneuvers quickly. If done = properly and at a rapid rate, the result is amazing. GA |
![]() Robert Gaines wrote: I am not sure if it is correct technique, but I have learned over many = years that a slip followed by a skid seems to increase climb rate. The = idea is to alternate between the two maneuvers quickly. If done = properly and at a rapid rate, the result is amazing. GA Bob, Normally I trust what you post, but I had to check to make sure today isn't April 1. Tim |
You trust Bob Gaines???
TTaylor at cc.usu.edu wrote: Normally I trust what you post, but I had to check to make sure today isn't April 1. Tim |
Bob,
That only works if your ship has a laminar airfoil. I guess that eliminates anything you fly ;-) "Robert Gaines" wrote in message ... I am not sure if it is correct technique, but I have learned over many = years that a slip followed by a skid seems to increase climb rate. The = idea is to alternate between the two maneuvers quickly. If done = properly and at a rapid rate, the result is amazing. GA |
![]() Bob, I fly that uncoordinated, but somehow I still gain altitude, too... Jack Womack |
Jack wrote:
Bob, I fly that uncoordinated, but somehow I still gain altitude, too... Jack Womack On a bad day the string just refuses to lie still. On a good one it hardly ever moves - and the vario makes happy noises. Maybe it is a Schempp-Hirth thing, but my old Cirrus also climbs best with a little bit of string deflection. The geometry would have a tiny two or three degrees slip indicated if you fly perfectly co-ordinated, and it is best with quite a lot more than that. |
Could it be a erroneous information from the instruments?
They are only accurate if you fly straight. As soon as you go sideways, the airspeed indicator, and the VSI, will not longer be "true", since you are adding quite a bit of airflow over the statics vents. To get a static pressure, you must fly straight. "Playing" with your rudders to get a better climb is quite simply....a myth! (And I must add that it is an urban legend that I have been hearing for the last 25 years!) Richard Phoenix, AZ On a bad day the string just refuses to lie still. On a good one it hardly ever moves - and the vario makes happy noises. Maybe it is a Schempp-Hirth thing, but my old Cirrus also climbs best with a little bit of string deflection. The geometry would have a tiny two or three degrees slip indicated if you fly perfectly co-ordinated, and it is best with quite a lot more than that. |
Thermal right, land left | John | Soaring | 195 | April 1st 04 11:43 PM |
