Searching for soaring centres in Europe
Old November 4th 06, 02:37 AM posted to rec.aviation.soaring
Udo
Default Searching for soaring centres in Europe
I will be in Europe for an extended holiday next spring.
I am looking for other centres similar to St.Auban.
I have contacted St.Auban and submitted my resume, but no answer.
Since then I have contacted them several times but no luck.
Also I am in touch with the people that run the British Over Sea's
Nat's in Spain. They do not have a glider I want.
I am open for suggestions in the southern regions in Europe, provided
there are reasonable weather conditions for soaring in May.
If you have any direct experience with a commercial or club operations,
that would rent a gliders
for a week or longer, let me know.
Thanks for any input.
Udo
Old November 4th 06, 05:01 PM posted to rec.aviation.soaring
Ruud[_1_]
It will take some time before you get an answer from CNVV (St Auban).
They normally make a planning for spring during these weeks and I
think you will receive an answer from them by the end of this month.
Ruud.
Udo
Old November 4th 06, 08:04 PM posted to rec.aviation.soaring
Udo
Thanks Ruud,
Still it would be nice if they would acknowledged my inquiry.
Udo
Ruud.
Udo
Old November 4th 06, 09:42 PM posted to rec.aviation.soaring
hans
Hi Udo!
What type of gilder do you want to fly?
What type of soaring do you want to pursue?
In what type of landscape would you like to fly?
Advice given to you after you have answered the questions will be much
more targeted to your needs.
Best Regards
Hans
Udo
Old November 5th 06, 09:34 AM posted to rec.aviation.soaring
Ruud[_1_]
That's the way it goes in "la douce France" ;-)
If you want to be sure that they have received your request, give them
a call.
Success!
On 4 Nov 2006 12:04:44 -0800, "Udo" wrote:
Thanks Ruud,
Udo
Ruud.
Udo
Old November 5th 06, 10:05 AM posted to rec.aviation.soaring
Ruud[_1_]
And....
it's certainly worth to invest a little time and effort to enlist
yourself for one of the "stages perfectionnements" and enjoy views
like these:
http://www.thermiekfotowedstrijd.nl/....php?pos=-5176
http://www.thermiekfotowedstrijd.nl/....php?pos=-5172
http://www.thermiekfotowedstrijd.nl/....php?pos=-4688
On Sun, 05 Nov 2006 10:34:22 +0100, Ruud
a call.
Success!
Thanks Ruud,
Udo
Ruud.
Udo
Old November 5th 06, 10:15 AM posted to rec.aviation.soaring
Ruud[_1_]
And....
like these:
a call.
Success!
Thanks Ruud,
Udo
Ruud.
Udo
Old November 5th 06, 10:52 AM posted to rec.aviation.soaring
hans
Hi Udo!
At many gilder fields in the Alps gilders will be only allowed to be
operated with an operational Flarm. As the use of Flarm by US and
Canadian nationals and residents is not permitted, this excludes lots of
good sites in Europe.
Best Regards
Hans
Udo
Old November 5th 06, 06:30 PM posted to rec.aviation.soaring
Udo
Hi Hans,
are you saying that a rented glider, equipped with a Flarm,
can not be flown by a Canadian pilot?
Udo
hans wrote:
Hi Udo!
Best Regards
Hans
Udo
Old November 5th 06, 07:02 PM posted to rec.aviation.soaring
hans
Hi Udo!
A Canadian or US citizen or permanent resident will fly a gilder in a
legal fashion only, if the Flarm is removed from the glider. But some
glider hirer will allow the removal of the Flarm, because most likely
his hull insurance will not pay, as would my hull insurance if I would
remove the Flarm from my glider. Furthermore a lot of soaring sites
allow take off only with functional Flarm.
The big problem is, that a Canadian or US citizen or permanent resident
can sign no legal binding document that frees the manufacturer from
liability. The document will be binding only for him but not for the
surviving dependents or for the entities that have to support the
surviving dependents.
Hans
Udo schrieb:
Hi Hans,
Udo
hans wrote:
Hi Udo!
Best Regards
Hans
Udo
Cry the beloved continent. European Soaring 0 January 9th 06 03:36 AM
Barometer Setting in Europe question... Piloting 19 April 3rd 05 09:43 PM
Airmen in Europe may go back to three-month rotation schedules Otis Willie Military Aviation 0 August 22nd 03 11:47 PM
Could it happen he The High Cost of Operating in Europe Larry Dighera Piloting 5 July 14th 03 02:34 AM
