Are there any handheld radios that can also be conveniently panel
mounted? I know there was once a Delcom that could, but it does not seem to be available in the USA. Appreciate any info. Thanks, Mike |
Hi Mike,
Not that I'm aware of. However, the Vertex Standard VXA-150 has a near feature that may make it panel mountable. the LCD display screen in mounted at a 45 degree angle on the top/front of the unit. It can be inverted so you could mount the radio in a homemade tray in the panel and you would be able to read the display from the end and slightly above the unit. You can see details he http://www.soarmn.com/cumulus/vertex.htm You may also want to check out my handheld and panel mounted radio comparisons. http://www.soarmn.com/cumulus/radios-handheld.htm http://www.soarmn.com/cumulus/radios-panel.htm In the long run, a panel mounted radio will give you much better ease of use and low maintenance which may make it less expensive in the long run. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Mike" wrote in message ups.com... Are there any handheld radios that can also be conveniently panel mounted? I know there was once a Delcom that could, but it does not seem to be available in the USA. Appreciate any info. Thanks, Mike |
| Thread Tools | |
| Display Modes | |
| FOR SALE - 15 Delcom AIR960 Radios and Accessories | ContestID67 | Soaring | 2 | April 11th 06 01:31 AM |
| FOR SALE - 15 Delcom AIR960 Radios and Accessories | ContestID67 | Home Built | 2 | March 6th 06 07:35 PM |
| I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 06:39 PM |
| TKM radios | Peter Gottlieb | Piloting | 5 | August 15th 03 03:44 PM |
