Here we go again
Old November 5th 06, 01:14 PM posted to rec.aviation.homebuilt
TigerPilot
Default Here we go again
I saw this advertised on ebay
http://cgi.ebay.com/ebaymotors/Mini-...QQcmdZViewItem
and couldn't help thinking about BWB. I guess it's time to rehash the
subject and maybe warn an unsuspecting buyer.
Old November 5th 06, 06:29 PM posted to rec.aviation.homebuilt
Morgans[_2_]
"TigerPilot" wrote in message
The thing is, how are you going to warn a bidder? They would have to check
here, and that is unlikely.
Notice they said that they did not have the mast support. That gives me a warm
and fuzzy feeling. Not!
Jim in NC
Old November 5th 06, 08:11 PM posted to rec.aviation.homebuilt
Roger (K8RI)
On Sun, 5 Nov 2006 13:29:25 -0500, "Morgans"
roups.com...
Note the Location. He's probably seen it.
Ahhh...That thing is actually over 5,000# empty and over 8,000 gross
with a useful load of almost 2 tons? That's what the add says.:-))
Yup. Just what I wanted.
www.rogerhalstead.com
Old November 5th 06, 09:45 PM posted to rec.aviation.homebuilt
jladd
It doesn't say that Roger, but I still doubt you would want it
Old November 6th 06, 12:24 AM posted to rec.aviation.homebuilt
Roger (K8RI)
That what the e-bay add says when I bring it up on my computer.
And no I don't want it. A nice turbine powered 4 passenger one would
be nice, but I couldn't afford the insurance let alone the chopper.
Old November 6th 06, 02:10 AM posted to rec.aviation.homebuilt
John Ammeter
Roger,
Look carefully at the figures again...
I don't recall the exact numbers right now but they're something like
550lbs.. Looks like 5501 pounds at first glance but really 550 lbs...
John
Old November 6th 06, 07:59 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On Sun, 05 Nov 2006 18:10:55 -0800, John Ammeter
Roger,
It should be and that's what I expected but I could find no decimal.
Old November 6th 06, 05:28 PM posted to rec.aviation.homebuilt
Bob Kuykendall
Earlier, Roger (K8RI) wrote:
...It should be and that's what I expected
I don't think it needs a decimal - the values are whole numbers.
If you go to the eBay page, the text says:
gross weight 870lbs
empty weight 515lbs
useful load 355lbs
Yeah, that looks a bit confusing with no space between the value (870)
and the units (lbs).
But if you drag the text onto the clipboard, paste it into MS Word, and
then apply the All Caps format (Format Fonts Fonts tab Effects
area), it says:
GROSS WEIGHT 870LBS
EMPTY WEIGHT 515LBS
USEFUL LOAD 355LBS
So that thing that looks like a one in the ones column of a four digit
number is actually a lower-case L in the unit specifier lbs.
So, it's not clear formatting; in fact I consider it to be particularly
unclear. But it definitely isn't specifying four-digit values for the
weights and load.
Thanks, Bob K.
Old November 7th 06, 02:42 AM posted to rec.aviation.homebuilt
John Ousterhout[_2_]
Some of us "greater than standard FAA pilot weight" folks appreciate
that useful load :-)
As it happens I have a bit of experience with a Mini-500. Here are a
couple photos.
Preparing for a Mini-500 flight.
http://ousterhout.net/gallery/Mini-500_preflight.jpg
An assessment of the Mini-500's flight characteristics.
http://ousterhout.net/gallery/Mini-5...ght_review.jpg
- J.O.-
Old November 7th 06, 04:48 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On 6 Nov 2006 09:28:02 -0800, "Bob Kuykendall"
gross weight 870lbs
empty weight 515lbs
useful load 355lbs
area), it says:
GROSS WEIGHT 870LBS
EMPTY WEIGHT 515LBS
USEFUL LOAD 355LBS
Ur right. Even after having it pointed out I still couldn't see it
until I copied it out and spaced the lbs one to the right.
weights and load.
Thanks, Bob K.
