#21
Helicopter, military definition: A mass of fatigued metal, rotating around
an oil leak. bumper "Roger" wrote in message oups.com... Ever try flying a helicopter? I truly have not had the fun meter pegged as far to the right by anything else, including gliders! Imagine lanidng on a rock in a river as that is the only landing spot and stopping for a skinny dip : ) On Oct 31, 1:34 pm, "fcnorton" wrote: Hi Victor, Power Pilot since Dec-1976 (ASEL/Ins) Glider Pilot since May-2006 VERY Happy 304CZ Owner since July-2006 Nothing has ever pegged my "fun meter" like soaring. It is honestly the most challenging flying that I have ever done....and the most rewarding. IMHO: Get your glider license first and then power - I believe you will be a better over all pilot. Just my 2 cents. FC Norton wrote: Hi all, I decided to take the plunge (no pun intended) and start flying. I thought about going straight for a private glider license. But, I do have the option of going for the powered pilot license first - then the glider license second. Any thoughts? How many here have both? Did you get your powered pilot license first? cheers, Victor |
Roger wrote:
Ever try flying a helicopter? I truly have not had the fun meter pegged as far to the right by anything else, including gliders! Imagine lanidng on a rock in a river as that is the only landing spot and stopping for a skinny dip : ) Definitely a entertaining and challenging experience! Enjoyed the heck out of my first lesson, but at almost $400 an hour for an R-22, it's damn expensive. That's 16 tows per hour. |
#24
Gary Emerson schrieb:
Definitely a entertaining and challenging experience! Enjoyed the heck out of my first lesson, but at almost $400 an hour for an R-22, it's damn expensive. That's 16 tows per hour. Regarding cost, there's a simple equation: One year of soaring equals one day in a power plane equals one hour in a helicopter. |
#25
Roger wrote:
Ever try flying a helicopter? I truly have not had the fun meter pegged as far to the right by anything else, including gliders! Imagine lanidng on a rock in a river as that is the only landing spot and stopping for a skinny dip : ) I'm told the most appropriate use for a helicopter is scouting out remote landing places for a glider, and retrieving a glider when it uses one of those remote fields. That requires a larger, more expensive one than the one used for field scouting, as it must safely lift a loaded trailer. I do know of a couple glider pilots that also own a helicopter. Not a common combination. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#26
![]() Victor, I hope this discussion helps, but fear its heavily weighted towards getting the glider rating first, then the powered rating. All I can share is my experience, do with it as please. I would encourage you to pick either avenue, flying is the most satisfying activity I do. My experience: I am a glider pilot with my powered add ons. Commercial Glider, Commercial SE Land, ATP ME Land, Instrument Airplane, CFI, CFII, CFIG - 1900 hours (200 in gliders.) I started flying gliders the summer after high school, then added my powered ratings in college. I fly for a career - so I am a little more willing to spend the money to gain hours and experience. Couple of things I learned along the way: 1. The glider first, followed by the powered rating means you'll have to take two FAA written exams - that's an extra $75-$100 depending on the testing center. Second - although you piloting skills will be better, you will still probably spend the minimum 40 hrs in a powered airplane to get the rating - you probaby won't see the benefit of the glider experience translate to lowered costs for the powered. I fly powered aircraft for my career, and I use GA airplanes to travel across the country. I fly 200+ hours a year, mostly all powered. I am finnally able to afford a sailplane of my own and am shopping for one right now. I plan to fly more gliders in the coming years, contests and XC, but I will still fly powered airplanes as an instructor, professional pilot, and to travel. I think one aspect that has been overlooked is ths soaring season. Your are at the end of it, which means lots of sled rides with very little opportunity to SOAR! That's the biggest factor in hooking pilots to gliders - the 1, 2, 3 hour soaring flights that are possible May through September in most of the country. That being said, night arrives sooner and this can limit the amount of time available for the powered training. But, I beleive that the powered flying will progress more quickly than the glider flying, unless you fly at a commercial glider operation that runs year round. Don't forget to find an instructor that fits your personality and can adapt to your learning style. That relationship is the single most important to completing your ratings, no matter which you choose first. Good luck and Happy Landings, Andrew |
#27
My suggestion if you have a soaring operation close by that will allow
you to fly reasonably often with reasonable expense then do the glider 1st. If you have to travel or availabity or cost are issues then I would recommend at least going up to Solo in a power airplane. You can learn a lot a lot of basics of a flying in a few hours of power instruction and power instruction is typically easier to locate and schedule. If you can find one, find an instructor that teaches both glider and power (rather hard to find I suspect). At the very least let your instructor know what you are planning, they can help taylor your instuction to your goals. Having the skills to solo a power airplane will greatly accelerate your progress in the glider. However if the glider/instructor/towplane and tow pilots are all readly available and reasonably priced then go glider only. Brian CFIIG/ASEL HP16T Boise, ID |
#28
![]() "COLIN LAMB" wrote in message .net... ...... One problem with a power plane rating is that the glider club will try to suck you into being a tow pilot. They say that tow pilot is the only usefull power pilot, others just spoil fuel. |
#29
When I took my practical test for Private Pilot Glider, the FAA examiner
said "I wish they would teach everyone to fly gliders before power. You learn so much more about energy management in gliders." Roger " wrote in message oups.com... Hi all, I decided to take the plunge (no pun intended) and start flying. I thought about going straight for a private glider license. But, I do have the option of going for the powered pilot license first - then the glider license second. Any thoughts? How many here have both? Did you get your powered pilot license first? cheers, Victor |
#30
All that stuff you learned flying RC will help you learn to fly the
"full-scale". In some ways it's easier, because of the immediate feedback of feeling what the aircraft is doing. Plus you don't have to reverse your thinking when you fly back toward the field. ;-) " wrote in message ups.com... Hey guys thanks a bunch for the comments and your experiences! Really appreciated. I'm going to call up the Puget Sound Soaring Association to see if they are flying this weekend. Assuming it doesn't rain! they operate at Bergseth Airfield in Enumclaw, WA. Only about an hour from Seattle where I'm at. I used to fly scale RC sailplanes decades ago. Had a Glasflugel 604 with a 12ft wingspan, custom winglets, flaps and modified airfoil cross section. Time to do it for real. Victor |
Sports Pilot Television Expands Market Coverage | AJ | Piloting | 0 | April 10th 06 11:17 PM |
Canadian PPL transition to USA | Jase Vanover | Piloting | 3 | November 27th 05 01:44 AM |
Thunderstorm - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 11:05 PM |
