AD Search?
Old November 6th 06, 01:47 PM posted to rec.aviation.owning
Roy Smith
Default AD Search?
What's the best way to search for all the ADs applicable to an airplane?
Old November 6th 06, 03:05 PM posted to rec.aviation.owning
Jim Burns[_1_]
Default AD Search?
Use the FAA's site.
First start with the airframe (make, model, & serial number) Print them
all. READ them thoroughly to insure that your plane is either included or
excluded.
Then do the same for the engine, engine accessories, avionics, ect.
After you've done that, use one of the commercial online services that will
sell you a one time search & report. Use this to cross check your own
research. You may find that they pick up some that you didn't and you may
find that you pick up some that they didn't.
Make an index listing each AD number, a description, and if it's recurring
or a single event.
Now go through the log books of the airframe and power plants. Make a list
of every AD and Service Bulletin mentioned, the book, and page number where
it was recorded in the logbook. In many cases if a SB has been complied
with it may qualify as compliance with a later AD.
When you're done, keep all the records in a 3 ring binder for reference.
This is the method that I used to research the airplane I flew for my CFI
and II. It made that part of the checkride last all of 5 seconds each time.
It's also the method that I used when shopping for our Aztec, I keep the
binder for the plane we purchased up to date to present it to our A&P-IA
during our annual.
Old November 6th 06, 09:59 PM posted to rec.aviation.owning
Robert M. Gary
Default AD Search?
To my knowledge the only way to search for all the AD's that apply to
you is to pay the $2000 for the CD or borrow one from an IA. The FAA
has listings but I don't believe you can search based on your serial
numbers. It might take you a year to search the FAA's way. I think that
is on purpose.
-Robert
Old November 6th 06, 10:04 PM posted to rec.aviation.owning
Jim Burns[_1_]
Default AD Search?
You're right, you can't search by serial number on the FAA site.... you have
to print out each AD and then read it to see if your serial number is
applicable. Lots of time, effort, and ink required.
is on purpose.
-Robert
62526 Mining the Web: Jacobian Matrix Constructs with eigenVectorSearching 62526 Web Science Home Built 0 November 16th 04 10:01 PM
20385 Mining the Web :Searches with Kriging, Inverse DistanceWeighting, eigenVectors and Cross-Pollination 20385 Web Science Owning 0 November 16th 04 10:01 PM
Was this a spite search? Anon Piloting 21 May 25th 04 11:17 PM
Search for missing pilot suspended C J Campbell Piloting 2 March 11th 04 02:22 AM
Search for missing plane C J Campbell Piloting 2 March 4th 04 01:42 AM
