angle of approach or landing range question
Old November 6th 06, 07:58 PM posted to rec.aviation.piloting
Tim923
Default angle of approach or landing range question
I don't have an aviation background. What is the typical angle of
landing/approach for commercial airliners? There's an illusion for
novices, and it seems like the angle is much greater, even 30 degrees
or more, but I remember hearing it is much less, like under 10. At
what angle would the passengers complain of a rough landing.
Old November 6th 06, 08:04 PM posted to rec.aviation.piloting
rod
It is typically 3 to 3.5 degrees.
Rod
"Tim923" wrote in message
Old November 6th 06, 08:06 PM posted to rec.aviation.piloting
Tauno Voipio
Unless the terrain or noise considerations require otherwise,
the standard approach glide angle is 3 degrees (about 1 to 20).
Tauno Voipio
tauno voipio (at) iki fi
Old November 6th 06, 08:12 PM posted to rec.aviation.piloting
Orval Fairbairn
They follow a three degree glideslope to landing. They do, however,
flare for landing, which raises the deck angle at touchdown.
Old November 6th 06, 09:01 PM posted to rec.aviation.piloting
Dudley Henriques
"Orval Fairbairn" wrote in message
news
Hi Orval;
My airliner experience is somewhat limited to say the least. I did put a
stretch DC8 down once as a "guest of the line", but that's about it :-))
Although the glide slope angle is correct, the deck angle for a normal
approach should be somewhat higher than the 3 degree glide slope and will be
related to angle of attack on the wing, which for an airliner should be a
function of the GW, airspeed, and configuration for the approach.
In a fighter like the Viper for example, on approach, the Hud will show a
difference between the FPM (flight path marker....the extension of the
velocity vector or where the airplane is actually going) and the GC (gun
cross.....the actual line through the airplane's nose or longitidudinal
axis.)
The difference between these two indicators is the AOA on the wing. Normal
approach AOA for the Viper is on speed between 12.75 and 13.25 degrees. You
fly the approach at 13 max. For an airliner using GW and a computed airspeed
for that GW on approach, I would be looking for the deck angle to be
somewhat higher and stabilized above that 3 degree glide slope.
Dudley
Old November 6th 06, 09:48 PM posted to rec.aviation.piloting
Robert M. Gary
Are you asking about the angle of decent? That's about 3 degrees.
Or are you asking about the deck angle (how high the nose is).
The quality of the landing has nothing to do with it because the plane
"flares" i.e. levels off to some degree before touching down. The angle
the for the last 2 feet is probably something like 0.5 degrees although
only an autopilot programmer would really know. Pilots don't flare by
measing angle of decent at touch down.
-Robert
Old November 6th 06, 10:02 PM posted to rec.aviation.piloting
Dudley Henriques
Pilots don't flare by easing angle of descent at touch down.
Hi Gary;
I'm sure you know this and don't need me to mention it, but just for a
slight addition to your comment can I respectfully add a caveat?
I've always found that you have to be REAL careful with this area. It works
somewhat in the general aviation scenario when getting into the
idiocyncrices of the "flare" so to speak, but after that, a general
statement on landing can cause some confusion as pilots move up to higher
performance airplanes.
The problem is that easing rate of descent is EXACTLY how you land both
airliners and high performance jets, especially aircraft with long fuselage
to wing mass ratios and airplanes where tail strikes are an issue at
touchdown.
Dudley Henriques
Old November 6th 06, 10:03 PM posted to rec.aviation.piloting
Darkwing
....and occasionally they don't flare at all!
Oops, we must be on the ground.
DW
Old November 6th 06, 11:09 PM posted to rec.aviation.piloting
Robert M. Gary
Hi Gary;
touchdown.
Sorry, I probably could have worded that better. What I meant to say is
that pilots aren't going to know that angle, in terms of degrees at
flare. That's not how we land, we don't pull back while watching some
soft of indicator of approach slope. Only an autopilot programmer would
know that.
-Robert
Old November 6th 06, 11:18 PM posted to rec.aviation.piloting
Dudley Henriques
Hi Gary;
works
fuselage
touchdown.
know that.
-Robert
That's the way I would approach it as well. I'll check with my wife and find
out if both of us are right :-)))
Dudley
Check this Approach & Landing out! nmg175 Naval Aviation 5 September 27th 06 02:07 AM
Wow - heard on the air... (long) Nathan Young Piloting 68 July 25th 05 06:51 PM
Cuban Missle Crisis - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 09:14 PM
