http://ntsb.gov/Pressrel/2006/061103.htm
UPDATE ON CIRRUS PLANE CRASH IN MANHATTAN, NEW YORK -------------------------------------------------------------------------------- The National Transportation Safety Board today released the following update on its investigation into the accident involving a Cirrus Design SR-20 N929CD that crashed into an apartment building while maneuvering above Manhattan, New York on October 11, 2006. The accident occurred about 2:42 pm eastern daylight time. The airplane was destroyed by impact forces and a post crash fire. The certificated private pilot owner of the airplane, New York Yankees pitcher Cory Lidle, and a certified flight instructor were fatally injured. Marginal Visual Flight rules conditions prevailed, and no flight plan was filed for the flight that departed Teterboro Airport (TEB), Teterboro, New Jersey. The personal sightseeing flight was conducted under the provisions of 14 Code of Federal Regulations Part 91. There were 1 severe and 2 minor injuries on the ground. The Safety Board go-team was composed of four teams: Airworthiness, Powerplants, Operations, and Witnesses. The Weather, Air Traffic Control and Aircraft Performance group chairmen gathered data from NTSB headquarters. Parties to the investigation are Cirrus Design, Federal Aviation Administration, Teledyne Continental Motors, and Ballistic Recovery System. The on-scene examination of the wreckage has shown that there was no sign of an in-flight fire or damage to the airplane. The airplane impacted the 30th floor of the apartment building, bounced off, then fell to the street below, where it came to rest inverted and was engulfed in a severe post crash fire. The engine was ejected from the airplane and entered the building through an apartment window on the 30th floor. The New York Central Park Automated Observation System reported that at the time of the accident, that the winds were from 060 degrees at 6 knots, visibility at 7 statute miles, ceiling overcast at 1800 feet above ground level, the temperature was 17 degrees Celsius, the dewpoint was 13 degrees Celsius and the altimeter was 29.90 inches of Mercury (Hg). No visibility restrictions were reported at any of the surrounding airport weather stations. An aircraft that was landing at Newark Liberty International Airport (KEWR) at the time of the accident was equipped with a weather reporting capability that indicated that the winds at 700 feet altitude were from 095 degrees at 13 knots. Over fifty witnesses to the accident were identified and many interview summaries were obtained from the New York Police Department. Eleven of those witnesses saw the airplane before it impacted the building. Radar data indicate that the airplane was flying over the east side of Roosevelt Island prior to initiating a 180 degree turn. At this location, there would have been a maximum of 2100 feet clearance from buildings, if the full width of the river had been used. However, from the airplane's mid-river position over Roosevelt Island, the available turning width was only 1700 feet. The prevailing wind from the east would have caused the airplane to drift 400 feet toward the building during the turn, reducing the available turning width to about 1300 feet. At an airspeed of 97 knots, this turn would have required a constant bank angle of 53 degrees and a loading of 1.7 Gs on the airplane. If the initial portion of the turn was not this aggressive, a sufficiently greater bank angle would have been needed as the turn progressed, which would have placed the airplane dangerously close to an aerodynamic stall. Since the accident, The FAA issued a Notice to Airman prohibiting fixed wing aircraft such as the accident flight from operating in the East River Class B Exclusion area where the accident occurred unless authorized and controlled by ATC. This will prevent pilots from encountering a situation in which they must attempt a complete u turn in order to avoid entry into controlled airspace. Maintenance records for the accident airplane indicated that all Airworthiness Directives and Service Bulletins had been complied with. The propeller and engine have been examined by Safety Board investigators at their respective manufacturers and they indicated that they were operating normally. Additional work continues in the investigation. Two damaged portable GPS units were recovered from the wreckage and sent to the manufacturer to try to recover additional data. The memory chip associated with the airplane's Multifunctional Display was retrieved and sent to NTSB headquarters to try to recover any stored data. A damaged laptop computer that was found in the wreckage and may contain flight log information, is being examined at NTSB headquarters. Several cockpit instruments are being examined in the Safety Board laboratories, and work is underway to enhance a video obtained from the Coast Guard that shows the airplane's impact with the building. A graphic depicting radar tracks from several local radar facilities may be found at the following link on the Board's website: http://ntsb.gov/Pressrel/2006/N929CD...rn_3radars.pdf Media Contact: Keith Holloway, 202-314-6100 |
I think there is a lesson here for all of us pilots. When in close
quarters, consider the wind. Even better allow DOUBLE (or some other amount you are comfortable with) the turning room for a 180 degree turn around. Also, go out and practice a "minimum radius turnaround" (hint, generally the slower you go the smaller the radius, the steeper you go the smaller the radius etc). We learn a chandelle in commercial manuevers, which is not really a minimum radius turnaround. I wonder if the FAA would consider modifying the chandelle to BECOME a minimum radius turnaround manuever? At any rate, try and learn from these pilots mistakes. I know I have been in some tight mountain canyons and not really considered the effects of the wind as I probably should have. I just looked and there was room so I executed the turn. So far I have been served well by my eyes and distant estimates, but perhaps I should allow a little more room for error if there is any signifigant tailwind during the turn. |
![]() "Larry Dighera" wrote in message ... http://ntsb.gov/Pressrel/2006/061103.htm UPDATE ON CIRRUS PLANE CRASH IN MANHATTAN, NEW YORK Has there been an update on the Comair crash that I missed? Anyone heard the status of the copilot? |
![]() "Steven P. McNicoll" wrote in message ink.net... "Larry Dighera" wrote in message ... http://ntsb.gov/Pressrel/2006/061103.htm UPDATE ON CIRRUS PLANE CRASH IN MANHATTAN, NEW YORK Has there been an update on the Comair crash that I missed? Anyone heard the status of the copilot? Nothing other than he is being sued. COMAIR FIRST OFFICER NAMED IN CRASH SUIT (http://www.avweb.com/eletter/archive...ll.html#193638) First Officer James Polehinke, the lone survivor of the Comair Flight 5191 crash, is among those named in a lawsuit filed on behalf of the family of a Florida man who died in the crash. In a news release, lawyer Stephen Marks, who has won a number of multimillion-dollar settlements in airplane crash suits, said he tried to keep Polehinke out of the case directly but he was unable to come to terms with his insurance company. The suit also names Comair, and Marks says it's clear that the pilot and airline are to blame. "Comair has acknowledged publicly that its pilots were using an outdated airport map in an attempt to make excuses for departing from the wrong runway," he said. "Therefore, both the airline and its pilots are clearly responsible for this tragedy despite what we are sure will be efforts by their insurer and lawyers to blame others." |
The real cause was he was an idiotic and inept pilot that day who
left his wife without a husband and kids fatherless. Ron Lee |
Ron Lee wrote:
The real cause was he was an idiotic and inept pilot that day who left his wife without a husband and kids fatherless. Ron Lee Don't hold back, tell us how you really feel. |
Ron Lee wrote:
The real cause was he was an idiotic and inept pilot that day who left his wife without a husband and kids fatherless. Jesus Christ! There but for the grace of God go many of us. You were never a newby? -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
See:
http://www.unionlabel.org/docs/S-O_06-LabelLetter.pdf mike "Ron Lee" wrote in message ... The real cause was he was an idiotic and inept pilot that day who left his wife without a husband and kids fatherless. Ron Lee |
Doug wrote:
I think there is a lesson here for all of us pilots. When in close quarters, consider the wind. Even better allow DOUBLE (or some other amount you are comfortable with) the turning room for a 180 degree turn around. Also, go out and practice a "minimum radius turnaround" (hint, generally the slower you go the smaller the radius, the steeper you go the smaller the radius etc). We learn a chandelle in commercial manuevers, which is not really a minimum radius turnaround. I wonder if the FAA would consider modifying the chandelle to BECOME a minimum radius turnaround manuever? At any rate, try and learn from these pilots mistakes. I know I have been in some tight mountain canyons and not really considered the effects of the wind as I probably should have. I just looked and there was room so I executed the turn. So far I have been served well by my eyes and distant estimates, but perhaps I should allow a little more room for error if there is any signifigant tailwind during the turn. The nice thing about a chandelle in this circumstance is the altitude that it would have gained them. Matt |
Ron Lee wrote:
The real cause was he was an idiotic and inept pilot that day who left his wife without a husband and kids fatherless. Fortunately, being an idiotic and inept usenet poster is more forgiving... Matt |
Lidle crash: who is wrong? | Blasto | Piloting | 57 | October 20th 06 08:05 AM |
VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 6th 06 11:13 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Four Winds 192 Crash into the Miami Federal Reserve Building, a year ago today | Billgran | Home Built | 3 | December 6th 03 03:22 PM |
