#21
"Bob Noel" wrote in message
... The "negative" g's would probably bother people way more. Very good point... When the drinks start coming out of the glasses and floating towards the ceilings, people are going to notice... I suspect that accelerations will be such that it won't interfere with drinking... |
"Jose" wrote in message
t... I don't usually fly in the tail of a commercial airliner. However, some time ago I had that opportunity, and was quite surprised at the horizontal components I was feeling during taxi on the ground. I was also amused, as it was in the opposite direction of the turn. Be that as it may, I don't see how that's relevant to the question at hand. I doubt the horizontal acceleration was even close to 1g, and on top of that most people are already accustomed to horizontal accelerations, since motor vehicles cause those any time they turn. I'm not a fast driver, and I still quite often turn quickly enough to cause packages loose in the trunk to slide from one side to the other. Not that it takes a LOT of force to do that, but it probably takes at least as much force as you experience in the tail of the airplane. One more time though: even though I believe that the acceleration would be significant, I doubt people will put up much of a fight. Pete |
Here's a little update:
------------------------------------------------------------------- AVwebFlash Volume 12, Number 45b -- November 9, 2006 ------------------------------------------------------------------- "SILENT AIRCRAFT" DEBUTS LOUDLY (http://www.avweb.com/eletter/archive...ll.html#193664) Plans for a quiet, energy-efficient airliner that could be flying in less than 25 years were unveiled Monday afternoon (http://www.cambridge-mit.org/cgi-bin...495&NewsID=368) by researchers from Cambridge University and the Massachusetts Institute of Technology (MIT). The design uses technology that should be ready to fly by 2030. Besides reducing noise around airports, the airplane would require about 25 percent less fuel. It would use a flying-wing design, eliminate flaps and slats, simplify the landing gear, improve its aerodynamics and mount the engines above the fuselage to screen the noise from the ground. Variable-size jet nozzles would allow for slower jet propulsion during takeoff and climb for low noise, and would be optimized for maximum efficiency during cruise. http://www.avweb.com/eletter/archive...ll.html#193664 |
#24
Only anecdotally. A more serious problem may be the slight oscillations that an ariplane goes through staying level. At the edges, they may become strong enough over a five hour flight to induce seasickness. Or not. Dunno. But better to think of it before placing the order. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
#25
![]() "Jose" wrote in message m... Be that as it may, I don't see how that's relevant to the question at hand. Only anecdotally. A more serious problem may be the slight oscillations that an ariplane goes through staying level. At the edges, they may become strong enough over a five hour flight to induce seasickness. Or not. Dunno. But better to think of it before placing the order. The original YB program had a problem with oscillations, making it a problem for bombing runs. The B-2 has that problem licked, with super fast fly by wire flight controls. I can not see any reason that they would not be able to solve any passenger comfort issues, with the correct subroutines applied to the flight control computers. I look forward to a new type of aircraft. If it is destine to come, I wish they would get more serious about starting some scaled down aircraft testing program. If Boeing is really serious about kicking Airbus' butt, that would be the way to start looking. There is no way to find out, short of starting the first steps. -- Jim in NC |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
