#61
Ron Lee writes:
Not sure what he can help on since I understand GPS quite well. If you think you can use GPS safely for altitude in aviation, you need to understand it better. I also fly in mountainous terrain which I doubt that he does. In that case, you need to understand GPS better very soon. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#62
You CLEARLY don't understand GPS at all!
Karl "Ron Lee" wrote in message ... "karl gruber" wrote: "Ron Lee" wrote in message ... Stefan wrote: The only use for GPS altitude in aviation is to calculate the final glide of a glider. (Or an IFR approach, but I don't know enough about IFR flight to comment this.) Most of what you said is correct except this one. My belief is that GPS altitude is fine for terrain separation. But not for aircraft separation which you correctly state is based upon pressure altitude. Ron Lee Your belief is wrong. Could be DEAD wrong. Read MX's posts...........he can give you an education on this subject. Not sure what he can help on since I understand GPS quite well. I also fly in mountainous terrain which I doubt that he does. Ron Lee |
#63
new_CFI writes:
Unfortunatly you dont die in a sim. Why is that unfortunate? That's one of the advantages to simulation. Indeed, when you clip a mountaintop east of Telluride because you trusted the GPS altitude in your simulator, you learn a valuable lesson that may keep you from getting killed in real life. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#64
Mxsmanic wrote: new_CFI writes: Unfortunatly you dont die in a sim. Why is that unfortunate? That's one of the advantages to simulation. Indeed, when you clip a mountaintop east of Telluride because you trusted the GPS altitude in your simulator, you learn a valuable lesson that may keep you from getting killed in real life. One of the advantages of masturbation is that you can't get AIDS from it. That hardly makes it a complete substitute for a real person of the opposite gender. |
#65
Roy Smith writes:
One of the advantages of masturbation is that you can't get AIDS from it. That hardly makes it a complete substitute for a real person of the opposite gender. In surveys I've seen, many people have said that they masturbate precisely because it doesn't carry the risk of STDs that sexual intercourse has. And supposedly masturbation produces more intense orgasms than intercourse as well. While these parallels are not completely relevant to flight simulation, they do illustrate why simulation is sometimes preferable to reality. Certainly this is the case when it comes to dire emergencies and accidents--whence the popularity of simulators in flight training. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#66
Nope. Knew that.
mike "Mxsmanic" wrote in message ... mike regish writes: Dang. I actually learned something from this post. You've also learned about GPS. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#67
"BT" wrote:
he's flying a friggin sim.. This forum is open to everyone, clued and clueless, sane and insane, so it's impossible to tell by the absurdity of a post whether it is being posted in jest or is sincerely believed by the poster. Hence my question. "Jim Logajan" wrote in message .. . "BT" wrote: you land every 100 miles or less reset your altimeter to field elevation and then fly another 100 miles I presume you're trying to pull his leg? |
#68
"Jim Macklin" wrote in message
... they give altitude, accurate to within a few feet. just set the altimeter to read the same. then you know adjusted pressure. considering the legal requirements, it is perfectly adequate. First of all, no they don't give altitude accurate to within a few feet. Secondly, they give a completely different kind of altitude measurement than the altimeter provides. Even if the GPS were accurate to within feet for altitude, setting your altimeter to the GPS displayed altitude would not be the same as having the current, local altimeter setting. Pete |
#69
My regular altimeter broke, and while it was being fixed I flew using
the altimeter in my IFR GPS -- which is coupled to the altimeter in my transponder--and which BTW has an adjustment for barometer reading. I am not sure exactly how it works, I think it uses both GPS and the transponder altimeter reading. It was King KLN90B and a King transponder, if that matters. |
#70
On Sun, 12 Nov 2006 06:43:31 -0500, mike regish wrote:
I think we can judge 1000' from the air better than somebody on the ground because we spend a lot of time in the pattern at 1000' agl. We gt used to the perspective and can verify it with our altimeters. Plus, there is also the issue of we have more to took at to get a reference on... People on the ground are trying to judge distance by looking at a single object that is relatively rather small... Nothing to really compare it to... On the other hand, if we are above water with no surrounding terrain or boats, I would suspect that we might have a bit more difficulty judging altitude... |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
(sorta OT) Free Ham Radio Course | RST Engineering | Piloting | 43 | January 24th 05 08:05 PM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
