KAS 297B Altitude Preselect question
Old November 12th 06, 08:48 PM posted to rec.aviation.owning
No Spam
Default KAS 297B Altitude Preselect question
I tried on rec.av.IFR and got no response, so I thought I'd try here.
Anybody know what it takes to adjust the alert volume on the King KAS 297B
unit? The volume is killing my ears.
TIA,
- Don
Farming looks mighty easy when your plow is a pencil and you are
a thousand miles from the corn field. - Dwight D. Eisenhower
Old November 14th 06, 04:38 AM posted to rec.aviation.owning
DR
The sheet I looked said that unit gives 2V p-p into 500 ohms. No wonder
it is loud. Can you add a resistor or a potentiometer into the signal
line? If you use a pot, get a 500 ohm potentiometer (log response would
be best type) across the output and ground and wire the wiper so as to
make it the new output line -i.e. as a regular volume control. If you
can only fit an inline resistor into the signal line, try several values
from say 100 ohm up until you get a suitable (still loud) volume.
Disclaimer: Such a modification is entirely at your own risk and I make
no recommendation whatsoever as to the suitability of this mod. for
inflight use.
Cheers MC
TIA,
- Don
Old November 24th 06, 04:53 AM posted to rec.aviation.owning
No Spam
Thanks, MC. I was hoping there was a screw on the box somewhere.
- Don
Everything is funny as long as it is happening to somebody else.
- Will Rogers
inflight use.
Cheers MC
TIA,
- Don
Metric Instruments Roy Bourgeois Soaring 29 May 27th 13 01:53 PM
why is intercept altitude labeled "LOC only"? Gary Drescher Instrument Flight Rules 32 September 23rd 06 09:00 PM
