#161
"Travis Marlatte" wrote:
Regardless, in this case GPS derived altitude was quite good. Ron Lee One of the challenges with GPS fixes (both horizontal and vertical) is that there is a statistical distribution of the error. Most receivers advertise being within 15' laterally, 90% of the time. It's that other 10% that you gotta worry about. Surveyors improve their accuracy by leaving the GPS receiver stationary to get a statistical sampling that can reveal the true position. Travis Correct point Travis but since I fly VFR I use other references to develop a "blended" solution. Plus my primary GPS receiver has integrity to catch the really bad errors (rare). Ron Lee |
#162
WE all need to review, perhaps that is the best thing about
these newsgroups. "Travis Marlatte" wrote in message m... | "Jim Macklin" wrote in message | ... | The word SHALL has a legal meaning... | (1) On a magnetic course of zero degrees through 179 | degrees, any odd thousand foot MSL altitude +500 feet (such | as 3,500, 5,500, or 7,500); or | | You got me. I'll confess. I forgot that those were actually regulations. I | fly them. I just forgot they were regs. | | ------------------------------- | Travis | Lake N3094P | PWK | | |
#163
Mxsmanic wrote:
Since it is possible to fly without voice radio equipment, and given that (if I understand correctly) pilots are supposed to have their altimeters set correctly to a reference located not more than 100 miles from their position, how does an aircraft without a radio keep its altimeter properly set as it travels? The aircraft gives not a **** if its altimeter is accurate and is incapable of adjustment if it did. ----- - gpsman |
#164
Travis Marlatte schrieb:
The discussion was about the life-saving necessity of an accurate altitude instrument. Sorry to nitpick, but the discussion was about how to set the altimeter if you can't get the lastest pressure data with the radio. Some guy proposed to use the GPS altitude as reference, and then some (other?) guy stated that you better always fly on GPS altitudes, because it's more accurate anyway. This was the point when I jumped in and said no, don't do this. Only then: MX was claiming that GPS is inaccurate enough to kill you. Actually, it can. It's accurate within a few meters (depending on how "enhanced" it is), but only in some 95% or so of the time and in some 90% or so places (the correct numbers don't matter). Which means that if you happen to be in the wrong place at the wrong time, believing in the GPS can actually kill you, at least theoretically. Of course I'm rather looking out of the window when I fly in VMC, so this isn't an issue in real life for me. Stefan |
#165
Travis Marlatte writes:
Excuse me? The DoD didn't build all of the GPS receivers out there either. I wasn't talking about the receivers. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#166
Recently, Mxsmanic posted:
Travis Marlatte writes: Excuse me? The DoD didn't build all of the GPS receivers out there either. I wasn't talking about the receivers. You certainly were, given that your claim was that their altitude reporting was dangerously inaccurate. No other component in the system reports a particular altitude. Please try to keep up with your side of a discussion. Neil |
#167
Stefan wrote:
Actually, it can. It's accurate within a few meters (depending on how "enhanced" it is), but only in some 95% or so of the time and in some 90% or so places (the correct numbers don't matter). Which means that if you happen to be in the wrong place at the wrong time, believing in the GPS can actually kill you, at least theoretically. Stefan Actually the 95% number often associated with an accuracy is a confidence. It is not an availability value. Thus under the identical conditions 95 times out of a hundred you would be at that accuracy or better. No value of the other 5% is given and may not be very much worse. At least in this case not enough to be life-threatening. Of course if VFR use your eyes and look outside. Ron Lee |
#168
No one has mentioned using the manifold pressure guage as an altimeter.
#169
![]() Mxsmanic wrote: DR writes: What do you think the WAAS is "augmenting"? If it were part of GPS, it couldn't augment itself. QED. You can wriggle but you haven't answered my question. It's not QED. If you can't think about it let me help you. The WAAS is NOT a positioning system is it? What does it *actually* augment? Cheers |
#170
![]() Ron Lee wrote: DR wrote: On my 12 channel boat GPS I see a HDOP of ~1m these days. HDOP is unitless. Good point. I'm sorry that I was being so loose. But you could descibe the 1 sigma dilutuion of precision in terms of distance at your position and time -right? I was actually amazed to see that my Ryatheon GPS put my boat right in the center of the correct dock -implying 2m accuracy (or better)! Cheers MC |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
(sorta OT) Free Ham Radio Course | RST Engineering | Piloting | 43 | January 24th 05 08:05 PM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
