Garmin 530 WAAS?
Old November 15th 06, 02:34 AM posted to rec.aviation.ifr
Mike Adams[_2_]
Default Garmin 530 WAAS?
Ron Rosenfeld wrote:
That may be. But that article links to a Garmin document, which
states in part,
"...The Service Bulletin and SAIB notifications will not prevent the
pilot from flying GPS approaches including LNAV/VNAV and LPV
procedures..."
My point exactly.
  #32
Old November 17th 06, 07:43 AM posted to rec.aviation.ifr
scott moore
Al G wrote:
Thanks to the certification and AML STC approval, owners of Garmin's popular
GNS 400/500 series panel-mount avionics will be able to upgrade their
products to meet the FAA's WAAS standards* without a field approval**. These
upgrades include 5 Hz position updates, faster map redraws, fully coupled
and guided procedure turns and holding patterns, and increased XM weather
content. Pilots will also experience significantly enhanced functionality
because of the WAAS LPV, LNAV/VNAV, LNAV+V, and LNAV approach capabilities.
Coupled procedure turns and holds? Why is WAAS an enabling factor for
that?
Thats pretty interesting. Go missed and hold. I'll just take a little
break :-)
Scott Moore
  #33
Old November 17th 06, 07:06 PM posted to rec.aviation.ifr
Sam Spade
scott moore wrote:
popular GNS 400/500 series panel-mount avionics will be able to
upgrade their products to meet the FAA's WAAS standards* without a
field approval**. These upgrades include 5 Hz position updates, faster
map redraws, fully coupled and guided procedure turns and holding
patterns, and increased XM weather content. Pilots will also
experience significantly enhanced functionality because of the WAAS
that?
I don't read where he said WAAS is the enabling factor for track-guided
procedure turns or holding patterns.
  #34
Old November 17th 06, 07:38 PM posted to rec.aviation.ifr
Stan Prevost[_1_]
How are they going to provide outbound guidance in a hold, and make proper
allowance for wind, while allowing a standard rate turn to inbound?
"Sam Spade" wrote in message
scott moore wrote:
popular GNS 400/500 series panel-mount avionics will be able to upgrade
their products to meet the FAA's WAAS standards* without a field
approval**. These upgrades include 5 Hz position updates, faster map
redraws, fully coupled and guided procedure turns and holding patterns,
and increased XM weather content. Pilots will also experience
significantly enhanced functionality because of the WAAS LPV, LNAV/VNAV,
that?
  #35
Old November 17th 06, 08:30 PM posted to rec.aviation.ifr
Jose[_1_]
With ordinary approach certified GPS.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
  #36
Old November 17th 06, 10:23 PM posted to rec.aviation.ifr
Sam Spade
I don't have any idea how they plan to do it. The previous posting is
the first I've heard of it.
I do know that the high-end stuff had done track-guidance holding
patterns for years, but there is no direct relationship to FAA patterns.
But, no one has ever picked the nit about the differences.
  #37
Old November 18th 06, 01:06 AM posted to rec.aviation.ifr
Stan Prevost[_1_]
"Jose" wrote in message
om...
proper allowance for wind, while allowing a standard rate turn to
inbound?
So how does ordinary approach certified GPS do it? None of those I have
used do it.
  #38
Old November 18th 06, 02:10 AM posted to rec.aviation.ifr
Mike Adams[_2_]
om...
inbound?
used do it.
The 430/530 didn't provide hold guidance prior to the upgrade. The point he was trying to make is that
this feature is part of the same upgrade package, but not specifically related to WAAS. As Sam said, the
big-boy FMSs have provided hold and procedure turn guidance for years, using just VOR/DME or
DME/DME position updating.
Mike
  #39
Old November 18th 06, 04:15 AM posted to rec.aviation.ifr
Stan Prevost[_1_]
"Mike Adams" wrote in message
om...
inbound?
used do it.
Mike
But my question is how do they do it? The desired track in a hold is not
the pretty little racetrack pattern with two parallel sides and two
semicircles at each end, except in a no-wind situation. The desired track
on the outbound leg is that which will put you in a position from which a
standard rate turn will roll you out on the inbound track That is why we
fly outbound with a multiple of the inbound wind correction.. The GPS box
cannot do that without knowledge of the wind. A fancy FMS which determines
the wind correction from the autopilot can do that, but how can a standalone
GPS box, WAAS or not, do that?
  #40
Old November 18th 06, 05:17 AM posted to rec.aviation.ifr
Jose[_1_]
I don't know how they do it. (and true, the 430 doesn't alter the hold
track for wind, though it does for airspeed). There's no reason it
couldn't though - WAAS has nothing to do with it. As long as you know
heading, airspeed, groundspeed, and track, the rest is just math.
Jose
WAAS up with Garmin? Lakeview Bill Products 0 August 30th 06 12:30 AM
Garmin 430/530 WAAS upgrade reminder Nov 15 Paul kgyy Instrument Flight Rules 18 November 22nd 05 07:22 PM
Garmin GNS430 & WAAS Roy Page Owning 33 April 7th 05 04:02 AM
WAAS and Garmin 430/530 DoodyButch Owning 23 October 13th 03 04:06 AM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 01:43 PM
