![]() "Ron Natalie" wrote in message m... The nominal diameter is 4.3 NM (5 SM). There may be extensions either as class D or class E surface area that accomodate the instrumetn approaches. They're centered on the airport reference point. There is no nominal diameter for Class D or E surface areas. The standard is 3.5 NM plus the distance from the Airport Reference Point to the end of the outermost runway. |
Christopher Brian Colohan writes:
North of Boston you will find a large white-ground circle outlined by a thick cyan dashed line. Looks like the one around Washington. I think it means that one of the President's friends lives somewhere near there, so all aircraft for dozens of miles around are prohibited so as not to disturb the royals. -- Transpose mxsmanic and gmail to reach me by e-mail. |
I've assumed that the reason for doing this is to identify areas in which you can expect to find IFR planes. I would guess that you don't want to have IFR planes going through areas too low or far away from antennas to have radio communications with ATC. (Could someone correct me if my guess is wrong?) Isn't IFR allowed in both Class E and Class G? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Dashed cyan is actually class E surface area.
Not cyan. Rather, class E is depicted by that horrible purply color the FAA erroniously calls "magenta". What they print on the chart is not magenta by any stretch of the imagination. Magenta is beautiful; you can see magenta in the deluxe Crayola crayon box. The FAA color should be called "FAA feh". Cyan is more like a deep blue. Real cyan is also beautiful. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Bob Noel writes:
In article , Christopher Brian Colohan wrote: North of Boston you will find a large white-ground circle outlined by a thick cyan dashed line. Not anymore (look at the 74th edition of the NY sectional) Heh. Don't have that one yet. :-) The meaning of white ground or a thick cyan dashed line is not defined in the chart legend, nor is it defined in the book you point at. Any guess what this is? (And why the FAA thinks it is worth putting on the chart, but not worth documenting what it means?) On the 73rd edition of the NY sectional there is indeed a note that P-67 is expanded by special notam. I found the note, but only figured out what it was associated with _after_ someone explained the dashed circle to me. I guess I find it puzzling that there are symbols used on the map which don't appear in any legend... (Especially when just adding them to the legend with a description like "heavy cyan dashed line == TFR outline" would clear everything up.) Chris |
Mxsmanic,
It's just hard to figure out whether I'm inside or outside the boundaries without a radius and center point. You're going at this the wrong way. In flight, what you do is simply look at the chart, find some ground features close to the border line of the airspace, look out the window, find the same ground features - and presto, you know where you are in relation to the airspace. For IFR flight, airspace doesn't matter much, since the controller will do everything necessary for you. Also, many circular airspaces are centered around a VOR-DME, so there's another help. Figuring the radius (which is normally standardized for certain types of airspace) is pretty easy, since the scale of a sectional is the same every time and you have a ruler. The logic for class E lower limits is in IFR traffic being in it. Class E means higher visibility requirements for VFR, so they can separate themselves from IFR traffic. You may recall the thread in which we tried VERY HARD to make you understand that concept. If you still haven't grasped it, it's no surprise you don't understand the logic of Class E lower limits. What comes round... -- Thomas Borchert (EDDH) |
Mxsmanic,
Isn't IFR allowed in both Class E and Class G? Yes, but along an airway or and approach, IFR traffic is much more likely. -- Thomas Borchert (EDDH) |
Christopher Brian Colohan wrote: North of Boston you will find a large white-ground circle outlined by a thick cyan dashed line. Not anymore (look at the 74th edition of the NY sectional) Heh. Don't have that one yet. :-) I literally got it from the club a few hours earlier as he unpacked the boxes. :-) -- Bob Noel Looking for a sig the lawyers will hate |
The meaning of white ground or a thick cyan dashed line is not defined in the chart legend, nor is it defined in the book you point at. Any guess what this is? (And why the FAA thinks it is worth putting on the chart, but not worth documenting what it means?) Correct. NACO finally adopted that to mean special flight restricted airspace. The other big use fo it is the FRZ in Washington and P-40 (Camp David) in DC. Are we talking about the one over Bush the First's place in Kennebunkport? |
![]() I've assumed that the reason for doing this is to identify areas in which you can expect to find IFR planes. I would guess that you don't want to have IFR planes going through areas too low or far away from antennas to have radio communications with ATC. (Could someone correct me if my guess is wrong?) Not where you can expect to find IFR planes, but where you can expect NOT to find VFR planes if the weather is below minimums. |
