I'm mildly curious as to what pathway lightning might follow through my
carbon and glass fibre glider (not curious enough to experiment however). Like Micki, I also believe the story. Ray Warshaw 1LK Vehicles are quite often struck by lightning and the damage varies from nothing at all to (most often) damage to electrical and electronic components, occasionally blown tires and (rarely) broken glass. Lightning injuries inside vehicles are rare, but have been reported. Damage to gliders depends on the current magnitude and duration of the strike. Many gliders have survived weak cloud flashes with little physical damage - I have personally examined two. The larger currents of ground flashes can be more exciting as the arcs inside the glider structure cause a large pressure pulse that can split a wing or blow off the canopy. A severe positive ground flash blew a glider apart in Britain a few years ago. You may get a few warning signs when approaching an electrified cloud. My Discus 2 produces small sparks from the release handle to my left leg! Definitely a sign that you should fly somewhere else! Mike |
Mike the Strike wrote:
A severe positive ground flash blew a glider apart in Britain a few years ago. That was a K-21. The strike entered at one aileron push rod and traveled to the other aileron push-rod, where it exited, through the spanwise alloy push-rods and control linkage. Ohmic heating in the control linkage produced a strong enough pressure pulse to cut the fuselage in half and to blow out both canopies. The skins were blown off both wings as well. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Ray Roberts wrote:
So wasn't it Ben Franklin that invented the fix for this problem, the lightning rod, connected to earth ground? I've often wondered why home insurance companies don't insist on having them installed on each house they insure. And no, my house doesn't have them either. Well over 95% of all trees struck by lightning do not leave an indication. If lightning is rarely so destructive, then why install lightning rods? Of course, older homes already had a sort of lightning rod - a cast iron sewer vent pipe. But more often struck are higher earthing conductors - AC electric wires on telephone poles. If an earth ground wire on utility poles is intact, then that is often a better (electrically shorter) path to earth. Using that paragraph, then one living in a newer home with plastic pipes and underground utilities wires may consider Franklin lightning rods (not to be confused with ESE devices). A more common path to earth through a house is incoming on AC electric wires (think of those wires as a large antenna network connected directly to each household appliance). Few who suffer appliance damage file insurance claims. Either a surge is harmlessly earthed where utility wires enter a building, or lightning finds a destructive path to earth via appliances. Most commonly damaged are appliances that connect to telephone lines because telco routinely earths a 'whole house' protector for every subscriber - installed for free. Incoming on AC electric. Through modem, portable telephone base station, or fax machine. Outgoing to earth ground via telephone line. Many instead assume this is a surge that enters via phone line. Fine. But then what was an outgoing path to earth? No outgoing path means no electricity - no damage. Why did the transient not take a shorter earthing path via a telco 'installed for free' protector? There is no stopping or blocking of lightning as plug-in protector manufacturers hope you believe. Lightning damage is made irrelevant by installing a so inexpensive and properly sized 'whole house' protector on AC mains where that wire enters the building AND earthed to same electrode used by telephone and cable TV. Effective protectors are found in Lowes, Home Depot, and electrical supply houses using responsible brand names such as Intermatic, Siemens, Cutler-Hammer, Leviton, Square D, and GE. Effective protector for a typically most destructive lightning path costs about $1 per protected appliance. That protector also does not stop or absorb anything. A protector is only as effective as its earth ground. Effective protectors make a short and temporary connection to earth. Cable TV does not need a protector since cable is earthed directly by hardwire. We still build homes as we did when transistors did not exist pre-1970. Most essential component of a protector system is earth ground. Best protected homes have lightning protection installed when footing are pour - halo or Ufer grounding. This because all lightnting protection (Franklin rods, 'whole house' protector) is only as effective as the earthing. However even upgrading household earthing to meet and exceed post 1990 National Electrical Code requirements will provide massive improvements. So again, why is this protection not routinely installed? Many believe a plug-in protector will somehow stop or absorb what 3 miles of sky could not. Number of claims submitted to insurance companies remains low. We still don't require effective lightning protection that has been made essential since 1970. Lightning striking a house via the roof is rare. Lightning directly striking household appliances is more common - typically once every seven years. A number that varies significantly even within neighborhoods. A problem made irrelevant if each incoming utility wire in each cable is earthed before it can enter the building. Effective protector earths each incoming wire so that lightning need not damage household appliance. How effective is your protection system? Protection begins with quality of a single point earth ground. |
![]() w_tom wrote: Ray Roberts wrote: Most commonly damaged are appliances that connect to telephone lines because telco routinely earths a 'whole house' protector for every subscriber - installed for free. Incoming on AC electric. Through modem, portable telephone base station, or fax machine. Outgoing to earth ground via telephone line. Many instead assume this is a surge that enters via phone line. Fine. But then what was an outgoing path to earth? No outgoing path means no electricity - no damage. Why did the transient not take a shorter earthing path via a telco 'installed for free' protector? Current flows in a complete circuit--direction is arbitrary and irrelevant. What actually happens in many cases of applicance damage is not voltage surges, it's ground potential difference. If your power, telephone, cable TV and water services do not enter at the same point and have common grounding, they can have different "gound" potentials relative to each other. Even if lightning does not strike your house directly, it disturbs the ground potential for a large area. This is why telephones, televisions and refrigerators with ice makers are often damaged--they are connected to two different systems. |
I was working on my computer when my neighbors house got struck - 100 feet
away. The strike went through the roof hiting the upstairs copper water pipes which set the house on fire. My neighbors were at home watching TV and reported that a fireball danced around the living room for a few seconds. Fortunately, all the pinholes blasted into the water pipes put the fire out within a minute but the total insured damage was still in excess of $50,000. My lights dimmed for a second but the computer never blinked. I use a good UPS. Bill Daniels "Doug Haluza" wrote in message ups.com... w_tom wrote: Ray Roberts wrote: Most commonly damaged are appliances that connect to telephone lines because telco routinely earths a 'whole house' protector for every subscriber - installed for free. Incoming on AC electric. Through modem, portable telephone base station, or fax machine. Outgoing to earth ground via telephone line. Many instead assume this is a surge that enters via phone line. Fine. But then what was an outgoing path to earth? No outgoing path means no electricity - no damage. Why did the transient not take a shorter earthing path via a telco 'installed for free' protector? Current flows in a complete circuit--direction is arbitrary and irrelevant. What actually happens in many cases of applicance damage is not voltage surges, it's ground potential difference. If your power, telephone, cable TV and water services do not enter at the same point and have common grounding, they can have different "gound" potentials relative to each other. Even if lightning does not strike your house directly, it disturbs the ground potential for a large area. This is why telephones, televisions and refrigerators with ice makers are often damaged--they are connected to two different systems. |
Doug Haluza wrote:
Current flows in a complete circuit--direction is arbitrary and irrelevant. What actually happens in many cases of applicance damage is not voltage surges, it's ground potential difference. If your power, telephone, cable TV and water services do not enter at the same point and have common grounding, they can have different "gound" potentials relative to each other. Even if lightning does not strike your house directly, it disturbs the ground potential for a large area. This is why telephones, televisions and refrigerators with ice makers are often damaged--they are connected to two different systems. If the surge protector has a cable or phone jack connector in addition to the AC sockets, would that protect the TV or telephone? -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Martin Gregorie wrote:
Mike the Strike wrote: A severe positive ground flash blew a glider apart in Britain a few years ago. That was a K-21. The strike entered at one aileron push rod and traveled to the other aileron push-rod, where it exited, through the spanwise alloy push-rods and control linkage. Ohmic heating in the control linkage produced a strong enough pressure pulse to cut the fuselage in half and to blow out both canopies. The skins were blown off both wings as well. Did the pilots report noticing any sparks, tingling, or other "electrification" before the strike? I've had lightning strike within a mile of my glider without noticing any signs of it, before or after. -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
You must mean the ASK21 GBP which was destroyed near the London Gliding
Club, Dunstable on 17th April 1999. The AAIB report may be found at http://www.aaib.gov.uk/cms_resources...pdf_500699.pdf . The pictures and other illustrations do not appear to be available, though I have them, downloaded when the report was first published. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Mike the Strike" wrote in message oups.com... I'm mildly curious as to what pathway lightning might follow through my carbon and glass fibre glider (not curious enough to experiment however). Like Micki, I also believe the story. Ray Warshaw 1LK Vehicles are quite often struck by lightning and the damage varies from nothing at all to (most often) damage to electrical and electronic components, occasionally blown tires and (rarely) broken glass. Lightning injuries inside vehicles are rare, but have been reported. Damage to gliders depends on the current magnitude and duration of the strike. Many gliders have survived weak cloud flashes with little physical damage - I have personally examined two. The larger currents of ground flashes can be more exciting as the arcs inside the glider structure cause a large pressure pulse that can split a wing or blow off the canopy. A severe positive ground flash blew a glider apart in Britain a few years ago. You may get a few warning signs when approaching an electrified cloud. My Discus 2 produces small sparks from the release handle to my left leg! Definitely a sign that you should fly somewhere else! Mike |
![]() Eric Greenwell wrote: Doug Haluza wrote: Current flows in a complete circuit--direction is arbitrary and irrelevant. What actually happens in many cases of applicance damage is not voltage surges, it's ground potential difference. If your power, telephone, cable TV and water services do not enter at the same point and have common grounding, they can have different "gound" potentials relative to each other. Even if lightning does not strike your house directly, it disturbs the ground potential for a large area. This is why telephones, televisions and refrigerators with ice makers are often damaged--they are connected to two different systems. If the surge protector has a cable or phone jack connector in addition to the AC sockets, would that protect the TV or telephone? It is helpful to have a common surge protector for low energy disturbances, but it cannot completely make up for a lack of proper bonding in a high energy situation. For example, if the telephone guy drove a separate ground rod, and it is not bonded to your power service ground, your $10 surge protector is not going to survive a nearby strike. |
Doug Haluza wrote: Current flows in a complete circuit--direction is arbitrary and irrelevant. What actually happens in many cases of applicance damage is not voltage surges, it's ground potential difference. If your power, telephone, cable TV and water services do not enter at the same point and have common grounding, they can have different "gound" potentials relative to each other. Even if lightning does not strike your house directly, it disturbs the ground potential for a large area. This is why telephones, televisions and refrigerators with ice makers are often damaged--they are connected to two different systems. If the surge protector has a cable or phone jack connector in addition to the AC sockets, would that protect the TV or telephone? To the extent that the surge protector is able, yes. However, the cheap power strip surge protectors that people often have are unlikely to absorb a lighting strike. If this is your goal, make sure you purchase one that says it can handle it. The good ones have attached equipment guarantees, where they'll pay for damage if their stuff fails to protect your stuff. -- Michael Ash Rogue Amoeba Software |
SSA and IRS | Pete Reinhart | Soaring | 12 | October 12th 06 07:59 PM |
SSA in Crisis: Can It Heal Itself? [LONG] | [email protected] | Soaring | 45 | October 5th 06 04:15 PM |
"For military, 'Lightning' strikes again" | Mike | Naval Aviation | 0 | September 18th 06 03:17 PM |
AOPA Truth Squad | skylunelives | Piloting | 29 | January 13th 06 04:42 AM |
OUCH! Lightning hits airplane......... | Aardvark | Piloting | 4 | February 8th 04 04:46 PM |
