Class D / Class C precedence
Old November 25th 06, 07:00 AM posted to rec.aviation.piloting,rec.aviation.student
Wade Hasbrouck
Default Class D / Class C precedence
"Mxsmanic" wrote in message
Kev writes:
Not "zero clouds", but "clear of clouds". Having to stay away from a
cloud by only an inch is much less restrictive than having to stay
hundreds of feet away.
Ah ... I thought "clear of clouds" meant "[sky] clear of clouds,"
rather than "[aircraft] clear of clouds."
Class B is more "restrictive" in the sense that you need an ATC clearance
before entering... Class D all you need to do is establish two way
communication.
Old November 25th 06, 07:37 AM posted to rec.aviation.piloting,rec.aviation.student
Wade Hasbrouck
"Wade Hasbrouck" wrote in message
Kev writes:
communication.
And when I say "establish two way communication" I mean you call them up and
if they acknowledge you in any way other than telling you to "stay out", you
are allowed to enter the Class D. i.e. if I call "Renton Tower, Cessna
1538V, Downtown Bellevue with Echo to land", and they reply with "Cessna
1538V, standby", that is considered establishment of two way communication
and I am allowed to enter the Class D. If they don't respond, then I must
stay clear of the Class D.
In your simulator you will never run into this.
One time going from Bremerton (PWT) to Boeing Field (BFI), as I came up on
the North end of Vashon Island, a guy departing BFI had declared an
emergency. The radio was quiet and thought I would see if the Boeing
Controller would acknowledge me (hoping for a "standby") so I could enter
the Class D, and so I called "Boeing Tower, Cessna 738VJ, North Vashon, with
Sierra, to land", and I got no response, so I started a left 360... then
the radio chatter picked up for the emergency and others inbound, and
between about 1/4 the way through the 360, the controller basically told
everyone, "I have an emergency in progress, I will get to as soon as I
can...", just past 1/2 way through the 360 the emergency was over and the
controller had gotten back to everyone but me and asked "is there anyone I
need to talk to that I haven't yet", suspecting he missed someone, and it
was me, but figured I would wait until I was pointed roughly in the right
direction before calling him again. Got pointed east, and gave him a call,
and he thanked me for my paitence. I had to do the 360 to stay out of the
Class D, as I had not yet established two way communication.
Old November 25th 06, 11:56 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Wade Hasbrouck writes:
Actually I will, with VATSIM, as there are real people handling ATC
and traffic then.
I try to be cooperative with ATC. I even feel guilty asking for
flight following. Of course, VATSIM controllers are much thinner on
the ground than the real thing, so the workload is sometimes much
higher. There may be one person effectively working all Class B and
Class C towers, plus Approach and Departure, plus Center, plus Ground
and Clearance Delivery. If there are only a few planes in the area,
no problem, but when traffic picks up to real-world levels, it becomes
impossible. The usual situation is practically empty skies and no
ATC, though.
Old November 25th 06, 03:40 PM posted to rec.aviation.piloting,rec.aviation.student
Roy Smith
Sierra, to land",
You might want to re-read what the AIM has to say about this:
6-3-1. Distress and Urgency Communications
d. Distress communications have absolute priority over all other
communications, and the word MAYDAY commands radio silence on the frequency
in use.
If you know the controller is working an emergency on the frequency, just
shut up, stay out of the way, and let the guy do his job. By keying the
mike, you could be stepping on a critical radio call. Even if the
frequency appears quiet, the controller is probably busy on the landline
coordinating with other ATC facilities, airport emergency response teams,
etc.
Old November 25th 06, 11:26 PM posted to rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
Communications with a troll are found to enable their behavior.
Old November 26th 06, 01:34 AM posted to rec.aviation.piloting,rec.aviation.student
Jarod
Newps wrote:
Mxsmanic wrote:
Newps writes:
You can only be in one airspace at a time. At TTD notice the class D
circle isn't a full cirlce. It gets cut off where the class C goes to
the ground.
Yeah, but look at the altitudes. The top of the Class D appears to be
_above_ the floor of the Class C that it overlaps.
The class C does not exist where the class D does.
Are you sure about that? Providence Class C protrudes into Quonset Point
class D airspace and the Quonset Tower is very adamant that the overlapping
area is Class C and requires communication with Providence.
Old November 26th 06, 02:25 AM posted to rec.aviation.piloting,rec.aviation.student
SR20GOER
"Morgans" wrote in message
"Dennis" wrote in message
I don't know if anyone else caught that, but it was very funny. Thanks!
I second that chuckle! :-)
Jim in NC
Jim (or any other USA contributors)
Slightly OT I know but can someone advise me (since we are talking
airspace) - are transponders mandatory to carry and use in Class E airspace
in the US?
cheers
Brian
  #28
Old November 26th 06, 04:16 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Jarod writes:
Newps wrote:
Mxsmanic wrote:
Newps writes:
the ground.
I'm looking at the inset on the Seattle sectional right now. The
dotted line of the TTD Class D doesn't extend into the central part of
the PDX Class C (where the latter starts at the surface). However, in
the two Class C sectors outside that, you see the dotted line of the
Class D, and 25 in a box, indicating that the Class D extends up to
2500 feet inclusive. But those two Class C sectors start at 1700 and
2000 feet, both below the ceiling of the Class D. So is 2000 feet
Class C, or Class D?
  #29
Old November 26th 06, 04:52 AM posted to rec.aviation.piloting,rec.aviation.student
Newps
One thing you can be sure of with ATC. Only one controller owns the
airspace at any given time. Those two facilities have gotten together
to iron out the airspace.
Jarod wrote:
Newps wrote:
Mxsmanic wrote:
Newps writes:
the ground.
  #30
Newps
in the US?
No.
SPORTS CLASS/CLUB CLASS 5 ugly Soaring 0 July 2nd 06 11:14 PM
Carrying flight gear on the airlines Peter MacPherson Piloting 20 November 25th 04 12:29 AM
