Pipistrel Kit Aircraft now FAA 51% Accepted
Old November 26th 06, 01:02 AM posted to rec.aviation.soaring,rec.aviation.homebuilt
Eric Greenwell
Default Pipistrel Kit Aircraft now FAA 51% Accepted
Juan Jimenez wrote:
ect certification of an individual aircraft.
C'mon Ron. You make it sound like the FAA guys are an officious bunch of
self righteous bureaucrats!
What else do they call themselves?
The ones I've worked with called themselves things like "Bob",
"Charlie", and "Sue", while they went out of their way to certify my
glider, set up our wave windows, and get me the waiver I requested.
"Transponders in Sailplanes" on the Soaring Safety Foundation website
www.soaringsafety.org/prevention/articles.html
"A Guide to Self-launching Sailplane Operation" at www.motorglider.org
Old November 26th 06, 01:36 AM posted to rec.aviation.homebuilt
On Sat, 25 Nov 2006 20:20:28 -0400, "Juan Jimenez" wrote:
"Brad" wrote in message
roups.com...
They could still get a Experimental-Exhibition tho right? Not quite the
freedom a Amateur built COFA gives, but can still fly it.
That depends where they stick you in the Exp/Exh structure. Some of the
subcategories are more restrictive than others.
The guys building the Me262s in Washington State came within a gnat's eyelash of
getting them Experimental/Amateur-Built. The DAR was going to sign them off,
but the local FSDO refused to allow it. They've got Exp/Exh, but with pretty
loose restrictions.
Old November 26th 06, 05:47 AM posted to rec.aviation.homebuilt
Morgans[_2_]
groups.com...
of
loose restrictions.
I thought they were going to get the same classification as other warbirds,
since they were built according to factory plans, or is that what the other
warbirds get?
Jim in NC
Old November 26th 06, 02:49 PM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
groups.com...
eyelash of
off,
pretty
loose restrictions.
You wouldn't have a copy of their op limitations, do ya?
Posted via a free Usenet account from http://www.teranews.com
Old November 26th 06, 02:50 PM posted to rec.aviation.soaring,rec.aviation.homebuilt
Juan Jimenez[_1_]
news:BI5ah.13303$_x3.11069@trndny02...
The ones I've worked with called themselves things like "Bob", "Charlie",
and "Sue", while they went out of their way to certify my glider, set up
Lucky you, you ran into the minority...
Old November 26th 06, 03:42 PM posted to rec.aviation.homebuilt
of getting them Experimental/Amateur-Built. The DAR was going to sign them off,
loose restrictions.
warbirds get?
You're probably right. The head of the operation is a member of EAA 26 (past
president, in fact) and he gave a talk at the last meeting, including the tale
of the certification process. Afterwards, I asked how bad his restrictions
were, and they sounded little different from Exp/Am-Built. They are permanent,
too, they don't have to be renewed every year like some of the Exp/Exh
airplanes. IIRC, he said it took them four months to get the first 262
licensed, and two weeks for the second. Beyond that, I can't tell you the
operating limitations.
The planes aren't just built to factory plans, they are considered factory
aircraft. Daimler Benz Aerospace assigned them the next five serial numbers on
from the wartime records. Other than critical safety issues (modern engines,
modern alloys, etc.), these planes are built the same as the wartime aircraft.
They've got steel where the WWII models had steel (LOTS of steel) and wood where
Messerschmitt used wood. They've even got dummy guns (needed for CG) and have
tankage for only 60-90 minutes of fuel.
One landing gear leg collapsed on the second landing, and it turned out to be a
manifestation of a common wartime fault (a built-up of tolerances in the
mechanism). After it happened, one of the old-time Messerschmitt mechanics
called from Germany to tell them exactly what to look for....
Old November 26th 06, 08:44 PM posted to rec.aviation.soaring,rec.aviation.homebuilt
Eric Greenwell
It's not luck when it happens repeatedly over a 30 year period at
multiple FSDOs, towers, and elsewhere. I do know people that always seem
to get the obnoxious ones, and it's not luck then, either.
Old November 26th 06, 09:27 PM posted to rec.aviation.soaring,rec.aviation.homebuilt
Juan Jimenez[_1_]
news:u0nah.7612$IW2.3020@trndny03...
of self righteous bureaucrats!
It's not luck when it happens repeatedly over a 30 year period at multiple
FSDOs, towers, and elsewhere. I do know people that always seem to get the
In my experience, running into "good ones" all the time means that whoever
is doing the running has figured out there are things the FAA doesn't need
to know.
Old November 27th 06, 12:00 AM posted to rec.aviation.soaring,rec.aviation.homebuilt
Jack
to know.
Juan, any boy with parents learns that by the time he's ten.
Good luck.
Jack
Old November 27th 06, 11:16 AM posted to rec.aviation.soaring,rec.aviation.homebuilt
Bruce Greef
bunch of self righteous bureaucrats!
Touche Eric, I was wondering if there was a good way to say that.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
