A REALLY bad joke
Old November 27th 06, 10:55 PM posted to rec.aviation.piloting
mike regish
Default A REALLY bad joke
After I got checked out in a Katana, I got my own POH. It came in a ring
binder with a pocket on the spine. I printed up a slip of paper to fit it
that said "How to Fly." I made sure it was facing the back on the glare
shield.
mike
"Doug" wrote in message
It's not JUST safety. The joke may be perfectly safe. But small
aircraft ARE dangerous and it's normal to worry somewhat about one's
safety while aboard. I always felt it was my job as captain to make my
passengers feel MORE safe, not less safe. Sure, ANYONE can scare a
passenger. Frankly if someone pulled one of these stunts on me, I'd
probably desert him as a friend and associate. These stunts have no
place in an airplane. Get your kicks some other way.
  #32
Old November 27th 06, 10:57 PM posted to rec.aviation.piloting
mike regish
I think that was a dentist-not a surgeon.
mike
"Jay Beckman" wrote in message
Wasn't it Bill Cosby who did the routine about just going under the
anasthetic (sp?) when the surgeon says "Ooops..." ???
"What do you mean, oops? I know what I mean when I say oops, but what the
hell do you mean when YOU say ooops??"
Jay B
  #33
Old November 28th 06, 12:35 AM posted to rec.aviation.piloting
Larry Dighera
On 27 Nov 2006 06:04:37 -0800, "Doug"
wrote in .com:
That's probably because you're a mature, responsible, adult, not an
immature jerk.
  #34
Old November 28th 06, 05:25 AM posted to rec.aviation.piloting
Alan Gerber
My CFI was very clear on the idea that I should *never* say "oops" when
I'm carrying passengers. Ever.
.... Alan
Alan Gerber
PP-ASEL
gerber AT panix DOT com
  #35
Old November 28th 06, 05:26 AM posted to rec.aviation.piloting
Alan Gerber
Brian wrote:
Like I pilot friend of mine told me he was coming in to land and
misjudged the approach and came in way to high. Upon Initiating a go
arround and told his passengers "We're not go make it" Meaning he was
going to have to go around. The passengers took it to mean "We are'nt
going to make it"
That seems like a reasonable interpretation to me.
.... Alan
Alan Gerber
PP-ASEL
  #36
Old November 28th 06, 06:11 AM posted to rec.aviation.piloting
Judah
Alan Gerber wrote in
the hell do you mean when YOU say ooops??"
... Alan
OK. That reminds me of a pilot story...
I had two passengers from Atlantic City in an Arrow II. We were returning
at night from a trip to Harrisburgh (KMDT) (Hershey, actually). It was
about 10pm or so...
We were heading to Bader (AIY). We had been at 5000', and coming up on the
field (KACY off to the left) I began a descent. After about 500', I decided
to pull out a couple of inches of Manifold Pressure to keep it below 24"
RPM.
As soon as I touched the throttle, the tach went redline on the RPM, the
engine revved like I was taking off. This was my first experience of this
type, so I was taken a bit by surprise. Before I realized the words had
come out of my mouth, I said ---
"Oh, SH-T!!"
Immediately, both passengers grabbed onto the doorhandles for dear life.
For the moment, appeasing my passengers was low priority. I reduce the
throttle to about half, and was able to get a reasonable prop response. I
then called ATC (I was still on with Atlantic City Approach) and indicated
that I had an onboard emergency, and would like to land on their runway 13,
just off to my left, instead of proceeding to Bader. They cleared me to
land and asked me the nature of the emergency.
By this time, I had noticed that the oil pressure was low, and so I told
them that I had the plane in a stable descent, had a low oil pressure
indication, and should be OK to make an easy landing on their Rwy 13.
He asks me, "Do you want me to roll the equipment?"
I say, "No, we've got it under control."
He says, "We're gonna roll the equipment anyway. They could use the
practice, and are probably bored anyway."
Sure enough, two fire trucks, a few ambulances, and a couple of police cars
followed me after an otherwise uneventful landing (actually, quite a
greaser!) down the runway and taxiway to the FBO. The engine actually
responded fairly well until we stopped the plane. Evidently, a seal had
leaked in one of the gaskets and I was left with about 3 quarts.
I'm not a mechanic, but as it was explained to me that when I adjusted the
throttle, after pretty much staying in the same spot for 90 minutes or so
enroute, the oil in the prop governer went back into the engine, and the
result was that there was not enough oil left in the prop governer to
govern the prop properly. (Say that 10 times fast!)
Incidentally, one of the two passengers has flown with me since, and the
other one hasn't, but did say he would fly with me again if the opportunity
presented itself...
It didn't take long for this story to be spread among everybody in our
industry. But somehow, no one really talks about how nice the greaser was,
or how I took command of the situation and landed us safely.
Nope, they mostly talk about my most memorable reaction to the problem in
the plane...
"Oh SH-T!!"
  #37
Old November 28th 06, 12:26 PM posted to rec.aviation.piloting
B A R R Y[_2_]
shield.
Beautiful... G
  #38
Old November 28th 06, 02:06 PM posted to rec.aviation.piloting
Jim Macklin
THE first indication of an oil problem is a run-away prop on
a single-engine with a typical constant speed prop. The
prop governor is just a high pressure oil pump and control
valve that must be supplied with engine oil under pressure
and with adequate volume. If the engine oil galleries and
lines are not full of oil, the governor will not work. On a
multiengine airplane, the prop will feather.
The prop, on a single, becomes fixed pitch and the throttle
controls rpm just like it was a solid fixed pitch. The
engine will run just fine as long as it has oil, but a
ruptured line or gasket will dump the oil and you don't know
exactly what is happening, so land ASAP.
Another story... When I was a student pilot, the FBO also
did completions on "green" MU2s that were very nice. They
had one that was being done for some Arab oil baron, with
solid gold fixtures, rare wood trim and the cost was over
$500,000 when a King Air was about $400,000 [long time ago].
The plane was finished and the company test pilot took it
out for a final acceptance test flight. Shortly after
take-off the pilot called the tower to report a problem and
get a quick landing, he did not use the word, emergency. He
was calm and spoke using his best "airline pilot voice."
The tower cleared him to land on any runway and asked him to
repeat his message. They asked him again. After the
uneventful landing the tower asked him to come up to the
tower.
The tape went like this... "Capitol tower, Mitsubishi 12345
has some cock in the smoke pit." This was repeated several
times, word for word, with out having any screaming, voice
inflections or emotions.
"Judah" wrote in message
going under the
oops, but what
say "oops" when
| ... Alan
were returning
actually). It was
| about 10pm or so...
coming up on the
keep it below 24"
| RPM.
on the RPM, the
experience of this
the words had
| "Oh, SH-T!!"
for dear life.
I reduce the
prop response. I
their runway 13,
cleared me to
and so I told
oil pressure
their Rwy 13.
could use the
(actually, quite a
engine actually
quarts.
when I adjusted the
90 minutes or so
engine, and the
governer to
since, and the
if the opportunity
| presented itself...
everybody in our
the greaser was,
safely.
the problem in
| the plane...
| "Oh SH-T!!"
  #39
Old November 28th 06, 02:08 PM posted to rec.aviation.piloting
Jim Macklin
How to Fly in Three Easy Lessons
or
The Little Airplane That Could.
"B A R R Y" wrote in message
. com...
It came in a ring
of paper to fit it
back on the glare
| shield.
| Beautiful... G
  #40
Old November 28th 06, 02:44 PM posted to rec.aviation.piloting
Judah
"Jim Macklin" wrote in news:JnXah.1960
Yeah - the way it was explained to me was that springs push the prop to full,
and oil pushes the prop back to govern the RPMs. But as you say, once I know
the oil pressure is low, it's time to pull over and get it checked out..
THAT is funny!
The Net's #1 Joke e-Book! Expert Humor Soaring 0 March 31st 06 03:25 PM
The Net's #1 Joke e-Book! Expert Humor Owning 0 March 31st 06 03:24 PM
The Net's #1 Joke e-Book! Expert Humor Home Built 0 March 31st 06 03:23 PM
The Net's #1 Joke e-Book! Expert Humor Piloting 0 March 31st 06 03:13 PM
American joke on the Brits ArtKramr Military Aviation 50 September 30th 03 10:52 PM
