Icing conditions
Old November 29th 06, 07:17 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Icing conditions
From what I understand, icing protection should be turned on if the
outside temperature is 5° C or less. However, what is the reason for
not having it on all the time? Does it overheat in normal weather, or
what?
I read that turning on icing protection before "sufficient ice has
accumulated" may prevent the protection from working to remove the
ice. Why?
Also, what types of anti-icing stuff should I turn on? Just
everything that deals with ice (wing, prop, pitot, fuel vent, etc.),
or is there an accepted order or hierarchy for these things?
Old November 29th 06, 07:22 PM posted to rec.aviation.piloting,rec.aviation.student
Gary[_2_]
Just turn up the heat in the room where you run your simulator, and
you'll be fine.
Old November 29th 06, 07:30 PM posted to rec.aviation.piloting,rec.aviation.student
Ron Garret
what?
No, it just wastes resources and puts unnecessary wear and tear on
things.
ice. Why?
That applies only to boots. If the ice layer is too thin it may remain
adhered to the boot.
Except for boots, the safest policy is to just turn it all on if there's
any possibility of ice.
rg
Old November 29th 06, 07:51 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
Air temperature changes with air pressure changes inside
engines and also around the wing and tail surfaces. Also,
temperature probes are not 100% accurate, so the +5°CF is to
provide a cushion.
Exactly what is turned ON depends on the airplane and the
type of ice protection installed.
It is important, something as simple as a temperature probe
also needs to be anti-iced to prevent any ice accumulation.
Other systems do de-icing, allowing some ice build-up and
then removing that.
King Air using P&W PT6 engines have ice deflector vanes that
deflect water and ice particles from the air going into the
engine. The intake lip on older King Airs had an electric
heating element, newer designs are heated by engine exhaust
being routed through a hot lip which gets hot any time the
engine is running.
Jet engines produce a lot of hot air by compression inside
the engine before the combustion section. Some of that hot
air is bled away and used to heat the air inlet to the
engine, electricity may be used to heat temperature probes
in the inlet. Smaller engines don't have as much hot bleed
air available, so they may use bleed air only for the air
intake and cabin pressure/environmental while a big airliner
probably uses bleed air for engines, wings, tail and other
areas. Some airplanes with multi-disc brakes may use a hot
air distribution manifold to send hot air to the brake
assembly so that the brakes are not frozen, this is turned
on a few minutes before landing and during taxiing in water
and slush/snow and is usually on a timer so it turns off
automatically about 10 minutes after gear retraction [the
switch then needs to be manual turned off to reset the
system for landing].
Pitot and windshield heat, are OK to run all the time in
flight, but if pitot heat is used on the ground for a long
period, the chrome will turn a pretty purple, so test it on
the ground [don't burn your hand] and then turn it on before
take-off.
Too many systems to explain here, read the POH or a good
training manual.
"Gary" wrote in message
on if the
simulator, and
you'll be fine.
Old November 29th 06, 07:58 PM posted to rec.aviation.piloting,rec.aviation.student
A Lieberma
"Jim Macklin" wrote in
training manual.
Talk about wasted advise.....
Mx doesn't even read the replies, much less anything he's been shown to
read like references or POHs.
Allen
Old November 29th 06, 08:00 PM posted to rec.aviation.piloting,rec.aviation.student
B A R R Y[_2_]
Some ice protection equipment uses a fluid that is of limited quantity
on-board, not to mention that it costs money. Other ice protection
devices can put a drain on a smaller aircraft's power. Turbine drivers
might chime in with their reasons, I don't know them.
Ice protection isn't always needed when it's cold, you also need
moisture to create ice.
Old November 29th 06, 08:12 PM posted to rec.aviation.piloting,rec.aviation.student
A Lieberma
"Steve Foley" wrote in news:BRlbh.12790
He can always pause and go to the fridge for more fluids.
Better yet, use the hot water from his sink.
Old November 29th 06, 08:13 PM posted to rec.aviation.piloting,rec.aviation.student
Steve Foley
"B A R R Y" wrote in message
et...
Other ice protection devices can put a drain on a smaller aircraft's
power.
He's running on 220VAC. Sholdn't be an issue.
Old November 29th 06, 08:21 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
I know, I know, but there are other real students out there
who might benefit. Just think if the Air Florida 737 pilot
had turned his engine anti-ice on before take-off a
Washington National, CNN wouldn't have had all those videos
of the water rescues and dead people.
"A Lieberma" wrote in message
. 18...
| "Jim Macklin" wrote
in
| training manual.
been shown to
| Allen
Old November 29th 06, 08:23 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
True, cold and in cloud or precip.
BTW, TKS systems make the plane and floor slippery, don't
fall and break a leg.
et...
turned on if the
the reason for
limited quantity
protection
Turbine drivers
also need
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
FAR 91.157 Operating in icing conditions O. Sami Saydjari Instrument Flight Rules 98 December 11th 03 06:58 AM
