I can't find any guidelines on the type of fixes or waypoints to be
included in the routing description of an IFR flight plan. I presume you can use things like VORs and (?) airports, as well as airways and anything indicated on IFR charts or procedures. But can you also use VPxxx waypoints or other VFR fixes? The reason for asking is that I'm wondering if a VFR flight plan with detailed routing that lists specific waypoints and fixes can be easily converted to IFR without changing the routing, should weather or other factors mandate a switch to IFR for the flight. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: converted to IFR without changing the routing, should weather or other factors mandate a switch to IFR for the flight. Hey y'all, This guy has been trolling the rec.aviation.piloting and rec.aviation.student newsgroups. He does not fly a real plane, just plays games on MSFS. If you could ignore this guy, it sure would be appreciated. Otherwise, the noise level in this group will rocket sky high. Allen |
A Lieberma wrote: Mxsmanic wrote in : converted to IFR without changing the routing, should weather or other factors mandate a switch to IFR for the flight. Hey y'all, This guy has been trolling the rec.aviation.piloting and rec.aviation.student newsgroups. He does not fly a real plane, just plays games on MSFS. He can't afford a real plane, so he's doing the best he can. He asks reasonable questions under the circumstances. If you could ignore this guy, it sure would be appreciated. Why should we ignore him when you don't? Otherwise, the noise level in this group will rocket sky high. IMHO you are contributing much more noise than mxsmanic does. At least he talks about flying. rg |
Mxsmanic wrote:
I can't find any guidelines on the type of fixes or waypoints to be included in the routing description of an IFR flight plan. I presume you can use things like VORs and (?) airports, as well as airways and anything indicated on IFR charts or procedures. But can you also use VPxxx waypoints or other VFR fixes? You can clearly use anything that defines an airway (but not T-airways), and ground-based navaids like VORs and NDBs, unless specifically tagged as "VFR Use Only". You specifically may not use VPxxx waypoints. The reason for asking is that I'm wondering if a VFR flight plan with detailed routing that lists specific waypoints and fixes can be easily converted to IFR without changing the routing, should weather or other factors mandate a switch to IFR for the flight. You can google for a long-ago thread that describes how to file a VFR flight plan that actually goes to ATC. If ATC doesn't have your flight plan, you're starting from scratch when you want to convert from VFR to IFR. Basically you check the "IFR" box on the flight plan form, then in the altitude box you write "VFR045" for 4500 feet (or something like that). Someone will correct me. If you don't check the IFR box, ATC never sees your flight plan, just FSS. Another advantage of this technique is that when you call up the next facility for VFR advisories, they already know who you are and where you are going. When the initial controller "departs" you, it initiates sending a strip to each of the facilities down the line based on your filed airspeed, just like for an IFR flight. There was a lot of discussion about whether it is legal to check the IFR box on the flight plan form if you don't hold an instrument rating. Clearly the answer is yes, it is legal [dons flameproof suit]. |
B A R R Y wrote in news:52mbh.16922$9v5.15977
@newssvr29.news.prodigy.net: I just thought of an "freebie" that might be of interest to you in your sim realism, "Sporty's Study Buddy": http://sportys.com/faatest/study/ Sporty's Study Buddy is more of a "learn the answers to the questions" system than a true course, but it's free. I was also going to suggest an online ground school, like King's: http://www.kingschools.com/, but I remember money is tight. Since you have no interest in actually flying, and won't actually have to pass a current written / oral exam, watching eBay for an outdated ground school video course (cheap, of course! G) might be worthwhile. Hey Barry, You are wasting your time. Mx isn't going to give your references the time of day..... Others have pointed him to many different sites. Unfortunately, looks like Mx is now polluting the rec.aviation.ifr group :-( Allen |
Mxsmanic wrote:
The reason for asking is that I'm wondering if a VFR flight plan with detailed routing that lists specific waypoints and fixes can be easily converted to IFR without changing the routing, should weather or other factors mandate a switch to IFR for the flight. You use IFR chart features on an IFR plan. Items like VOR, NDB, and airports with instrument approaches are on IFR Charts. Another document, known as the AF/D, or "Airport Facility Directory", lists "preferred routes", which ATC will usually put you on regardless of what you try to file. AF/D's are free he http://www.naco.faa.gov/index.asp?xml=naco/online/d_afd The "supplemental" section has the IFR routes 40 or so pages in. You can also look up restricted airspace, noise abatement corridors, etc... so you can keep the simulated Baron out of simulated trouble and prevent ****ing off the simulated noise-sensitive residents (simulated Skylune? G) you're flying over. It is possible to file a flight plan that uses both IFR and VFR portions. This is known as a "composite" flight plan. I just thought of an "freebie" that might be of interest to you in your sim realism, "Sporty's Study Buddy": http://sportys.com/faatest/study/ Sporty's Study Buddy is more of a "learn the answers to the questions" system than a true course, but it's free. I was also going to suggest an online ground school, like King's: http://www.kingschools.com/, but I remember money is tight. Since you have no interest in actually flying, and won't actually have to pass a current written / oral exam, watching eBay for an outdated ground school video course (cheap, of course! G) might be worthwhile. |
As filed, flight plans are not flown. VFR might well be
just as simple as telling FSS VFR, Washington DC , Indianapolis, St. Louis, Destination Kansas City [the phrase close enough for government work comes to mind.] My actual plan would have many points for visual and radio navigation. An IFR plan is more detailed, but might only have a departure airport, a SID and airway and a STAR and might only have the airway, the feds will assign the SID and STAR anyway. "B A R R Y" wrote in message . net... | Mxsmanic wrote: | | The reason for asking is that I'm wondering if a VFR flight plan with | detailed routing that lists specific waypoints and fixes can be easily | converted to IFR without changing the routing, should weather or other | factors mandate a switch to IFR for the flight. | | You use IFR chart features on an IFR plan. Items like VOR, NDB, and | airports with instrument approaches are on IFR Charts. Another | document, known as the AF/D, or "Airport Facility Directory", lists | "preferred routes", which ATC will usually put you on regardless of what | you try to file. | | AF/D's are free he | http://www.naco.faa.gov/index.asp?xml=naco/online/d_afd | | The "supplemental" section has the IFR routes 40 or so pages in. You | can also look up restricted airspace, noise abatement corridors, etc... | so you can keep the simulated Baron out of simulated trouble and prevent | ****ing off the simulated noise-sensitive residents (simulated Skylune? | G) you're flying over. | | It is possible to file a flight plan that uses both IFR and VFR | portions. This is known as a "composite" flight plan. | | I just thought of an "freebie" that might be of interest to you in your | sim realism, "Sporty's Study Buddy": | http://sportys.com/faatest/study/ Sporty's Study Buddy is more of a | "learn the answers to the questions" system than a true course, but it's | free. | | I was also going to suggest an online ground school, like King's: | http://www.kingschools.com/, but I remember money is tight. Since you | have no interest in actually flying, and won't actually have to pass a | current written / oral exam, watching eBay for an outdated ground school | video course (cheap, of course! G) might be worthwhile. |
Dave Butler writes:
You can clearly use anything that defines an airway (but not T-airways), and ground-based navaids like VORs and NDBs, unless specifically tagged as "VFR Use Only". You specifically may not use VPxxx waypoints. OK. So I'd probably be better off avoiding VPxxx waypoints to begin with, even for VFR, if there's any chance that I'd want to use that as a base for an IFR flight plan. Too bad ... there's lots of VPxxx waypoints on the VFR charts, whereas the only other ones indicated are on airways, and there are a lot less of those (at least in high traffic areas). Basically you check the "IFR" box on the flight plan form, then in the altitude box you write "VFR045" for 4500 feet (or something like that). Someone will correct me. Hmm ... I didn't know that. Another advantage of this technique is that when you call up the next facility for VFR advisories, they already know who you are and where you are going. When the initial controller "departs" you, it initiates sending a strip to each of the facilities down the line based on your filed airspeed, just like for an IFR flight. Sounds very convenient. Is there someplace on the Web that discusses everything you can validly put in an IFR flight plan (or a VFR flight plan, for that matter)? I can't find any detailed descriptions in the references I've looked at. -- Transpose mxsmanic and gmail to reach me by e-mail. |
B A R R Y writes:
You use IFR chart features on an IFR plan. Is there any place that has IFR charts online, like SkyVector does for VFR charts? AF/D's are free he http://www.naco.faa.gov/index.asp?xml=naco/online/d_afd I'm trying to download that now. The "supplemental" section has the IFR routes 40 or so pages in. You can also look up restricted airspace, noise abatement corridors, etc... so you can keep the simulated Baron out of simulated trouble and prevent ****ing off the simulated noise-sensitive residents (simulated Skylune? G) you're flying over. I have simulated lawyers to protect me, but your point is well taken. It is possible to file a flight plan that uses both IFR and VFR portions. This is known as a "composite" flight plan. Well, I can't even find the details on how to file a basic flight plan, like what all the slash notations mean or guidelines for giving the routing information or anything. I found the paper form itself online, but no instructions. I just thought of an "freebie" that might be of interest to you in your sim realism, "Sporty's Study Buddy": http://sportys.com/faatest/study/ Sporty's Study Buddy is more of a "learn the answers to the questions" system than a true course, but it's free. I won't be taking an actual test any time soon, so I'm more interested in detailed answers than in rote responses to test questions, but I'll keep it in mind. I was also going to suggest an online ground school, like King's: http://www.kingschools.com/, but I remember money is tight. Yes. Unfortunately, anything that isn't free right now is out of the question. Since you have no interest in actually flying, and won't actually have to pass a current written / oral exam, watching eBay for an outdated ground school video course (cheap, of course! G) might be worthwhile. What does ground school cover that isn't in the downloadable stuff from the FAA? I remember my father taking a ground school course endless years ago and a big fat book that came with it, but I don't recall anything else. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Is there someplace on the Web that discusses everything you can validly put in an IFR flight plan (or a VFR flight plan, for that matter)? I can't find any detailed descriptions in the references I've looked at. http://www.faa.gov/airports_airtraff.../media/aim.pdf |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| FLIGHT SIMULATOR X DELUXE 2006-2007 (SIMULATION) 1DVD,Microsoft Flight Simulator 2004, and Addons, FLITESTAR V8.51 - JEPPESEN, MapInfo StreetPro U.S.A. [11 CDs], Rand McNally StreetFinder & TripMaker Deluxe 2004 [3 CDs], other | T.E.L. | Simulators | 0 | October 14th 06 10:08 PM |
| us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 05:24 AM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
