Contra-rotating engine revisited
Old December 1st 06, 09:34 PM posted to rec.aviation.piloting
Mxsmanic
Default Contra-rotating engine revisited
tom418 writes:
Vacuum pumps are different (although these are accesories)
What is the logic behind using vacuum to power instruments? Why not
just use an electric motor, or compressed air?
Old December 1st 06, 09:51 PM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
"Chris W" wrote in message
The previous post on this topic got me wondering. Just how different
would the two engines need to be? I'm no expert, but it seems to me cam
shaft(s), magnetos, and prop are the parts that would be different from
one side to the other. I almost forgot, reverse the polarity on the
starter motor. What am I missing?
Chris W
KE5GIX
Camshaft as you said.
Crank - they drill the holes for the oil to the rod bearings in a different
spot.
Magneto - the impulse has to work in the other direction. I don't know if
there are changes to the points for avaition applications.
Oil pump - has to pump in the other direction
Starter - the bendix is different, the brushes are re-located
Alternator - it may have a different cooling fan
vacuum pump
Prop as you said
Mechanical Tach, or the drive (I assume)
Geoff
Old December 1st 06, 10:22 PM posted to rec.aviation.piloting
TxSrv
Why don't you just think about what FAA's answer to that one is.
So obvious a Caveman can figure it out. Plus, compressed air
can be and is used. But not electricity, unless....
F--
Old December 1st 06, 10:33 PM posted to rec.aviation.piloting
Jose[_1_]
Anyone for the "Dutch Roll" discussion next?
Isn't that a cinnamon roll where you supply your own cinnamon?
Jose
"There are 3 secrets to the perfect landing. Unfortunately, nobody knows
what they are." - (mike).
Old December 1st 06, 11:23 PM posted to rec.aviation.piloting
Bucky
If propeller direction is all that you need to change, could you just
add a reverser gear?
Old December 2nd 06, 12:14 AM posted to rec.aviation.piloting
Steve Foley[_2_]
Default MXX Contra-rotating engine revisited
"TxSrv" wrote in message
Too many Geico ads?
Old December 2nd 06, 12:16 AM posted to rec.aviation.piloting
Steve Foley[_2_]
"Bucky" wrote in message
How about one engine in the middle, with chain driven gears turning the
props on the wings.
Oh, wait. I think that's already been done.
Old December 2nd 06, 02:32 AM posted to rec.aviation.piloting
Peter Dohm
Please do not feed the trolls!
Peter Dohm
Old December 2nd 06, 09:18 AM posted to rec.aviation.piloting
Jim Macklin
MXs Maniac, sounds like a handle for a motocross rider or
wannabe...
Test for torque.
Jump your YZ400 and while in the air, open the throttle, why
does the front wheel move and which direction? Stab the
rear brake just before landing, why is that a bad idea?
Get your MSFS and setup the P51 Mustang with the big HS
prop. In flight at 75 mph and 100 feet, slam the throttle
wide open, report what happens?
"Nomen Nescio" wrote in message
| -----BEGIN PGP SIGNED MESSAGE-----
| That's because the amount of torque changes with the
rotational speed
| of the engine. However, as long as it is turning, it is
exerting
| torque on the rest of the car.
| Dammit! I'm calling MIT tomorrow to demand my money back.
| Those *******s told me that it was proportional to angular
| acceleration.
| -----BEGIN PGP SIGNATURE-----
| Version: N/A
iQCVAwUBRXEvR5MoscYxZNI5AQHLwwP/c8Px/lAd0Juz8SrdSryWwm+a18/JOQch
fE4wOQJok+uuBvlwirYRzQXaO/JYUvcHfS2LsnP6IGlqn5cPWhfjoZm90Z7z0E8r
6uGcn1SIG2wL95eawN/Qr7/6r2MljbUvRF3VtvvAGJDexRVnHSgK+73sAIht1Wfg
| CYUcTQG1O1U=
| =d6DK
| -----END PGP SIGNATURE-----
Gyrocopter Speed Mark Rotorcraft 36 August 16th 05 11:28 PM
Towing Roger Fowler Soaring 6 August 11th 05 04:25 AM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
