tom418 writes:
Vacuum pumps are different (although these are accesories) What is the logic behind using vacuum to power instruments? Why not just use an electric motor, or compressed air? -- Transpose mxsmanic and gmail to reach me by e-mail. |
"Chris W" wrote in message
... The previous post on this topic got me wondering. Just how different would the two engines need to be? I'm no expert, but it seems to me cam shaft(s), magnetos, and prop are the parts that would be different from one side to the other. I almost forgot, reverse the polarity on the starter motor. What am I missing? -- Chris W KE5GIX Camshaft as you said. Crank - they drill the holes for the oil to the rod bearings in a different spot. Magneto - the impulse has to work in the other direction. I don't know if there are changes to the points for avaition applications. Oil pump - has to pump in the other direction Starter - the bendix is different, the brushes are re-located Alternator - it may have a different cooling fan vacuum pump Prop as you said Mechanical Tach, or the drive (I assume) -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Mxsmanic wrote:
What is the logic behind using vacuum to power instruments? Why not just use an electric motor, or compressed air? Why don't you just think about what FAA's answer to that one is. So obvious a Caveman can figure it out. Plus, compressed air can be and is used. But not electricity, unless.... F-- |
Anyone for the "Dutch Roll" discussion next?
Isn't that a cinnamon roll where you supply your own cinnamon? Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
Chris W wrote:
The previous post on this topic got me wondering. Just how different would the two engines need to be? If propeller direction is all that you need to change, could you just add a reverser gear? |
"TxSrv" wrote in message
. .. So obvious a Caveman can figure it out. Too many Geico ads? |
"Bucky" wrote in message
ups.com... Chris W wrote: The previous post on this topic got me wondering. Just how different would the two engines need to be? If propeller direction is all that you need to change, could you just add a reverser gear? How about one engine in the middle, with chain driven gears turning the props on the wings. Oh, wait. I think that's already been done. |
Please do not feed the trolls!
MXs Maniac, sounds like a handle for a motocross rider or
wannabe... Test for torque. Jump your YZ400 and while in the air, open the throttle, why does the front wheel move and which direction? Stab the rear brake just before landing, why is that a bad idea? Get your MSFS and setup the P51 Mustang with the big HS prop. In flight at 75 mph and 100 feet, slam the throttle wide open, report what happens? "Nomen Nescio" wrote in message ... | -----BEGIN PGP SIGNED MESSAGE----- | | From: Mxsmanic | | That's because the amount of torque changes with the rotational speed | of the engine. However, as long as it is turning, it is exerting | torque on the rest of the car. | | Dammit! I'm calling MIT tomorrow to demand my money back. | Those *******s told me that it was proportional to angular | acceleration. | | -----BEGIN PGP SIGNATURE----- | Version: N/A | | iQCVAwUBRXEvR5MoscYxZNI5AQHLwwP/c8Px/lAd0Juz8SrdSryWwm+a18/JOQch | fE4wOQJok+uuBvlwirYRzQXaO/JYUvcHfS2LsnP6IGlqn5cPWhfjoZm90Z7z0E8r | 6uGcn1SIG2wL95eawN/Qr7/6r2MljbUvRF3VtvvAGJDexRVnHSgK+73sAIht1Wfg | CYUcTQG1O1U= | =d6DK | -----END PGP SIGNATURE----- | | |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Gyrocopter Speed | Mark | Rotorcraft | 36 | August 16th 05 11:28 PM |
Towing | Roger Fowler | Soaring | 6 | August 11th 05 04:25 AM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
