I've asked a lot of experts this question and have
yet to get a cogent answer. Surprising. When the engines are mounted by the tail in everything from MD-80s to CJ Citations, why do they always tilt up at the front? What aerodynamic problem does that solve? We know about similar things... why do they make the engine on more than a few singles point to the right? -- To deal with P-factor. But what's the answer on the jets? Bill Hale |
Most likely to line it up with the local flow at a design point. Such as:
high altitude, heavy wt, cruise or single engine climb at max gross or .... or .... or a compromise between several design points. I remember an access door on the outboard side of a rear mounted nacelle that came off in flight. It hit the rudder. " wrote in message ps.com... I've asked a lot of experts this question and have yet to get a cogent answer. Surprising. When the engines are mounted by the tail in everything from MD-80s to CJ Citations, why do they always tilt up at the front? What aerodynamic problem does that solve? We know about similar things... why do they make the engine on more than a few singles point to the right? -- To deal with P-factor. But what's the answer on the jets? Bill Hale |
Picture the airflow from the trailing edge of the wing, you want this well
aligned with the intake. Todd "B A R R Y" wrote in message ... wrote: When the engines are mounted by the tail in everything from MD-80s to CJ Citations, why do they always tilt up at the front? What aerodynamic problem does that solve? Thrust line. |
I'm no aeronautical engineer, but .. I would think the angle may be
chosen so that, at some chose speed (like final approach speed), there is minimal trim change over a wide range of power (thrust) settings. I wouldn't want the airplane to pitch up, or down, on short final when I found it necessary to add power to make a missed approach. I would think a similar reason would explain the off-axis alignment of the motor on single-engine airplanes. I'll ask my mechanic. george |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
