#41
On Mon, 04 Dec 2006 12:52:18 GMT, B A R R Y
wrote: Roger wrote: Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) Roger, In what general area are you based? Midland Michigan's Barstow Airport (3BS) which is about 100 miles NNW of Detroit. We're 11.3 on the 337 radial of MBS which is just north of Saginaw. There's a polished Debonair / Bo at MGJ (Orange County, NY), that's got to be the runner-up to yours. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#42
On Mon, 04 Dec 2006 12:39:58 GMT, B A R R Y
wrote: Roger wrote: In most Beech singles that rudder has more authority than the nose gear unless going really slow. As a pilot who learned to taxi without brakes on Pipers and Cessnas, I almost ran the first Beech single I taxied right into the weeds. You shouldn't need to use the brakes on a Bo either, but the nose gear has a couple of "quirks" that make it difficult to taxi in a straight line. The strut is canted forward and to the left. (pilot's side). This gives the nose gear a negative caster as well as being tilted slightly. The results are the need to constantly "dance" on the rudder pedals. Right rudder to get the nose gear straight and once it centers it will keep right on going to the right. Left rudder to center and of course it'll just keep right on going to the left. It is not an airplane you can taxi with your feet flat on the floor. Leave it alone and it'll go any direction except straight. You also learn to be "quick" when taking your feet off the pedals to move them up high enough for your toes to be able to touch the brakes as the thing is going to want to change directions. However, it is good exercise for you legs.:-)) A classic case of needing to operate the plane you're in, not the others you've flown in the past. All airplanes have quirks and idiosyncrasies. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#43
On Mon, 04 Dec 2006 07:44:52 -0700, Newps wrote:
Roger wrote: We had an old V Tail Bo on the line around the Jurassic Period that we used for charter once in a while. Even then those big flaps slow them down in a hurry. Bonanza flaps are OK. They're no Cessna flaps though. Might depend on the model. Some Bonanzas and Debonairs are rated for shorter landings than a 172. That's saying quite a bit when you are talking about 3000# and up compaired to the weight of a 172. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#44
Wheel barrowing will cause loss of directional control and
the accident will damage the airplane. Many Cessna airplane are used for student instruction, as are Piper and Beech, all are often landed on the nose wheel by student pilots (and other too) and damage is not uncommon. Transport category airplanes are often designed with a negative angle of attack when the nose wheel is on the ground and they also have ground spoilers. Some GA light twins, such as the Duke, have a negative lift with the nose on the ground, but most light aircraft have enough tail area to lift a major portion of the weight from the main wheels with full down elevator. Land, hold the nose off and then reduce back pressure and lower the nose wheel into contact with the ground. Some airplanes, such as the Piper singles may need to have the nose wheel steering straightened before the wheel is allowed to touch down. Some airplanes disconnect nose wheel steering until the wheel has weight applied. Once the nose wheel is firmly on the ground, apply brakes and smoothly apply aft pressure again until the control is fully aft. Be sure to use the ailerons, elevator and brakes to control the airplane. Some differential power on a twin can be used, but on a slick runway, be careful. If you have reverse thrust, be extra careful about directional control. "Matt Whiting" wrote in message ... | BT wrote: | | I would not apply forward pressure to the stick. I would apply heavier than | normal braking to get more weight on the wheels, and apply back pressure at | the same time so the decelleration does not throw more weight onto the nose | tire/strut. Heavier than normal braking tends to flat spot tires if the | weight is not fully on the mains. | | Wheel barrowing is a common occurance on landing when a pilot forces the | airplane to land before it is ready. | Common evidence of wheel barrowing in Cessna's is damage to the lower fire | wall, sometimes to the point that day light is seen through the seperation. | | I don't think wheelbarrowing will damage the firewheel. It takes a | landing on the nosewheel to do that. This isn't quite the same as | wheelbarrowing. | | | Matt |
#45
OK.................I'll bite!
I'm doubting that..... Karl "Curator" N185KG Might depend on the model. Some Bonanzas and Debonairs are rated for shorter landings than a 172. That's saying quite a bit when you are talking about 3000# and up compaired to the weight of a 172. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#46
![]() "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news ![]() "Dan" wrote in message ps.com... My impression that the elevator applied varying levels of downward force to balance the plane about the center of lift. I am not aware that the elevator could even produce _upward_ force on the tail. If the elevator couldn't generate an _upward_ force, then you couldn't pick up the tail on an taildragger, right? Let me assure you, you can pick up the tail on a taildragger. I agree 100% that the elevator can generate an upward force and pushing the stick forward in a tricycle plane to put weight on the nose is NOT a good idea in general. I would think it would be very easy to over do it. Danny Dot -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
#47
On 3 Dec 2006 21:52:57 -0800, Dan wrote:
My impression that the elevator applied varying levels of downward force to balance the plane about the center of lift. I am not aware that the elevator could even produce _upward_ force on the tail. If it can't produce upward force, then the rear of the plane could be made no lighter than when it is standing still, therefore it could transfer no _additional_ weight to the nosewheel no matter what the control inputs. Where is this logic flawed (seriously, I want to understand if this is wrong...) Airplanes are normally trimmed (and loaded within limits) so the horizontal stabilizer provides a relatively small downward force. This gives positive pitch stability without a major increase in drag. If your model of how the elevator works was valid, it would be impossible for an aircraft to fly inverted since even full down elevator wouldn't be enough to counteract the nose-down pitch moment. You also have to consider that an aircraft on the ground would pitch around an axis passing through the main landing gear, not through the wing's center of lift. ljd |
#48
![]() Matt Whiting wrote: Dan wrote: All, When touching down in a crosswind, after the mains and the nosewheel have all touched down firmly and are rolling, would it be proper procedure to apply slight forward pressure to get better steering from the nosewheel? Often, noseweel steering seems ineffective, and this seems to have helped my control on rollout. Any cautions? I have heard about "wheelbarrowing" but is that more of a takeoff issue than landing issue? Under what circumstances would "wheelbarrowing" occur? --Dan I was taught to basically use neutral elevator during the roll-out. You really shouldn't need to add forward pressure to get solid steering. Wheelbarrowing is a possibility if you apply aggresive nose down elevator right after landing when you speed is high, but as you slow down the ability to do this obviously decreases. What are your symptoms of ineffective nosewheel steering? Are you not able to hold the airplane on the centerline? Are you rolling in aileron into the wind as you slow down such that you have full aileron into the crosswind as you get to taxi speed? I happened to bump into this:- http://www.aaib.dft.gov.uk/cms_resou...pdf_507740.pdf It discusses forward pressure immideately after landing says:- Boeing 757-2T7, G-MONC Nature of Damage: Structural damage to forward fuselage in area of nose landing gear ..... Having developed an incorrect landing technique, it is possible that it was simply a matter of time before the timing in the application of full nose-down elevator caused an incident ..... Over the ensuing 1.125 seconds, the elevator position changed from 15.6degrees nose up at touchdown to full nose down (20degrees) and the pitch attitude began to reduce rapidly. The aircraft became light on the main landing gear oleos but not enough to register a change of state of the air / ground logic. The right reverser indicated in transit just before the (almost simultaneous) main landing gear recompression and nose gear ground contact. A normal acceleration of +1.6g was recorded during the re-compression of the main landing gear. The rate of derotation at nose gear oleo compression was calculated to be 10degrees/second. This figure was confirmed by the aircraft manufacturer who also stated the design limit value to be 7°/second. |
#49
Boeing airliners are designed to have the nose wheel firmly
on the ground, some even have a brake. But no airplane is designed to have the nose forced/slammed down except maybe a carrier based fighter. But back to the GA aircraft and effective nose wheel steering... steering works with the weight on the main landing gear and the nose wheel applies force to move the nose. If you apply forward elevator you'll be loading the nose wheel and shifting the pivot point [fulcrum] to the nose wheel, this will cause the airplane to weathervane even more and result in loss of directional control. wrote in message oups.com... Matt Whiting wrote: Dan wrote: All, When touching down in a crosswind, after the mains and the nosewheel have all touched down firmly and are rolling, would it be proper procedure to apply slight forward pressure to get better steering from the nosewheel? Often, noseweel steering seems ineffective, and this seems to have helped my control on rollout. Any cautions? I have heard about "wheelbarrowing" but is that more of a takeoff issue than landing issue? Under what circumstances would "wheelbarrowing" occur? --Dan I was taught to basically use neutral elevator during the roll-out. You really shouldn't need to add forward pressure to get solid steering. Wheelbarrowing is a possibility if you apply aggresive nose down elevator right after landing when you speed is high, but as you slow down the ability to do this obviously decreases. What are your symptoms of ineffective nosewheel steering? Are you not able to hold the airplane on the centerline? Are you rolling in aileron into the wind as you slow down such that you have full aileron into the crosswind as you get to taxi speed? I happened to bump into this:- http://www.aaib.dft.gov.uk/cms_resou...pdf_507740.pdf It discusses forward pressure immideately after landing says:- Boeing 757-2T7, G-MONC Nature of Damage: Structural damage to forward fuselage in area of nose landing gear ..... Having developed an incorrect landing technique, it is possible that it was simply a matter of time before the timing in the application of full nose-down elevator caused an incident ..... Over the ensuing 1.125 seconds, the elevator position changed from 15.6degrees nose up at touchdown to full nose down (20degrees) and the pitch attitude began to reduce rapidly. The aircraft became light on the main landing gear oleos but not enough to register a change of state of the air / ground logic. The right reverser indicated in transit just before the (almost simultaneous) main landing gear recompression and nose gear ground contact. A normal acceleration of +1.6g was recorded during the re-compression of the main landing gear. The rate of derotation at nose gear oleo compression was calculated to be 10degrees/second. This figure was confirmed by the aircraft manufacturer who also stated the design limit value to be 7°/second. |
#50
Best place for CG along roll axis | Mxsmanic | Piloting | 42 | September 28th 06 04:40 AM |
Crosswind landing | Ron Webb | Home Built | 23 | June 10th 06 03:43 AM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
Tailwheel Crosswind Landing | Piloting | 32 | December 6th 04 02:42 AM | |
Strong crosswind landings! | Toks Desalu | Piloting | 12 | April 19th 04 07:43 PM |
