IFR Cancellation Question
Old December 8th 06, 11:32 PM posted to rec.aviation.ifr
Newps
Default IFR Cancellation Question
A Lieberma wrote:
IFR would be then cancelled once wheels touch ground???
ATC takes no overt action to cancel an IFR aircraft landing at a towered
field. You just land.
  #32
Old December 8th 06, 11:33 PM posted to rec.aviation.ifr
Newps
Robert Chambers wrote:
Or unless you cancel in the air which is sometimes easier to do at a
field with no RCO or a tower that is closed.
You can also cancel in the air to help people out, I've been on an IFR
plan (but by the time I was approaching the field was VFR conditions)
and I heard a Jet at the hold short "ready for release" the tower said
"I have one IFR arrival inbound, expect a 3 minute delay" once that was
acknowledged I said "N1234 is cancelling IFR at this time" got the
cancellation and they released the jet to go before I got there. The
jet jockey (which surprised me) threw me a thank you before he got
switched over to approach.
Anything to make the system work that makes sense is ok in my book.
Three lousy minutes? The tower should have used visual separation and
let the jet go.
  #33
Old December 8th 06, 11:35 PM posted to rec.aviation.ifr
Newps
Mark Hansen wrote:
So I wonder if the confusion came when ATC told Allen to Squawk VFR?
This just means that you're no longer in radar contact, and not that
you're no longer IFR, right?
No, that measn the controller thought you were VFR.
Or, are you supposed to maintain your transponder code until changed
by ATC or you cancel IFR - even if radar service is terminated?
If you are terminated you still stay on your code unless you are now
going to be VFR.
  #34
Old December 9th 06, 01:23 AM posted to rec.aviation.ifr
Alan Gerber
Steven P. McNicoll wrote:
Yes, you can get an altitude assignment while VFR, but you can't (properly)
get one from Seattle Center while VFR. Reporting the field serves a purpose
if you're IFR, but not if you're VFR.
When I get flight following from New York Approach, they always ask me to
report the field in sight. (This is for both controlled and uncontrolled
fields.) This is for airports that are NOT in the Bravo airspace --
they're either near or underneath it.
I assume the purpose it serves is it tells them when they can terminate
flight following.
.... Alan
Alan Gerber
PP-ASEL
gerber AT panix DOT com
  #35
Old December 9th 06, 01:30 AM posted to rec.aviation.ifr
A Lieberma
Robert Chambers wrote in news%keh.20495
Absolutely agree Robert. I like to be a "good neighbor" but not at the
cost of safety of course.
Once I get a visual on my airport (KMBO - uncontrolled), I do cancel IFR
as soon as I can.
The very same situation happened to me, and I was on the ground, and I
had really appreciated it myself so because one person did it for me, I
am determine to "pay it forward" any chance I get so long as my skin is
not jeapordized.
I generally can tell approach also appreciates my cancellation by the
sound of their voice when they say "cancellation received" as I am sure
it helps them as well.
One other time, I was on the ground, picking up my clearance on a MVFR
day, and CD was kind enough to clue me in to depart visually (was never
taught this in my IFR training) and pick up my clearance in the air as
there would have been a 15 minute delay for incoming IFR traffic.
Ceilings were 2500, so I had no problem with the choice given.
Allen
  #36
Old December 9th 06, 01:37 AM posted to rec.aviation.ifr
A Lieberma
Mark Hansen wrote in
Mark,
My experiences operating in areas of no radar coverage (NOT what happened
here in my original post) is that you maintain your transponder code and
work with "reporting points" as required under IFR enroute rules.
I was in Charlie airspace when I was told to squawk VFR in my original
post, thus my confusion
For no radar coverage, you maintain your transponder code. I had asked
when this happened to me the first time and Center advised me to retain
the code and when I come out of the non radar environment, he would pick
me up. I'd rather sound dumb on the radio then do something dumb :-))
I think the only thing that was missing in Allen's case was the
clearance to fly the visual approach.
EXACTLY right! AND the IFR cancellation received, squawk VFR" buzz words
I learn to know and love.
Those rank up there with "cleared to land" at a controlled airport :-)
Allen
  #37
Old December 9th 06, 01:50 AM posted to rec.aviation.ifr
A Lieberma
Alan Gerber wrote in
terminate flight following.
Alan,
VFR flight following is workload permitted basis.
So, like you, I have experienced the same, approach asking me to advise
airport in sight. Approach can tell you to squawk VFR, have a good day
well before you have a visual on VFR flight following. In my area, I have
never had that done except once when I was arriving after the ATC shut down
for the night.
Generally IN MY AREA, if it's that busy, approach much rather you squawk
and talk then not. But I am only dealing with C airspace.
For IFR, a visual approach requires sight of the airport / runway
environment, and ATC cannot terminate your IFR until you request it (I.E
cancel IFR like in my case at an uncontrolled airport) or land at a
controlled airport.
Allen
  #38
Old December 9th 06, 02:28 AM posted to rec.aviation.ifr
Alan Gerber
I guess I worded that poorly. Of course they can terminate flight
following whenever they need to. Once the field is in sight, you pretty
much *need* to terminate flight following -- either to contact the tower,
for a towered field, or to start talking on CTAF, otherwise.
for the night.
I've had that done on occasion -- including my long student X-C solo. I
assumed they weren't able to do the handoff, especially since they gave me
the frequency to try myself later.
.... Alan
Alan Gerber
PP-ASEL
  #39
Old December 9th 06, 03:49 AM posted to rec.aviation.ifr
Mark Hansen
Alan,
for the night.
environment,
.... or sight of the airplane ahead of you...
controlled airport.
Allen
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
  #40
Old December 9th 06, 03:54 AM posted to rec.aviation.ifr
Robert Chambers
let the jet go.
Our tower is special, there's lots of things they "should" do but don't.
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 09:32 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Question Charles S Home Built 4 April 5th 04 09:10 PM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
