Digital Paper displays
Old December 9th 06, 05:38 AM posted to rec.aviation.soaring
Roger Worden
Default Digital Paper displays
In the current issues of aviation magazines, there are ads for eFlyBook.
This device contains various flight documents for power pilots, but the
interesting part is the use of a "digital paper" display. Other than retail
store signs, this is the first commercial use of digital paper that I have
seen. Digital paper is a technology that uses tiny rotating beads, black on
one side and white on the other, electrostatically rotated, forming a
non-volatile, non-luminous display. The upside is that it is clearly visible
in full sunlight! The downside is that right now DP is limited to
monochrome. I am hoping that the PDA makers will someday produce a DP-based
unit, which might eventually be useful with SeeYouMobile, WinPilot and the
like. It's really hard to see the display on my HP IPAQ in the cockpit, even
though the one I selected was recommended as one of the most visible. I did
some searching and did not find any hints of such a product yet.
Anyone have more information?
Old December 9th 06, 08:29 AM posted to rec.aviation.soaring
Clint
Colour is overated in the cockpit. Far prefer my monochrome palm
running soaringpilot to my colour ipaq running seeyou mobile
Clinton
Lak 12
Old December 9th 06, 08:31 AM posted to rec.aviation.soaring
Clint
Clinton
Lak 12
Old December 9th 06, 01:12 PM posted to rec.aviation.soaring
Mark Hawkins
If you want to pay $3000 you can buy one of the prototype kits from
E-Ink (display maker). It is a fully functional system running a
version of Linux. You might be able to then run Cumulus
(http://www.kflog.org/cumulus/). It's he only soaring app that I know
of that runs under linux.
Later!
-Mark
Clinton
Lak 12
Old December 9th 06, 02:44 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I was very curious about the display so I called the manufacturer of the
hardware. I like the large size and sunlight readability. But they said it
had a very slow update rate that probably wouldn't work well for a moving
map display.
Paul Remde
"Roger Worden" wrote in message
t...
retail
on
visible
DP-based
even
did
Old December 9th 06, 06:10 PM posted to rec.aviation.soaring
kirk.stant
Clinton
Lak 12
The trick is to be very selective in what color is displayed. Most
moving map data is eye candy only, especially on flatlands.
The nice thing about Seeyou mobile is you can tailor the display to
show just what you want, and make the lines big enough and dark enough
to be seen easily on an iPaq in direct sunlight.
When terrain is desirable (such as in ridge country), again the map can
be setup to only show the ridges that are of interest.
Takes some time at home to tweak, but worth it!
Kirk
66
Old December 9th 06, 08:05 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
seen.
Mororola's new F3 mobile phone, which apparently has just started
shipping in India, uses an E ink display. Its a low cost phone aimed at
3rd world users. The display retains what it was last showing when the
phone is turned off.
If you want to check the display legibility, details and photos are he
http://www.reghardware.co.uk/2006/11...hips_motofone/
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 9th 06, 08:06 PM posted to rec.aviation.soaring
eInk has a terribly slow update rate, such that entry of a numeric
value the way we do it in the SN10 is very difficult. Also high UV
sensitivity. It is definitely a technology to watch but has a long
way to go prior usability for flight computers. As a replacement
for very static display (ie, paper map), it is quite good. Extremely
high contrast (better than newsprint, much much better than LCD).
First consumer product to use this was a Japanese-only eBook
a couple years back, followed by the recently available in USA model.
Best Regards, Dave
PS: Anyone that attended my SSA talks on past&future
glider instrumentation a few years back, already knew this ;-)
Old December 9th 06, 09:11 PM posted to rec.aviation.soaring
Greg Arnold
About time that there is a cell phone with a screen that can be read
when outside.
retail
have
seen.
Old December 9th 06, 09:30 PM posted to rec.aviation.soaring
Greg Arnold
retail
have
seen.
Here is more about the technology, plus a photo of a screen that seems
about the right size for a glider cockpit:
http://linuxdevices.com/news/NS9257262400.html
About digital meters [email protected] Home Built 9 April 17th 06 04:18 AM
Printing off Jepp charts: What paper do you use? Peter R. Instrument Flight Rules 12 January 23rd 06 02:44 AM
Tracking the Elusive Tracing Paper Veeduber Home Built 18 August 30th 04 12:53 PM
