#11
At 14:36 08 December 2006, T O D D P A T T I S T wrote:
wrote: new mac laptop and they made the power cord attach w/a magnet, to keep the computer from hitting the ground when someone trips on the power cord. My wife has a hot pot that constantly holds near-boiling water and dispenses with a pump on request. It uses one of those magnetically attached power cords to prevent anyone from getting burned if you trip over the cord. They must be sold somewhere. -- T o d d P a t t i s t - 'WH' Ventus C (Remove DONTSPAMME from address to email reply.) Wouldn't the magnet ideas cause compass issues? |
Simon Taylor wrote:
At 14:36 08 December 2006, T O D D P A T T I S T wrote: wrote: new mac laptop and they made the power cord attach w/a magnet, to keep the computer from hitting the ground when someone trips on the power cord. My wife has a hot pot that constantly holds near-boiling water and dispenses with a pump on request. It uses one of those magnetically attached power cords to prevent anyone from getting burned if you trip over the cord. They must be sold somewhere. -- T o d d P a t t i s t - 'WH' Ventus C (Remove DONTSPAMME from address to email reply.) Wouldn't the magnet ideas cause compass issues? Microphones and radio speakers have magnets. I don't know how magnetic shielding works but it exists. TV speakers are shielded so they don't interfere with the CRT-at least in those old fashioned TVs :-) Shawn |
Ever tried to pull off an USB connector by pulling across ?!
Any cable on the canopy system is a serious thread. "ContestID67" wrote in message ups.com... Interesting topic. I had considered putting the PDA on the rail of the canopy. One possible simple "break away" connector that was recently recommended to me is a USB connector. They are simple and inexpensive gold plated slide connectors with four contacts. Purchase a USB "extension cord" which has a male and a female connector (don't ask me which is which). Cut the cord in the middle and splice it into your serial connection to the PDA All you need are four connections; USB Pin 1 - Power +5Vdc - DB-9 pin 8 (may be vendor specific) USB Pin 2 - Transmit - DB-9 pin 2 USB Pin 3 - Recieve - DB-9 pin 3 USB Pin 4 - Ground - DB-9 pin 5 Anyway, if you cut the PDA cradle cable, there should only be four wires. Three may be a shield which you should connect to the shield of the USB. Connect each to whatever you want at the USB connector and call it the "fill in your last name proprietary cabling standard". - John |
On Tue, 12 Dec 2006 09:22:59 +0100, Bert Willing wrote:
Ever tried to pull off an USB connector by pulling across ?! Any cable on the canopy system is a serious thread. I have a Volkslogger mounted on the canopy frame of our LS3a. I spliced a male/female pair of "mic" cables into the wire connecting it to the battery such that they will part if the canopy is jettisoned. Some comments: - The screw retaining ring on the plugs has been removed. - The cables on either side of the plugs are secured onto the support post and canopy frame respectively with cable ties. The geometry is such that if the canopy jettison latch is released the load on the wires will always be axial which quickly pulls the plugs apart. - There is a small loop in the cable to allow just enough slack for the canopy to open on its "parallelogram" mechanism without the cable becoming tight. - When the canopy is closed the loop forms in a location where it can't be easily kicked loose on entry/exit or in flight. - A fair amount of planning and testing went into getting it to work just right. These installations are easier to wrong than right. I have tested it a number of times by taking the canopy off without first releasing the cable. It always pulls out cleanly without any force or damage. On the flip side we have yet to loose a trace due to the wire coming loose when it is not supposed to. My mic plugs have 4 pins, of which I am using two so there are two spare. When I finally get around to installing a PDA I have some options to use the same cable for PDA power etc. But when we installed a Flarm I avoided mounting it on the canopy because that would have required a second plug set for the remote display cable. Getting this to work side by side with the existing cable looked a bit tricky. If I did it again I would experiment with RJ45 plugs with the locking tabs broken off. It may be possible to mount two cables in parallel to have enough pairs to meet future requirements. Regards Ian |
I also used male and female sterop plugs for the connections made to the
canopy. The issue that's been bugging me is what to do with the external catheter. In the flurry of an egress, it does take a few moments to disconnect the QD from the drain tubing. Maybe a winter project is a small spring loaded guillotine below the seat pan that would cut the drain tubing. "Ian" wrote in message news ![]() On Tue, 12 Dec 2006 09:22:59 +0100, Bert Willing wrote: Ever tried to pull off an USB connector by pulling across ?! Any cable on the canopy system is a serious thread. I have a Volkslogger mounted on the canopy frame of our LS3a. I spliced a male/female pair of "mic" cables into the wire connecting it to the battery such that they will part if the canopy is jettisoned. Some comments: - The screw retaining ring on the plugs has been removed. - The cables on either side of the plugs are secured onto the support post and canopy frame respectively with cable ties. The geometry is such that if the canopy jettison latch is released the load on the wires will always be axial which quickly pulls the plugs apart. - There is a small loop in the cable to allow just enough slack for the canopy to open on its "parallelogram" mechanism without the cable becoming tight. - When the canopy is closed the loop forms in a location where it can't be easily kicked loose on entry/exit or in flight. - A fair amount of planning and testing went into getting it to work just right. These installations are easier to wrong than right. I have tested it a number of times by taking the canopy off without first releasing the cable. It always pulls out cleanly without any force or damage. On the flip side we have yet to loose a trace due to the wire coming loose when it is not supposed to. My mic plugs have 4 pins, of which I am using two so there are two spare. When I finally get around to installing a PDA I have some options to use the same cable for PDA power etc. But when we installed a Flarm I avoided mounting it on the canopy because that would have required a second plug set for the remote display cable. Getting this to work side by side with the existing cable looked a bit tricky. If I did it again I would experiment with RJ45 plugs with the locking tabs broken off. It may be possible to mount two cables in parallel to have enough pairs to meet future requirements. Regards Ian |
Jim, let's not discuss spring-loaded guillotines and pee tubes in the
same thread! :-) Larry "01" Zero One USA "Jim Vincent" wrote in message : I also used male and female sterop plugs for the connections made to the canopy. The issue that's been bugging me is what to do with the external catheter. In the flurry of an egress, it does take a few moments to disconnect the QD from the drain tubing. Maybe a winter project is a small spring loaded guillotine below the seat pan that would cut the drain tubing. "Ian" wrote in message news ![]() On Tue, 12 Dec 2006 09:22:59 +0100, Bert Willing wrote: Ever tried to pull off an USB connector by pulling across ?! Any cable on the canopy system is a serious thread. I have a Volkslogger mounted on the canopy frame of our LS3a. I spliced a male/female pair of "mic" cables into the wire connecting it to the battery such that they will part if the canopy is jettisoned. Some comments: - The screw retaining ring on the plugs has been removed. - The cables on either side of the plugs are secured onto the support post and canopy frame respectively with cable ties. The geometry is such that if the canopy jettison latch is released the load on the wires will always be axial which quickly pulls the plugs apart. - There is a small loop in the cable to allow just enough slack for the canopy to open on its "parallelogram" mechanism without the cable becoming tight. - When the canopy is closed the loop forms in a location where it can't be easily kicked loose on entry/exit or in flight. - A fair amount of planning and testing went into getting it to work just right. These installations are easier to wrong than right. I have tested it a number of times by taking the canopy off without first releasing the cable. It always pulls out cleanly without any force or damage. On the flip side we have yet to loose a trace due to the wire coming loose when it is not supposed to. My mic plugs have 4 pins, of which I am using two so there are two spare. When I finally get around to installing a PDA I have some options to use the same cable for PDA power etc. But when we installed a Flarm I avoided mounting it on the canopy because that would have required a second plug set for the remote display cable. Getting this to work side by side with the existing cable looked a bit tricky. If I did it again I would experiment with RJ45 plugs with the locking tabs broken off. It may be possible to mount two cables in parallel to have enough pairs to meet future requirements. Regards Ian |
I just did some calculations considering accelerations, masses and mechanics of materials. It turns out that if I stay connected to the pee tube and bail out at under 103 kts, the force of the bail out will extend my penis by 2.8" before the latex tubing breaks (in colder temperatures the max bailout speed does drop). Well, that extension of 2.8" falls just between the elastic and yield (not ultimate) values of my penis, so after extending out by 2.8", my penis will retract by 1.6" for a net permanent gain of 1.2" Mind you, 1.2" is only about a 10% increase over current length, but that's OK too. ;-)
However, after some feedback from some friends, I decided it is best to only connect the quick disconnect when I have to use the pee tube. No need for the guillotine. "01-- Zero One" wrote in message . .. Jim, let's not discuss spring-loaded guillotines and pee tubes in the same thread! J Larry "01" Zero One USA "Jim Vincent" wrote in message : I also used male and female sterop plugs for the connections made to the canopy. The issue that's been bugging me is what to do with the external catheter. In the flurry of an egress, it does take a few moments to disconnect the QD from the drain tubing. Maybe a winter project is a small spring loaded guillotine below the seat pan that would cut the drain tubing. "Ian" wrote in message news ![]() On Tue, 12 Dec 2006 09:22:59 +0100, Bert Willing wrote: Ever tried to pull off an USB connector by pulling across ?! Any cable on the canopy system is a serious thread. I have a Volkslogger mounted on the canopy frame of our LS3a. I spliced a male/female pair of "mic" cables into the wire connecting it to the battery such that they will part if the canopy is jettisoned. Some comments: - The screw retaining ring on the plugs has been removed. - The cables on either side of the plugs are secured onto the support post and canopy frame respectively with cable ties. The geometry is such that if the canopy jettison latch is released the load on the wires will always be axial which quickly pulls the plugs apart. - There is a small loop in the cable to allow just enough slack for the canopy to open on its "parallelogram" mechanism without the cable becoming tight. - When the canopy is closed the loop forms in a location where it can't be easily kicked loose on entry/exit or in flight. - A fair amount of planning and testing went into getting it to work just right. These installations are easier to wrong than right. I have tested it a number of times by taking the canopy off without first releasing the cable. It always pulls out cleanly without any force or damage. On the flip side we have yet to loose a trace due to the wire coming loose when it is not supposed to. My mic plugs have 4 pins, of which I am using two so there are two spare. When I finally get around to installing a PDA I have some options to use the same cable for PDA power etc. But when we installed a Flarm I avoided mounting it on the canopy because that would have required a second plug set for the remote display cable. Getting this to work side by side with the existing cable looked a bit tricky. If I did it again I would experiment with RJ45 plugs with the locking tabs broken off. It may be possible to mount two cables in parallel to have enough pairs to meet future requirements. Regards Ian |
Real glider pilots have no need for pee tubes, quick connects, funnels,
misc. plumbing parts etc. Why do you think they installed that storm window so low on the canopy side instead of directly overhead? Just be sure to slow to below 60 knots prior to "gear" extension to avoid the possibility of flutter - - guaranteed to be an unpleasant experience. Frostbite, though rare, can be nasty. bumper "Jim Vincent" wrote in message . .. I just did some calculations considering accelerations, masses and mechanics of materials. It turns out that if I stay connected to the pee tube and bail out at under 103 kts, the force of the bail out will extend my penis by 2.8" before the latex tubing breaks (in colder temperatures the max bailout speed does drop). Well, that extension of 2.8" falls just between the elastic and yield (not ultimate) values of my penis, so after extending out by 2.8", my penis will retract by 1.6" for a net permanent gain of 1.2" Mind you, 1.2" is only about a 10% increase over current length, but that's OK too. ;-) However, after some feedback from some friends, I decided it is best to only connect the quick disconnect when I have to use the pee tube. No need for the guillotine. "01-- Zero One" wrote in message . .. Jim, let's not discuss spring-loaded guillotines and pee tubes in the same thread! J Larry "01" Zero One USA "Jim Vincent" wrote in message : I also used male and female sterop plugs for the connections made to the canopy. The issue that's been bugging me is what to do with the external catheter. In the flurry of an egress, it does take a few moments to disconnect the QD from the drain tubing. Maybe a winter project is a small spring loaded guillotine below the seat pan that would cut the drain tubing. "Ian" wrote in message news ![]() On Tue, 12 Dec 2006 09:22:59 +0100, Bert Willing wrote: Ever tried to pull off an USB connector by pulling across ?! Any cable on the canopy system is a serious thread. I have a Volkslogger mounted on the canopy frame of our LS3a. I spliced a male/female pair of "mic" cables into the wire connecting it to the battery such that they will part if the canopy is jettisoned. Some comments: - The screw retaining ring on the plugs has been removed. - The cables on either side of the plugs are secured onto the support post and canopy frame respectively with cable ties. The geometry is such that if the canopy jettison latch is released the load on the wires will always be axial which quickly pulls the plugs apart. - There is a small loop in the cable to allow just enough slack for the canopy to open on its "parallelogram" mechanism without the cable becoming tight. - When the canopy is closed the loop forms in a location where it can't be easily kicked loose on entry/exit or in flight. - A fair amount of planning and testing went into getting it to work just right. These installations are easier to wrong than right. I have tested it a number of times by taking the canopy off without first releasing the cable. It always pulls out cleanly without any force or damage. On the flip side we have yet to loose a trace due to the wire coming loose when it is not supposed to. My mic plugs have 4 pins, of which I am using two so there are two spare. When I finally get around to installing a PDA I have some options to use the same cable for PDA power etc. But when we installed a Flarm I avoided mounting it on the canopy because that would have required a second plug set for the remote display cable. Getting this to work side by side with the existing cable looked a bit tricky. If I did it again I would experiment with RJ45 plugs with the locking tabs broken off. It may be possible to mount two cables in parallel to have enough pairs to meet future requirements. Regards Ian |
![]() And L\D refers to Length\Diameter? Bob |
Oh, my!
We didn't get to this conversation until February, a couple of years ago. That one was finished by some PW-5 pilot who claimed to 'tap it' with the rudder. At 19:00 21 December 2006, Bumper wrote: Real glider pilots have no need for pee tubes, quick connects, funnels, misc. plumbing parts etc. Why do you think they installed that storm window so low on the canopy side instead of directly overhead? Just be sure to slow to below 60 knots prior to 'gear' extension to avoid the possibility of flutter - - guaranteed to be an unpleasant experience. Frostbite, though rare, can be nasty. bumper 'Jim Vincent' wrote in message ... I just did some calculations considering accelerations, masses and mechanics of materials. It turns out that if I stay connected to the pee tube and bail out at under 103 kts, the force of the bail out will extend my penis by 2.8' before the latex tubing breaks (in colder temperatures the max bailout speed does drop). Well, that extension of 2.8' falls just between the elastic and yield (not ultimate) values of my penis, so after extending out by 2.8', my penis will retract by 1.6' for a net permanent gain of 1.2' Mind you, 1.2' is only about a 10% increase over current length, but that's OK too. ;-) However, after some feedback from some friends, I decided it is best to only connect the quick disconnect when I have to use the pee tube. No need for the guillotine. '01-- Zero One' wrote in message ... Jim, let's not discuss spring-loaded guillotines and pee tubes in the same thread! J Larry '01' Zero One USA 'Jim Vincent' wrote in message : I also used male and female sterop plugs for the connections made to the canopy. The issue that's been bugging me is what to do with the external catheter. In the flurry of an egress, it does take a few moments to disconnect the QD from the drain tubing. Maybe a winter project is a small spring loaded guillotine below the seat pan that would cut the drain tubing. 'Ian' wrote in message news ![]() On Tue, 12 Dec 2006 09:22:59 +0100, Bert Willing wrote: Ever tried to pull off an USB connector by pulling across ?! Any cable on the canopy system is a serious thread. I have a Volkslogger mounted on the canopy frame of our LS3a. I spliced a male/female pair of 'mic' cables into the wire connecting it to the battery such that they will part if the canopy is jettisoned. Some comments: - The screw retaining ring on the plugs has been removed. - The cables on either side of the plugs are secured onto the support post and canopy frame respectively with cable ties. The geometry is such that if the canopy jettison latch is released the load on the wires will always be axial which quickly pulls the plugs apart. - There is a small loop in the cable to allow just enough slack for the canopy to open on its 'parallelogram' mechanism without the cable becoming tight. - When the canopy is closed the loop forms in a location where it can't be easily kicked loose on entry/exit or in flight. - A fair amount of planning and testing went into getting it to work just right. These installations are easier to wrong than right. I have tested it a number of times by taking the canopy off without first releasing the cable. It always pulls out cleanly without any force or damage. On the flip side we have yet to loose a trace due to the wire coming loose when it is not supposed to. My mic plugs have 4 pins, of which I am using two so there are two spare. When I finally get around to installing a PDA I have some options to use the same cable for PDA power etc. But when we installed a Flarm I avoided mounting it on the canopy because that would have required a second plug set for the remote display cable. Getting this to work side by side with the existing cable looked a bit tricky. If I did it again I would experiment with RJ45 plugs with the locking tabs broken off. It may be possible to mount two cables in parallel to have enough pairs to meet future requirements. Regards Ian |
Who's At Fault in UAV/Part91 MAC? | Larry Dighera | Instrument Flight Rules | 24 | April 29th 04 03:08 PM |
Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 05:39 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
HH-60 ACCIDENT REPORT RELEASED | Otis Willie | Military Aviation | 0 | July 4th 03 03:06 AM |
