#81
"Rip" wrote in message . net... Ray wrote: Looks like airplane treadmill problem, regularly a spark for flame wars on R.A.P., has made it into the mainstream. http://pogue.blogs.nytimes.com/ Let the arguing begin! - Ray Yes, the airplane will take off. The thrust of the engine is against the AIR. NOT the treadmill. There are two real life situations analogous to this: 1) Will an airplane on an essentially frictionless surface (say, wet ice) take off? Of course it will at airspeed X. And it will do so at a power setting that creates airspeed X. 2) Will a sea plane take off upriver in a current equal to it's take-off speed (this one is a cheat, since it involves drag not involved in the original situation, but should be a good "fire starter" for further discussion). Yes it will and it will do so at a power setting that creates airspeed X x2 |
#82
"Travis Marlatte" wrote in message et... "Bob Noel" wrote in message ... In article , Jose wrote: The wheels don't have to push on anything for an aircraft to take off...there's no drivetrain feeding power to the wheels! Right. Phrasing it the way I did may get people to realize this, or at least to think about it themselves. If you put an airplane on the roof of a speeding train, would it take off? What if the train were shaped like a runway? What if it were very thin? hmmmm, if you put the airplane on, say, a fast moving ship, could it take off? I wonder.... -- Bob Noel Looking for a sig the lawyers will hate I don't think so. I've seen videos of planes launching from an aircraft carrier (that's a fast moving ship, right) fall right off the end. I guess it's because the forward motion of the carrier negated the forward thrust of the plane. What you saw was an aircraft that failed to achieve and or retain a critical airspeed. Either the catapult failed or the engine failed or, well any number of things. There is a reason carriers turn into the wind to launch aircraft. There is also a reason that carriers can't launch fixed wing aircraft while tied to the dock. Well they might be able to but a lot of things have to be perfect. |
#83
Rip wrote: Yes, the airplane will take off. The thrust of the engine is against the AIR. NOT the treadmill. The thrust of the engine is not against the air. It generates thrust as a Newtonian reaction to the prop moving air back, not "pushing on other air." A rocket in space has nothing to push against, yet it generates the same thrust as it did in the atmosphere. 1) Will an airplane on an essentially frictionless surface (say, wet ice) take off? Of course, as forward motion creates airflow over the wings. There is no forward motion on the treadmill. 2) Will a sea plane take off upriver in a current equal to it's take-off speed (this one is a cheat, since it involves drag not involved in the original situation, but should be a good "fire starter" for further discussion). Yes, it would, but it's waterspeed at takeoff airspeed would be double the usual takeoff speed. However, this would require considerable power to overcome the extra drag of the floats on the water, being a lot more than wheels on pavement. I have a hard time believing that so many people can't see that it's airflow over wings, not wheel speed or prop blast, that lifts airplanes. What do they think wings are for, anyway? Why don't we discuss something truly valid, like the downwind turn feared by some (especially a few RC modelers) that they think will reduce airspeed and cause a stall? Dan |
#84
"Travis Marlatte" wrote in message et... "Peter Duniho" wrote in message ... "T o d d P a t t i s t" wrote in message news ![]() [...] Agreed, further interpretation is required, although I think the most reasonable interpretation is pretty clear But that's my point. Just as a "reasonable interpretation" is required, one can just as easily assert that a MORE reasonable interpretation would be to assume the question means to discuss a scenario that is at least theoretically possibly to reproduce with existing technology. The question is ambiguous no matter how one looks at it. How can anyone assert that it makes more sense to interpret it in a way that creates a physically impossible situation than to interpret in a way that can at least in theory be tested experimentally? Pete Yup. The question can be interpreted in a couple of different ways. This is what has created the multi-faceted debate. We are not just debating whether the plane will fly given a single scenario. We are arguing about the scenario itself. Stupid, really. I mean, the arguing is stupid. I'm all for discussing alternate scenarios to gain enlightenment (which I got the last round - no new information this time). I happen to believe that the point of the scenario is to illustrate the independence (within limits of friction) of the motion of the plane from its connection to the ground. I think that the alternate scenarios are interesting and have their own merit. However, there are those that clearly do not get the independent nuance of airmotive thrust (e.g. Darkwing). ------------------------------- Travis Lake N3094P PWK That's what I call an INDUSTRIAL STRENGTH nuance! Peter |
#85
#86
thrust as a Newtonian reaction to the prop moving air back, not "pushing on other air." A rocket in space has nothing to push against, yet it generates the same thrust as it did in the atmosphere. Actually, it's not that way. (but read carefully) The thrust of a propeller engine is created when the propeller (an airfoil) creates a high pressure area behind and a low pressure area in front of the prop, as it pushes air back. The prop is pushing against the air in order to do this. The air is constantly trying to get out of the way, but it is not entirely successful, which leads to the pressure differences. There's nothing funamentally wrong in saying that the airplane pushes against the air to move forward. The prop (a part of the airplane) is doing the pushing. Rockets are different. The tail of fire coming out of the rocket does push against the air (push the air out of the way to make room for the fire), but it is =not= part of the rocket. If there were no air to "push against", the rocket would work just as well, for that reason. Where the rocket gets its thrust is the tail of fire pushing (the other way) against the engine bell of the rocket itself. The rocket is pushing against the fire, in essence. The fire is =not= part of the rocket. Both cases can be viewed in the newtonian "action/reaction" paradigm, but something has to push against something else in order to get the thrust to happen in the first place. In a plane, the propeller pushes against the air (to make the air go backwards fast and create thrust. In a rocket, the engine bell pushes against the tail fire (pushing the fire out, and the rocket forward). I suppose it may be clearer to say that the expanding gasses of the tail fire push against the engine bell, but the two are equivalent. Although the expanding rocket gasses do push the air out of the way, that doesn't help the rocket in any meaningful way. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
#87
ups.com... Rip wrote: Yes, the airplane will take off. The thrust of the engine is against the AIR. NOT the treadmill. The thrust of the engine is not against the air. It generates thrust as a Newtonian reaction to the prop moving air back, not "pushing on other air." A rocket in space has nothing to push against, yet it generates the same thrust as it did in the atmosphere. 1) Will an airplane on an essentially frictionless surface (say, wet ice) take off? Of course, as forward motion creates airflow over the wings. There is no forward motion on the treadmill. 2) Will a sea plane take off upriver in a current equal to it's take-off speed (this one is a cheat, since it involves drag not involved in the original situation, but should be a good "fire starter" for further discussion). Yes, it would, but it's waterspeed at takeoff airspeed would be double the usual takeoff speed. However, this would require considerable power to overcome the extra drag of the floats on the water, being a lot more than wheels on pavement. I have a hard time believing that so many people can't see that it's airflow over wings, not wheel speed or prop blast, that lifts airplanes. What do they think wings are for, anyway? Why don't we discuss something truly valid, like the downwind turn feared by some (especially a few RC modelers) that they think will reduce airspeed and cause a stall? Dan And, after we've resolved that one, we can move on to the turn to the final turn for a left crosswind landing from a tight left pattern or a right crosswind landing from a tight right pattern. Peter |
#88
You have to remember that the plane's airspeed is completely independent of
its wheel speed. As you know, a plane can have sufficient airspeed to fly even if the wheels are stopped, and it can have insufficient airspeed even if the wheels are spinning at 200 mph. The treadmill spins the wheels - it has absolutely no affect on airspeed. The plane gathers airspeed by means of the propeller acting on the surrounding air. No matter how fast the treadmill belt is moving it is not taking the surrounding air with it. If you tie a rope to the wall and then sit in a wheelchair on the treadmill, as long as you hold onto the rope the chair will not move no matter how fast the treadmill goes. Likewise, by simply pulling on the rope you can move yourself forward on the treadmill no matter how fast the belt is going. The reason is because the force moving you forward on the treadmill (pulling on the rope) is not related at all to how fast the belt is going. The plane is "pulling on the rope" (air) using its propeller - it doesn't care what its wheels are doing. BDS "Darkwing" theducksmail"AT"yahoo.com wrote How is that possible if the wings are stationary? Are you saying the thing will take off due to the pure power setting to keep up at 25mph (or whatever), nothing to do with the wings? --------------------------------- DW |
#89
On Wed, 13 Dec 2006 17:29:04 GMT, "BDS" wrote:
You have to remember that the plane's airspeed is completely independent of its wheel speed. As you know, a plane can have sufficient airspeed to fly even if the wheels are stopped, and it can have insufficient airspeed even if the wheels are spinning at 200 mph. The treadmill spins the wheels - it has absolutely no affect on airspeed. The plane gathers airspeed by means of the propeller acting on the surrounding air. No matter how fast the treadmill belt is moving it is not taking the surrounding air with it. If you tie a rope to the wall and then sit in a wheelchair on the treadmill, as long as you hold onto the rope the chair will not move no matter how fast the treadmill goes. Likewise, by simply pulling on the rope you can move yourself forward on the treadmill no matter how fast the belt is going. The reason is because the force moving you forward on the treadmill (pulling on the rope) is not related at all to how fast the belt is going. The plane is "pulling on the rope" (air) using its propeller - it doesn't care what its wheels are doing. BDS OK ! I'm putting my pa-28-140 on a treadmill and will report back to clear this up once and for all. "Darkwing" theducksmail"AT"yahoo.com wrote How is that possible if the wings are stationary? Are you saying the thing will take off due to the pure power setting to keep up at 25mph (or whatever), nothing to do with the wings? --------------------------------- DW Daveb |
#90
On Wed, 13 Dec 2006 19:04:48 GMT, (DaveB) wrote:
On Wed, 13 Dec 2006 17:29:04 GMT, "BDS" wrote: You have to remember that the plane's airspeed is completely independent of its wheel speed. As you know, a plane can have sufficient airspeed to fly even if the wheels are stopped, and it can have insufficient airspeed even if the wheels are spinning at 200 mph. The treadmill spins the wheels - it has absolutely no affect on airspeed. The plane gathers airspeed by means of the propeller acting on the surrounding air. No matter how fast the treadmill belt is moving it is not taking the surrounding air with it. If you tie a rope to the wall and then sit in a wheelchair on the treadmill, as long as you hold onto the rope the chair will not move no matter how fast the treadmill goes. Likewise, by simply pulling on the rope you can move yourself forward on the treadmill no matter how fast the belt is going. The reason is because the force moving you forward on the treadmill (pulling on the rope) is not related at all to how fast the belt is going. The plane is "pulling on the rope" (air) using its propeller - it doesn't care what its wheels are doing. BDS OK ! I'm putting my pa-28-140 on a treadmill and will report back to clear this up once and for all. "Darkwing" theducksmail"AT"yahoo.com wrote How is that possible if the wings are stationary? Are you saying the thing will take off due to the pure power setting to keep up at 25mph (or whatever), nothing to do with the wings? --------------------------------- DW Daveb Forgot to mention I will use two treadmills one for each wheel so I can control the speed on both. Daveb |
| VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 7th 06 12:13 AM |
| Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 8th 05 12:17 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 09:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 09:27 AM |
