Instrument Rating Foreign Pilot
Old December 13th 06, 10:35 PM posted to rec.aviation.ifr
gwengler
Default Instrument Rating Foreign Pilot
I need to get my FAA license upgraded. Currently it is ME, VFR, based
on my Canadian ME IFR ATPL. To have it include IFR, I have to write
the FAA Knowledge Test "Instrument Rating - Foreign Pilot (IFP)". I
cannot find/google what exactly is being tested for the IFP: Is it
questions from the whole IFR question catalogue or is it questions
pertaining only to certain areas like "instrument flight rules and
related procedures"?
Any idea anyone?
Gerd
Old December 14th 06, 12:27 AM posted to rec.aviation.ifr
Mitty
On 12/13/2006 4:35 PM, gwengler wrote the following:
Any idea anyone?
Gerd
It looks like about everything is covered. 946 total possible questions
covering all topics you might think of. By comparison, the regular Instrument
written is 930 questions. Both have the same 11 topic areas.
I got this info from the Dauntless Groundschool program that I used for my
written. It's a $30 download from faatest.com and unlocking the Instrument tests
gives you access to all 8 of them including instructor and helicopter tests. I
have no financial interest in the product but I have been very pleased with it.
Got 100% on my Instrument written using an earlier version than what is now
current, so it's probably better now.
Old December 14th 06, 02:02 AM posted to rec.aviation.ifr
Jim Macklin
You are limited to private pilot privileges, no commercial
ops, even though you hold a Canadian ATPL. You can fly "for
hire" in the USA if you are in a Canadian aircraft.
You might consider studying for the US ATP and taking the
ride, you will surrender the FP certificate, but you will be
ahead.
You don't need any sign off, you have a choice of a 135 or a
121 based test.
"gwengler" wrote in message
VFR, based
have to write
(IFP)". I
IFP: Is it
questions
rules and
| Any idea anyone?
| Gerd
Old December 14th 06, 12:40 PM posted to rec.aviation.ifr
Ron Natalie
Instrument written is 930 questions. Both have the same 11 topic areas.
My guess is the extra questions would be the helicopter, etc.
questions. The normal Instrument Rating test is specific
to category (Airplane, Helicopter, ...). The instructor test
however is not so you might see the category specific questions
from any of the categories.
Old December 14th 06, 08:03 PM posted to rec.aviation.ifr
Chris
Just work on the basis of the regular IR knowledge test which you should
manage. I think the foreign pilots test has 50 questions as opposed to the
regular 60 but what the hell it only takes about 40 minutes to do.
Any idea anyone?
Gerd
Old December 14th 06, 08:21 PM posted to rec.aviation.ifr
tscottme
Any idea anyone?
Gerd
I worked for a large flight school that administered written tests. One
thing that came up pretty often was confusion between the Instrument-Foreign
Pilot written test and the more common Instrument Rating Airplane written
test. While the two written tests cover virtually the exact same FAA
questions, they are not the same test. It was pretty common for
flight/ground instructors to sign off a student to take the conventional IR
test when the student should have received the IR-Foreign Pilot sign off.
Make sure your paperwork clearly indicates your test is the test you expect.
If you study for one test you will be prepared to pass either test, but the
sign off and the FAA paperwork does distinguish between the two tests. We
would get students signed off for the IR-Airplane when they needed the IR-FP
test. One authorization doesn't cover both tests. Even had they passed the
incorrect IR written test, it probably would have been caught by the FAA.
Instead of receiving the license in the mail sever weeks later, you could
receive notice of a mistake. It's a pretty small detail, but it's quicker
to prevent than fix after the fact.
Scott
Old December 14th 06, 10:13 PM posted to rec.aviation.ifr
Jim Macklin
I would check with the FSDO I don't think that the foreign
pilot needs an instructor endorsement to take the FP IR
test. The ATP does not for any pilot the first time.
"tscottme" wrote in message
ME, VFR, based
have to write
Pilot (IFP)". I
IFP: Is it
questions
rules and
| Any idea anyone?
| Gerd
written tests. One
Instrument-Foreign
Airplane written
exact same FAA
common for
the conventional IR
Pilot sign off.
the two tests. We
had they passed the
caught by the FAA.
later, you could
but it's quicker
| Scott
Old December 15th 06, 09:25 AM posted to rec.aviation.ifr
tscottme
"Jim Macklin" wrote in message
news
I don't mean to indicate a foreign ATP needs an instructor endorsement. My
emphasis was on making sure everyone, applicant, tester, etc. not confuse
the IR Airplane written test for the IR-Foreign Pilot written test. My
experience showed that people that should know better would often confuse
the common IR test for the less common IR test. Just because the written
tests are almost nearly identical, one will not substitute for the other
test.
Scott
Old December 15th 06, 10:51 AM posted to rec.aviation.ifr
Jim Macklin
That is very true. Paperwork is the most important thing to
the FAA.
| "Jim Macklin" wrote
in message
| news | I would check with the FSDO I don't think that the
foreign
endorsement. My
etc. not confuse
written test. My
would often confuse
because the written
for the other
| test.
| Scott
Old December 16th 06, 01:44 AM posted to rec.aviation.ifr
Andrew Sarangan
You will run into a lot of red tape, and interpretations that will vary
from one inspector to the next. Once upon a time I tried to do the same
- add an instrument rating to the Restricted Private pilot certificate
issued on the basis of my Canadian license. It was way more trouble
than it was worth. So I just retook the private pilot checkride, and
then the IR checkride.
Any idea anyone?
Gerd
Instrument rating prerequisites [email protected] Instrument Flight Rules 10 September 13th 06 02:18 AM
Canadian PPL transition to USA Jase Vanover Piloting 3 November 27th 05 01:44 AM
question about instrument proficiency check Sylvain Instrument Flight Rules 14 October 20th 05 09:11 AM
