Okay, I know I've seen a lot of engineers and technical folks on here.
I have a complex math problem relating to the classic wind triangle that I posted on sci.math and received little response. I don't know if they're stumped or just not interested. :-) Here is a copy of my original post and the only useful response I received. Anyone have a solution? (For the controllers here, this is an enhancement we are trying to add to the Falcon program that centers will see next year, which was developed by a controller here at ZKC.) Chad Speer PP-ASEL, IA ATCS, Kansas City ARTCC ************************************************** * ************************************************** * My original post: ***** I am helping someone with a program that estimates wind speed and direction using radar data from aircraft. I need help finding a formula that can determine the wind speed and direction when given the following information for multiple aircraft: direction of travel speed across the ground speed through the air The direction of travel and the speed across the ground are taken from the radar data. The speed through the air is taken from the pilot's flight plan. We're air traffic controllers trying to improve our training tools, so we get access to all the goodies. I know that with information from just one aircraft, the possibilities are endless for the wind speed and direction. I think it is possible to use the same data from two or more aircraft to determine the wind speed and direction. I thought I could come up with a formula to solve this, but the need to reference everything to north in order to achieve actual directions instead of just angles took it way above my head. Basically, you are given the lengths of two adjacent sides of many different triangles. You also know the angle of one of those sides (aircraft direction) with respect to a known reference (north). The properties common to all of the triangles, which are unknown, are the length of the third side (wind speed) and the angle of that third side (wind direction) with respect to a known reference (north). If I have not described this well enough, I can upload some diagrams to a web page to simplify the problem. I would really be grateful if someone is able to solve this! ***** A useful response: ***** Interesting problem. For the single aircraft, case, let: Wd, Ws be wind direction and speed. Ad, As be aircraft direction and speed (relative to the air, not the ground). Gd, Gs be aircraft direction and speed (relative to the ground). Representing each vector as a 2-tuple of (direction, magnitude) gives: (Gd, Gs) = (Ad, As) + (Wd, Ws) The unknowns are Ad, Ws, and Wd. (Note that As is known due to filed information, i.e. a pilot will know how fast his aircraft cruises.) Splitting into x- and y-components will result in 2 equations with 3 unknowns. I agree that there are infinitely many solutions in the single-aircraft case. For the two-aircraft case (and I'll just suffix with 1 and 2), we have: (Gd1, Gs1) = (Ad1, As1) + (Wd, Ws) (Gd2, Gs2) = (Ad2, As2) + (Wd, Ws) where of course we assume that the wind affecting each aircraft (since they are presumably not too many tens of miles apart) is the same. Breaking into x- and y-components leads to 4 equations and 4 unknowns (Ad1, Ad2, Wd, Ws). The 2-aircraft case probably has a unique solution. We have: Gs1 * cos(Gd1) = As1 * cos(ad1) + Ws * cos(Wd) Gs1 * sin(Gd1) = As1 * sin(ad1) + Ws * sin(Wd) Gs2 * cos(Gd2) = As2 * cos(ad2) + Ws * cos(Wd) Gs2 * sin(Gd2) = As2 * sin(ad2) + Ws * sin(Wd) One can probably square equations, add, and make use of the relationship that sin^2(x) + cos^2(x) = 1. I'm not sure what the form of the solution would be. I'm too lazy to work it out. It will be messy. I believe at first glance that the 2-aircraft case has a single unique solution (4 equations, 4 unknowns). However, moving on to more than 2 aircraft ... If there are more than 2 aircraft, the system is "overspecified" (there is a mathematical term for this, but it has been so long ...). You probably want a way to pick a single best solution among the infinitely many, assuming that you have some "noise" in the data. The style of solution you want is probably about the same as a "least-squares" solution to a system of linear equations, i.e. http://www.mathresource.iitb.ac.in/l...hapter8.5.html I would need to do some thinking about how to phrase this problem as a least-squares problem (the sines and cosines above put doubts in my head), but there is probably a way to do it. So, out of a group of data for at least 2 aircraft, you should be able to grind out a solution that is unique according to some constraints and assumptions. To summarize my thoughts: a)1 aircraft -- system not solvable. b)2 aircraft -- system has one solution, but I'm too lazy to do the algebra. c)3 or more aircraft -- system is overspecified, and some least squares approach should give a solution. One more thought: I've spent a fair amount of time in little Cessnas. It has been my experience that wind direction and speed won't vary too much over distance, but may vary EXTREMELY with altitude. I've flown on days when the winds at 3,000 feet were 15 knots and the winds at 6,000 feet were 50 knots (or at least this is my memory). I accept the assumption that winds affecting aircraft at the same altitude that are within maybe 20NM of each other are about the same. But I do not accept the assumption that winds at different altitudes are similar -- my experience says otherwise. If you agree, this adds yet another dimension to the problem. (BTW, near the end of my student training, I used to like to fly in heavy crosswinds to practice technique. We have an airport about 20NM North of our local airport with a roughly perpendicular runway, and I discovered that if the wind was blowing straight down the runway here I could get a perfect crosswind to practice with just by going N and using the other airport. The surface winds were always about the same at both airports. That is why I'm comfortable with the assumption that winds don't vary much over relative short distances.) Good problem. I am not a mathematician. I hope others can add more insight. ***** |
"Chad Speer" wrote in message ups.com... Okay, I know I've seen a lot of engineers and technical folks on here. I have a complex math problem relating to the classic wind triangle that I posted on sci.math and received little response. I don't know if they're stumped or just not interested. :-) Here is a copy of my original post and the only useful response I received. Anyone have a solution? (For the controllers here, this is an enhancement we are trying to add to the Falcon program that centers will see next year, which was developed by a controller here at ZKC.) Chad Speer PP-ASEL, IA ATCS, Kansas City ARTCC ************************************************** * ************************************************** * My original post: ***** I am helping someone with a program that estimates wind speed and direction using radar data from aircraft. I need help finding a formula that can determine the wind speed and direction when given the following information for multiple aircraft: direction of travel speed across the ground speed through the air The direction of travel and the speed across the ground are taken from the radar data. The speed through the air is taken from the pilot's flight plan. We're air traffic controllers trying to improve our training tools, so we get access to all the goodies. I know that with information from just one aircraft, the possibilities are endless for the wind speed and direction. I think it is possible to use the same data from two or more aircraft to determine the wind speed and direction. I thought I could come up with a formula to solve this, but the need to reference everything to north in order to achieve actual directions instead of just angles took it way above my head. snip Chad if you know HDG ( ie where you are pointing), GS and TAS then there is only 1 possibility for the wind speed and direction. these can be calculated from the cosine rule. If you know the cosine rule and the sine rule for triangles you can calculate a lot of things. to apply both of these rules draw yourself a little triangle and mark the sides small a,b and c. then mark the angles capital A,B and C where angle A is opposite side a and angle B is opposite side b. cosine rule a^2 = b^2 +c^2 - 2bc cos( A) sine rule a/sin A = b/sin B = c /sin C in the case of the NAV triangle WS= SQRT( GS^2+TAS^2 =2*GS*TAS*cos(HDG-TR)) where WS= windspeed GS = ground speed TAS = airspeed HDG = heading(where you are pointing) TR = track ( where you are going) If you want I can email you an excel spreadsheet that has this already coded. you just enter your TAS, GS and HDG and it will give you the WS and Wind direction. Terry PPL |
d&tm schrieb:
if you know HDG ( ie where you are pointing), GS and TAS then there is only 1 possibility for the wind speed and direction. Actually, there are two. But the question was a different one. It has already been answered pretty well, all what remains is to do the dirty work and shuffling some formulas. Stefan |
Terry - thanks for the reply, but heading is not known.
Stefan - we need to be able to plug these known values into a formula and kick out a result. Assuming the original responder was on the right track, I still don't know what to do with his suggestion. Any ideas on that? I'm not lazy, this just went over my head a long time ago. :-) Chad Speer PP-ASEL, IA ATCS, Kansas City ARTCC |
Stefan wrote: d&tm schrieb: if you know HDG ( ie where you are pointing), GS and TAS then there is only 1 possibility for the wind speed and direction. Actually, there are two. Eh? Not to sidetrack the thread too much, but how could there be two wind answers? For example on the E-6B, to solve this, you'd set TRACK up, grommet over GS, and then look for where your TAS arc meets your drift correction angle (HDG-TRACK). The vector back to the grommet is the single direction and speed for the wind. Thanks, Kev |
"Stefan" wrote in message ... d&tm schrieb: if you know HDG ( ie where you are pointing), GS and TAS then there is only 1 possibility for the wind speed and direction. Actually, there are two. I give up, can you please explain how there can be 2 ? |
"Chad Speer" wrote in message oups.com... Terry - thanks for the reply, but heading is not known. Stefan - we need to be able to plug these known values into a formula and kick out a result. Assuming the original responder was on the right track, I still don't know what to do with his suggestion. Any ideas on that? I'm not lazy, this just went over my head a long time ago. :-) Chad, sorry misread the question. But I like a challenge so I had another go. Firstly I dont believe the equations given by the original poster are correct. if you apply the cosine rule to the wind triangle for 2 aircraft you get the following 2 equations. TAS1^2=WS^2+GS1^2-2WSGS1COS(180-ABS(WD-TR1) TAS2^2=WS^2+GS2^2-2WSGS2COS(180-ABS(WD-TR2) WHERE TAS1 AND TAS2 ARE TRUE AIRSPEEDS FOR AIRCRAFT 1 AND 2 WS = WIND SPEED WD =WIND DIRECTION IN DEGREES MAG TR1 AND TR2 ARE TRACKS MAGNETIC FOR AIRCRAFT 1 AND 2 GS1 AND GS2 ARE GROUND SPEEDS FOR AIRCRAFT 1 AND 2. (180-ABS(WD-TR) WILL GIVE YOU THE ACTUAL ANGLE BETWEEN WIND DIRECTION AND TRACK. Now we have 2 equations with 2 unknowns ( WS and WD) which should be solvable but I am stuggling to get it out. However I did a little exercise which suggests the end result may not be very useful. because small errors in the ground speeds will cause very large errors in the calculated wind speed. By subtracting the 2 equations above you get WS=(GS2^2-GS1^2-TAS2^2+TAS1^2)/(2(GS2COS(180-ABS(WD-TR2)-GS1COS(180-ABS(WD-T R1)) What I then did was calculate the ground speeds for 2 aircraft for a known wind of 20 kts from 220 M aircraft 1 aircraft 2 TAS 120 100 GS 111.7 91.4 TR 290 150 If I then use my above equation for WS after setting wind direction to 220, I get 20 kts as expected. However if I round off the GS to 112 and 91 kts the Wind speed changes from 20 to 9.5kts which suggests the ground speeds have to be super accurate to get anywhere near the right wind speed.. Given that also you are taking the TAS from a flight plan, which will vary with density altitude and RPM setting etc. suggests your objective is going to be rather difficult to achieve in practice. Hope this helps and good luck. If you come up with the solution I would love to see it. terry |
"d&tm" wrote in message ... "Chad Speer" wrote in message oups.com... Terry - thanks for the reply, but heading is not known. Stefan - we need to be able to plug these known values into a formula and kick out a result. Assuming the original responder was on the right track, I still don't know what to do with his suggestion. Any ideas on that? I'm not lazy, this just went over my head a long time ago. :-) Chad, sorry misread the question. But I like a challenge so I had another go. Firstly I dont believe the equations given by the original poster are correct. if you apply the cosine rule to the wind triangle for 2 aircraft you get the following 2 equations. TAS1^2=WS^2+GS1^2-2WSGS1COS(180-ABS(WD-TR1) TAS2^2=WS^2+GS2^2-2WSGS2COS(180-ABS(WD-TR2) WHERE TAS1 AND TAS2 ARE TRUE AIRSPEEDS FOR AIRCRAFT 1 AND 2 WS = WIND SPEED WD =WIND DIRECTION IN DEGREES MAG TR1 AND TR2 ARE TRACKS MAGNETIC FOR AIRCRAFT 1 AND 2 GS1 AND GS2 ARE GROUND SPEEDS FOR AIRCRAFT 1 AND 2. (180-ABS(WD-TR) WILL GIVE YOU THE ACTUAL ANGLE BETWEEN WIND DIRECTION AND TRACK. Now we have 2 equations with 2 unknowns ( WS and WD) which should be solvable but I am stuggling to get it out. However I did a little exercise which suggests the end result may not be very useful. because small errors in the ground speeds will cause very large errors in the calculated wind speed. By subtracting the 2 equations above you get WS=(GS2^2-GS1^2-TAS2^2+TAS1^2)/(2(GS2COS(180-ABS(WD-TR2)-GS1COS(180-ABS(WD-T R1)) What I then did was calculate the ground speeds for 2 aircraft for a known wind of 20 kts from 220 M aircraft 1 aircraft 2 TAS 120 100 GS 111.7 91.4 TR 290 150 If I then use my above equation for WS after setting wind direction to 220, I get 20 kts as expected. However if I round off the GS to 112 and 91 kts the Wind speed changes from 20 to 9.5kts which suggests the ground speeds have to be super accurate to get anywhere near the right wind speed.. Given that also you are taking the TAS from a flight plan, which will vary with density altitude and RPM setting etc. suggests your objective is going to be rather difficult to achieve in practice. Hope this helps and good luck. If you come up with the solution I would love to see it. terry should have mentioned in 180- ABS( WD-TR) ABS is absolute , ignore negatives. terry |
Lots of fun to play with the formulas... But, the fly in the ointment
here is that the airspeed filed by the pilot is a canned number and has nothing to do with reality... I fly IFR, I file the same airspeed - 130 kt - for all flights regardless of load, altitude, and what the power setting winds up to be... If the actual airspeed in your problem is within 15% of the filed number you will be lucky... denny |
Kev schrieb:
Eh? Not to sidetrack the thread too much, but how could there be two wind answers? Mathematically: There are always two square roots which solve the equation: A positive and a negative. Physically: If you only know GS, TAS and HDG, then you don't know whether the wind blows from the let or from the right. (If you also know the track, then of course there's only one solution.) Stefan |
| Help with 152 math | pittss1c | Piloting | 12 | May 13th 05 02:47 PM |
| Another Math Question | Dan Nafe | Home Built | 2 | May 4th 05 02:50 AM |
| # of Aircraft Club Members - Math Formula Wanted | Rich | Owning | 3 | September 16th 04 05:08 PM |
| Math help request ? | Snead1 | Soaring | 5 | June 9th 04 12:15 AM |
| Student invents new math process | Otis Willie | Military Aviation | 29 | December 2nd 03 03:13 AM |
