IFR Cancellation Question
Old December 18th 06, 11:04 PM posted to rec.aviation.ifr
Steven P. McNicoll
Default IFR Cancellation Question
"Alan Gerber" wrote in message
Underneath the New York Class B airspace: TEB (Teterboro), MMU
(Morristown), CDW (Caldwell), HPN (Westchester), and FRG (Farmingdale) -
all pretty busy Class D airports.
When you're in any of that Class D airspace, do you feel you should be
talking to the tower or still on flight following?
  #132
Old December 18th 06, 11:16 PM posted to rec.aviation.ifr
Steven P. McNicoll
I don't know. How do you mean "should" he as what's best, or as
what's standard procedure? I've only experienced having them wait to
terminate until I had the field in sight.
Instructing VFR aircraft on flight following to advise when they have the
field in sight is not standard procedure and does not have any useful
purpose.
When *is* "time to switch"? Again, I had thought - by inferring from how
I've been handled - that it's time to switch when I actually have the
field in sight.
It's time to switch at a point that will allow the aircraft to contact the
tower before entering Class D airspace.
Because if I'm having trouble spotting the field, either I need help
because it's hard to find, or I'm just not in the right place (i.e.,
"lost"), and need help finding it because I'm lost.
How is keeping flight following, by itself, beneficial in those cases?
  #133
Old December 18th 06, 11:21 PM posted to rec.aviation.ifr
Mark Hansen
Is there a reason why the pilot should not be on flight following once he
enters Class D airspace?
The controller will hand you off to the tower when both are ready for you.
To the original poster: Sighting the field is not what is needed to have
the FF controller hand you off to the tower controller. I think because
this has happened to you a few times, you may have gotten the wrong
impression.
The FF controller is not waiting for you to find the field. He assumes you
know where you're going. He is not providing directions to you (unless
you ask for it, of course).
Telling the FF controller that you have the field in sight is just a polite
way of letting the controller know that you're ready to be handed off to
the tower. It is not necessary. The FF controller will hand you off when
he and the tower controller are ready for you. If you want it sooner, just
ask: "XXX Approach, Cessna XXXX, Request frequency change to XXX tower",
or just terminate flight following.
As to whether or not you've spotted the field, this has little to do with
either controller - again, they assume you know where you're going. If you
need help, ask either one.
Hope this helps,
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
  #134
Old December 18th 06, 11:42 PM posted to rec.aviation.ifr
Steven P. McNicoll
"Mark Hansen" wrote in message
Yes, if he's not talking to the tower when he enters Class D airspace he's
busted FAR 91.129(c)(1).
How does that work?
polite
As I recall the issue was why do some controllers tell VFR aircraft on
flight following to report the field in sight.
  #135
Old December 19th 06, 01:26 AM posted to rec.aviation.ifr
Mark Hansen
No, his communication requirements are met by maintaining communication
with the ATC facility providing flight following.
How does that work?
polite
I was responding to your question, which was:
Sacramento, CA
  #136
Old December 19th 06, 01:35 AM posted to rec.aviation.ifr
Steven P. McNicoll
How is that done?
  #137
Old December 19th 06, 01:46 AM posted to rec.aviation.ifr
Mark Hansen
How is that done?
What do you mean "how is it done?" The pilot is in communication
with ATC, the reg says the pilot must be in communication with
ATC.
Sacramento, CA
  #138
Old December 19th 06, 02:21 AM posted to rec.aviation.ifr
Steven P. McNicoll
ATC.
Communication with any ATC facility satisfies the requirements of the reg?
Doesn't the reg specify communication with the ATC facility providing air
traffic services in that airspace?
  #139
Old December 19th 06, 02:42 AM posted to rec.aviation.ifr
Mark Hansen
ATC.
Yes.
  #140
Old December 19th 06, 02:54 AM posted to rec.aviation.ifr
Steven P. McNicoll
ATC.
reg?
Yes.
Which question are you answering?
Lyc. O-360 cylinder question JB Owning 13 November 27th 04 09:32 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
Partnership Question Harry Gordon Owning 4 August 16th 03 11:23 PM
