Time travel
Old December 19th 06, 12:36 AM posted to rec.aviation.military.naval
Jim[_10_]
Default Time travel
We haven't played with this for some time now. Seeing as how we have
newer members let's see how this plays out.
You have the opportunity to travel back to the '50s, '60's, '70s'. You
may select any airframe of that era and "rebuild" it with modern
engines, avionics, etc. The basic dimensions of the airframe must
remain reasonably the same. (translation: the fuselage might be
expanded to accommodate a more modern engine, but not go from a single
engine to a dual engine design) Of course ultimately you might need to
engage your pick in combat against the newer aircraft.
So which would you pick? And why? U.S. or other airframes.
ACC USN ret.
NKX, BIKF, NAB, CV-63, NIR
67-69 69-71 71-74 77-80 80-85
74-77
Founder: RAMN (rec.aviation.military.naval)
Old December 19th 06, 03:52 AM posted to rec.aviation.military.naval
Gordon[_1_]
Default Time travel
Why not start with the ultimate 50s-60s-70s aircraft? Take an SR-71
and do wizard stuff to that - it would have some amazing possibilites
if it were built with everything available today. It would end up
needing docking capability for refueling from the ISS!
v/r Gordon
Old December 19th 06, 08:03 AM posted to rec.aviation.military.naval
Jeroen Wenting
Default Time travel
"Gordon" wrote in message
v/r Gordon
What modern engines would you fit to an SR-71 that would not destroy its
aerodynamic profile yet enable it to work both in the earth's atmosphere and
outside it?
Such engines don't at the moment exist. The scramjets being tested are built
into the aerodynamic structure of the craft so are out of the question given
the restrictions you have been handed, adding rocket motors to the SR-71
would be impractical (you might mount one on the top of the fuselage where
the old drone attachments are situated I guess, but I doubt that would drive
it up to over 200km altitude).
Vacuum sealing the fueltanks and avionics bays would also be a major
problem, certainly if you don't want to replace the entire airframe
structure and panelling with different materials.
Let's try a more modest approach, the TSR.2.
Fit it with the avionics and weapons systems of the F/A-18E/F or F-35 and
the engines of the F-22, add some RAM to critical areas (leading edges
mainly), and I think you have a rather interesting ground attack/penetration
strike platform with limited multi-role capabilities.
Old December 19th 06, 08:13 AM posted to rec.aviation.military.naval
Gordon[_1_]
Default Time travel
outside it?
Did the original poster say I had to solve all the engineering
questions to make it work? No. It was a simple "what if", which I
answered.
For several years, they tested a "canoe" with an X-33 prototype engine
in exactly that location. Is that what you meant?
No where in the original post did he say I had to come up with the
engineering changes and adapter kits to make it work. Forget I
bothered to post.
Gordon
Old December 19th 06, 01:48 PM posted to rec.aviation.military.naval
Jeroen Wenting
Default Time travel
ps.com...
and
outside it?
answered.
I did read it as stating that major changes to the airframe design are not
allowed, only minor changes like to the size of the engine bays.
Old December 19th 06, 06:48 PM posted to rec.aviation.military.naval
John[_1_]
Default Time travel
ACC USN ret.
74-77
Ha ha . . . I wonder if I would be crazy to suggest . . . the Vought
F7U Cutlass (aka Gutless, aka Ensign Killer [probably one of several
deserving of that name[)
Replace the POS's that it had for engines with a pair of real
powerplants (no, I'm not sure what would fit), install a triple, no
quad (it is a Cutlass afterall) redundant fly-by wire system. Wire it
for AMRAAM and a short range IR dogfight missle). Replace the canopy
with something the pilot can see out of towards the tail.
If I can get someone very clever to the play with the aerodynamics,
figure out a way to trick the air flowing over the wings in such a way
that it could be flown slow with less deck angle, to improve visibility
and to allow for a shorter and lighter nose gear. The FBW should help
with this.
Since I am at the end of my lunch hour, I will stop here . . . but
that's a start. I always thought the F7U was a pretty plane, maybe it
could be tamed and made friendlier. And don't bother . . . I already
know about the crazy part
Blue skies . . .
John
Old December 19th 06, 10:32 PM posted to rec.aviation.military.naval
TV
Default Time travel
F-14 or F-15 from the 70's.
F-4 from the 60s.
F-8 from the 50s.
Because they're all proven airframes. Maybe redo the Scooter from the 50s
if you want a strike platform.
Old December 19th 06, 10:52 PM posted to rec.aviation.military.naval
Jim[_10_]
Default Time travel
Let's try a more modest approach, the TSR.2. Fit it with the avionics
and weapons systems of the F/A-18E/F or F-35 and the engines of the
F-22, add some RAM to critical areas (leading edges mainly), and I
think you have a rather interesting ground attack/penetration strike
How about the same approach to the RA-5C of which appears to be a direct
offspring?
ACC USN ret.
74-77
Old December 20th 06, 02:10 AM posted to rec.aviation.military.naval
WaltBJ
Default Time travel
Either a turbo DC3/C47 or a PBY5 with an added PT6 on centerline. Good
autopilot, radar and loran/loran-C. I'm not the least bit interested in
getting back into combat. Either of those birds can go just about
anywhere that matters to me.
Walt BJ
Old December 20th 06, 02:41 AM posted to rec.aviation.military.naval
John[_1_]
Default Time travel
Good answer . . . but. . . . wouldn't GPS be better than LORAN (cripes
I hope I dont start a flame war over this.
Blue skies . . .
John
P.S.: Walt . . . you seem to have a fair number of interesting flying
stories . . . did you ever consider writing a book?
Walt BJ
Gyrocopter Speed Mark Rotorcraft 36 August 16th 05 11:28 PM
