Anyone flown atn LPV yet?
Old December 17th 06, 02:12 AM posted to rec.aviation.ifr
Sam Spade
Default Anyone flown atn LPV yet?
John R. Copeland wrote:
"Ron Rosenfeld" wrote in message ...
Yes, the approaches are a pleasure to fly, but the step change in course
width can cause a coupled approach to give a small disturbance, for me.
If the needle isn't exactly centered at the point of switching,
my autopilot hunts for a few moments, until it stabilizes again.
It's a small amount, and not an operational problem, but it makes the GPS
approaches slightly less smooth than an ILS, which doesn't have that bump.
My autopilot is a Collins AP-107.
Who sees any similar effect with other autopilots?
Is this a GNS 480 that is giving the step changes? Do you see these
small incremental changes on your CDI or HSI?
Old December 17th 06, 10:19 AM posted to rec.aviation.ifr
Ron Rosenfeld
On Sat, 16 Dec 2006 11:52:57 -0500, "John R. Copeland"
On Fri, 15 Dec 2006 06:56:17 -0800, Sam Spade wrote:
Subject line says it all.
If so, what was your impression?
Not yet. But I have flown an LNAV with advisory vertical guidance. The
needles were extremely stable -- more so than an ILS with my equipment.
Pretty easy to fly.
I've not noted a "step change" in my CNX80. The changes in sensitivity are
supposed to be gradual, and at the FAF I believe the "scaling" goes to
angular, to mimic an ILS. But maybe I've just missed it.
Old December 17th 06, 02:59 PM posted to rec.aviation.ifr
Sam Spade
As I understand it, it first ramps down to 0.3 from 1.0 starting at 2
miles from the LPV FAF, then it does a continuous angular "ramp down"
from the FAF to the runway so it will be ILS-like close in. Have you
noted that doing small incremental "stepping" on an LPV IAP during final
approach?
Old December 17th 06, 11:04 PM posted to rec.aviation.ifr
John R. Copeland
"Sam Spade" wrote in message ...
approach?
You say LPV course widths ramp down gradually over some miles?
Should LNAV/VNAV approaches do the same?
Around the FAF, it's usually too busy a time to collect every detail.
If it's not a step change in course width, it seems at least pretty quick.
Quick enough to disturb my autopilot a small amount, it seems.
But the reason I asked was to learn if other CNX80 users see a similar effect.
So far, the answer seems to be "no".
The effect I see is small, though, so it could be ignored easily.
If the blame turns out to be on my autopilot, I could send it back
to Collins to get it re-calibrated.
Old December 18th 06, 01:17 PM posted to rec.aviation.ifr
Sam Spade
RNAV IAPs, other than LPV, ramp down from 1.0 miles to 0.3 miles
starting two miles prior to the FAF, and completed at the FAF. Then,
the sensitivity remains at 0.3 throughout the final approach segment.
With LPV, the sensitivity continues to increase (course width decreases)
from the FAF to the runway. That causes LPV to be an angular system
from the FAF to the runway. Not so with other RNAV.
Old December 19th 06, 01:09 AM posted to rec.aviation.ifr
John R. Copeland
Thanks. I didn't know of the difference. I'll watch for it.
Old December 21st 06, 10:10 AM posted to rec.aviation.ifr
Sam Spade
I getting up to speed on the 145/146 spec. The LNAV approach also
reduces in the lateral mode similar to the laternal mode of the LPV
approach. When you reach the MAP, it is only 350 feet full scale
deflection, instead of the 0.3 mile defection for TSO 129 LNAV final.
Old December 21st 06, 02:44 PM posted to rec.aviation.ifr
Stan Prevost
from the FAF to the runway. That causes LPV to be an angular system from
I getting up to speed on the 145/146 spec. The LNAV approach also reduces
in the lateral mode similar to the laternal mode of the LPV approach.
When you reach the MAP, it is only 350 feet full scale deflection, instead
Do you have a link to the TSO handy? And is it the full requirement? Last
time I tried to read TSO C129, seems like it was a skeleton document,
referencing a commercial spec that had to be purchased.
Old December 21st 06, 03:12 PM posted to rec.aviation.ifr
John R. Copeland
I'm definitely gonna have to set up an experiment over that!
I'd expect to have noticed it, if my CNX80 behaved that way.
Is that a behavior demanded by TSO-C145/146, or merely allowed?
Old December 21st 06, 04:19 PM posted to rec.aviation.ifr
Sam Spade
Same with 145/146. The nuts-and-boths is in RTCA Doument 229C. $350.
Haven't flown in a long while... Flyingmonk Piloting 33 April 5th 06 06:30 AM
Total cross country distance flown Bill Daniels Soaring 9 November 4th 05 11:53 AM
If there are any pilots here that have ever flown aerial surveys.... terrygeosearch Piloting 1 February 8th 05 06:45 PM
If there are any pilots here that have ever flown aerial surveys.... terrygeosearch General Aviation 0 February 2nd 05 04:11 AM
Most aircraft types flown by 1 pilot? Chad Irby Military Aviation 10 January 7th 04 03:47 AM
