WAAS upgrade info for Garmin 430
Old December 24th 06, 02:41 PM posted to rec.aviation.owning
Ron Natalie
Default WAAS upgrade info for Garmin 430
Roy Smith wrote:
Is there anything I'm supposed to do with the "WAAS CH 90502 W09A"
information? Are there receivers which require you to tune the WAAS
corrections in manually? I've always assumed that a WAAS-equipped GPS
would just do that automatically.
The 480 does. I'm sure the 430-W will as well. I suspect this is
one of those things like the TACAN channel numbers put in there for
"other" users.
Old December 25th 06, 03:51 AM posted to rec.aviation.owning
Brad[_1_]
Roy Smith wrote:
In article . com,
"Brad" wrote:
200...
http://204.108.4.16/d-tpp/0612/00125R9.PDF
check the NOTAMs before you go...
Those WAAS channel numbers are part of a spec for "Delta 4" receivers
typically associated with an FMS installation that doesn't have a
database of the whole procedure, but instead uses the the channel
number to indentify the Final Approach Segment (FAS). The FMS is used
to navigate the procedure up to the FAF,and the Delta 4 receiver flies
the FAS. This is similar to how an ILS is flown using an FMS.
Your 480 shows the channel, but it isn't necessary to pull up the
procedure.
Old January 2nd 07, 11:59 PM posted to rec.aviation.owning
JD
http://www.aopa.org/whatsnew/air_traffic/waas-lpv.pdf
RNAV LPVs as of 9/28/06:
http://gps.faa.gov/Library/Data/Master-RNAVs_092806.xls
There may even be a newer list on the web site somewhere.
-JD
  #24
Old January 3rd 07, 04:33 PM posted to rec.aviation.owning
Brad[_1_]
Yes, there is...
http://gps.faa.gov/CapHill/indexApproach.htm
As of 12/21/06:
646 total LPV procedures, as well as 520 LNAV/VNAV procedures without
LPV that can be flown to LNAV/VNAV minima using WAAS.
Expect another 31 LPV procedures 1/18/07.
Brad
Garmin 530 WAAS upgrade - what's involved? Paul Tomblin Instrument Flight Rules 24 December 2nd 06 07:07 PM
Garmin 530 WAAS? Al G Instrument Flight Rules 53 November 21st 06 11:30 PM
Garmin 430/530 WAAS upgrade reminder Nov 15 Paul kgyy Owning 18 November 22nd 05 07:22 PM
Garmin 430/530 WAAS upgrade reminder Nov 15 Paul kgyy Instrument Flight Rules 18 November 22nd 05 07:22 PM
More info on GNS 430/530 WAAS upgrade PPT33R Instrument Flight Rules 33 June 24th 05 02:21 PM
